/*----------基于uPD6121/LC7461M/HT6222/AS6122等红外编码芯片的解码程序------------
作者:Benny
Blog:http://bennylo.mcublog.com/
Email:89S53@163.com
MCU: ATmega16
Crystal: 6.0000Mhz
#include <iom16v.h>
#include <macros.h>
#define uint unsigned int
#define ulong unsigned long
/*------------------------------显示-----------------------------------*/
#define LED_DATA PORTB
const uchar tab[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
0 1 2 3 4 5 6 7 8 9 A B C D E F
void delay(void){
uint i;
for(i=0;i<2000;i++);
void dis_int(uint dis_data)
{ //四位共阴数码管,十六进制显示
LED_DATA=tab[(uchar)((dis_data&0xf000)>>12)]; //显示千位
PORTD=0xf7;
delay(); //延时
LED_DATA=tab[(uchar)((dis_data&0x0f00)>>8)]; //显示百位
PORTD=0xfb;
delay(); //延时
LED_DATA=tab[(uchar)(dis_data&0x00f0)>>4]; //显示十位
PORTD=0xfd;
delay(); //延时
LED_DATA=tab[(uchar)dis_data&0x000f]; //显示个位
PORTD=0xfe;
delay(); //延时
void port_init(void)
PORTA = 0xFF;
DDRA = 0x00;
PORTB = 0xFF;
DDRB = 0xFF;
PORTC = 0xFF;
DDRC = 0xFF;
PORTD = 0xFF;
DDRD = 0x0F;
void timer1_init(void)
TCCR1B = 0x00; //stop
TCNT1H = 0x00; //setup
TCNT1L = 0x00;
ICR1H = 0x00;
ICR1L = 0x08;
TCCR1A = 0x00;
/*一体化接收头的DATA引脚接到ATmega16的PD6(ICP1)引脚,采用上升沿捕捉的方法解码*/
/*晶振为6M,无分频,用8M太大(分频则太小)*/
TCCR1B = 0x41; //start Timer
uint arr[16];//保存捕捉值
uchar times;//记录捕捉次数
uchar index;//数组索引
uchar ir_code;//红外遥控键码
uchar OK_flag;//解码完毕标志
模块名称:PD6(ICP1)引脚上升沿捕捉中断程序
影响: 将捕捉值保存在arr[16]中
___ ___
___| |_________| |__________
|<-----t----->|
DEC HEX
t=9ms 计数值=54000 0xD2F0
t=4.5ms 计数值=27000 0x6978
t=2.25ms 计数值=13500 0x34BC
t=1.125ms 计数值=6750 0x1A5E
#pragma interrupt_handler timer1_capt_isr:6
void timer1_capt_isr(void)
uint value;
value=ICR1L;
//CLI();
value|=(uint)(ICR1H << 8);
TCNT1H = 0x00;
TCNT1L = 0x00;
times++;
if(times>18&×<35){
//从第19个上升沿开始保存,直到第34个,短按时共有36个上升沿
arr[index]=value;
index++;
else if(times>=35){
//第35个上升沿到来时,解码完毕
times=0;
index=0;
OK_flag=1;
//SEI();
/*------------------------------解码程序----------------------------------------
结果:得到uchar型的键码ir_code,如果解码出错,则ir_code=0xff
void get_code(void){
uchar i,dat,/*键码*/_dat;/*键码反码*/
uint temp=0;
for(i=0;i<16;i++){
if(arr<7000){
//“0”
temp<<=1;
if(arr>13000){
//“1”
temp<<=1;
temp|=1;
_dat=(uchar)(temp&0x00ff);/*键码*/
dat=(uchar)((temp>>8)&0x00ff);/*键码反码*/
/*“键码”与“键码反码相与,如果为0则解码正确*/
if((dat&_dat)==0){
ir_code=dat;
else{
TCNT1H = 0x00;
TCNT1L = 0x00;
ir_code=0xff;//解码出错
times=0;
index=0;
void init_devices(void)
CLI();
port_init();
timer1_init();
MCUCR = 0x00;
GICR = 0x00;
TIMSK = 0x20;
SEI();
void main(void){
uchar i;
init_devices();
while(1){
if (OK_flag){
get_code();//解码
OK_flag=0;
for(i=0;i<200;i++){
dis_int(ir_code);//显示键码
