//============头文件nRF905.h============//
#define PWR_UP PORTB_PB7 //out
#define TX_EN PORTB_PB6 //out
#define TRX_CE PORTB_PB5 //out
#define CSN PORTB_PB4 //out
#define CD PORTB_PB3 //in
#define DR PORTB_PB2 //in
#define AM PORTB_PB1 //in
#ifndef _NRF905_H
#define _NRF905_H
#include "derivative.h" /* derivative-specific definitions */
#define WC 0x00 // Write configuration register command
#define RC 0x10 // Read configuration register command
#define WTP 0x20 // Write TX Payload command
#define RTP 0x21 // Read TX Payload command
#define WTA 0x22 // Write TX Address command
#define RTA 0x23 // Read TX Address command
#define RRP 0x24 // Read RX Payload command
#define AM PORTA_PA0 //in
#define DR PORTA_PA1 //in
#define MISO PORTA_PA2 //in
#define CD PORTA_PA3 //in
#define AM PTJ_PTJ0 //in
#define DR PTJ_PTJ1 //in
#define MISO PTJ_PTJ6 //in
#define CD PTJ_PTJ7 //in
#define TRX_CE PORTB_PB2 //out
#define CSN PORTB_PB3 //out
#define MOSI PORTB_PB4 //out
#define SCK PORTB_PB5 //out
extern volatile char nRF905TxBuf[32],nRF905RxBuf[32];
void nRF905_Interrupt(void);
void SetTxMode(void);
void SetRxMode(void);
void RxPacket(void);
void TxPacket(void);
void Config905(void);
void nRF905_Delay_100us(byte ms);
void nRF905_Delay_ms(int ms);
//==========C文件===============//
#include "nRF905.h"
#include "MC9S12XS128.h"
typedef struct RFConfig
byte n;
byte buf[10];
}RFConfig;
RFConfig RxTxConf =
10,
0x01, 0x0c, 0x44, 0x20, 0x20, 0xcc, 0xcc, 0xcc,0xcc, 0x58 // 433Mhz
//0x4C, 0x0e, 0x44, 0x20, 0x20, 0xcc, 0xcc, 0xcc,0xcc, 0x58 // 868/915MHz
byte ReceiveAddress[4]={0xcc, 0xcc, 0xcc,0xcc};
void nRF905_Interrupt(void) {
//PTJ_PTJ1中断
PPSJ_PPSJ1=1;
PIEJ_PIEJ1=1;
//延时约100微秒
int ii,jj;
for(ii=0;ii<ms;ii++)
for(jj=0;jj<540;jj++); //busclk:64MHz--100us
//延时约1毫秒
int ii,jj;
if (ms<1) ms=1;
ms=4*ms;
for(jj=0;jj<1335;jj++); //busclk:64MHz--1ms
//function SpiWrite();
void SPIWrite(byte tmch)
byte i;
for(i=0;i<8;i++) // Setup byte chirculation bits
if(tmch&0X80) // Put DATA_BUF.7 on data line
MOSI=1;
MOSI=0;
SCK=1; // Set clock line high
tmch <<= 1; // Shift DATA_BUF
SCK=0; // Set clock line low
// function SpiRead();
byte SPIRead(void)
byte i,dat=0;
for (i=0;i<8;i++) // Setup byte circulation bits
dat <<=1 ; // Right shift DATA_BUF
if(MISO)
dat |= 0x01; // Read data
return dat; // Return function parameter
//function Config905();
//开发板IO及模块寄存器配置
byte i;
//DDRA=0XF0;
DDRB=0XFF;
DDRJ=0x00;
DR=1; // Init DR for input
AM=1; // Init AM for input
PWR_UP=1; // nRF905 power on
TRX_CE=0; // Set nRF905 in standby mode
TX_EN=0; // set radio in Rx mode
CSN=0; // Spi enable for write a spi command
SPIWrite(WC); // Write config command写放配置命令
for (i=0;i<RxTxConf.n;i++) // Write configration words 写放配置字
SPIWrite(RxTxConf.buf);
CSN=1; // Disable Spi
//function TxPacket();
void TxPacket(void)
byte i;
SPIWrite(WTP); // Write payload command
for (i=0;i<32;i++)
SPIWrite(nRF905TxBuf); // Write 32 bytes Tx data
CSN=1; // Spi disable
nRF905_Delay_100us(1);
SPIWrite(WTA); // Write address command
for (i=0;i<4;i++) // Write 4 bytes address
SPIWrite(ReceiveAddress);
//TX_EN=1; 是否需要置1?
TRX_CE=1; // Set TRX_CE high,start Tx data transmission
nRF905_Delay_100us(1); // while (DR!=1);
TRX_CE=0; // Set TRX_CE low
//function RxPacket();
void RxPacket(void)
byte i;
SPIWrite(RRP); // Read payload command
for (i=0;i<32;i++)
nRF905RxBuf=SPIRead(); // Read data and save to buffer
CSN=1; // Disable spi
while(DR||AM);
TRX_CE=1;
//function SetTxMode();
TX_EN=1;
TRX_CE=1;
nRF905_Delay_ms(1); // nRF905_Delay_100us for mode change(>=650us)
//function SetRxMode();
TX_EN=0;
TRX_CE=1;
点击此处下载 ourdev_716697LE9KZA.rar(文件大小:2K) (原文件名:nRF905.rar) |
