本程序采用了新唐NUC120RD2BN带了EBI总线的CPU,因为ILI9327只有一个地址线RS,也就是命令,数据寄存器地址,而且又支持16位总线,所以把此地址线接到多余的ALE上,把ALE配置成GPIO模式,把ALE地址锁存的时序忽略掉,直接用EBI总线驱动ILI9327的数据总线。
      其余不多说,请查看源码文件:ili9327.c
文件内容如下:
* Includes ------------------------------------------------------------------*/
#include <stdio.h>
#include <NUC1xx.H>
#include "Driver\DrvSYS.h"
#include "Driver\DrvGPIO.h"
#include "Driver\DrvEBI.h"
#define TFT_BL                E_GPA, 15   /* PA.15 = TFT_BL   */
#define TFT_RST               E_GPA, 9   /* PA.9  = TFT_RST  */
#define TFT_DC                E_GPB, 6   /* PB.6  = TFT_DC   */
#define ILI9327_READ()    (*(__IO uint16_t *)(0x60000000))
#define ILI9327_DAT(DAT)    *(__IO uint16_t *)(0x60000000) = DAT
#define ILI9327_CMD(CMD)   {GPIOB->DOUT &= 0xffbf;*(__IO uint16_t *)(0x60000000) = CMD;GPIOB->DOUT |= 0x0040;}
//make by yuanxihua@21cn.com
//BYD LCM
//BM240400-8790FTGB
//262K TFT 240RGB×400dots
//ILI9327 is a 262,144-color single-chip SoC driver for a-TFT liquid crystal display
//with resolution of 240RGBx432 dots, comprising a 720-channel source driver, a 432-channel
//gate driver, 233,280 bytes GRAM for graphic data of 240RGBx432 dots, and power supply circuit.
_________________________________________________
| NUC120RD2BN      ILI9327B |
| PA9  TFT_RST  ---->  RESET  |
| PA15 TFT_BL  ---->  BACKLIGHT |
| PB6  TFT_DC  ---->  RS   |
| NCS  TFT_CS  ---->  CS   |
| NWR  TFT_WR  ---->  WR   |
| NRD  TFT_RD  ---->  RD   |
| AD0  TFT_D0  <--->  DB0   |
| AD15 TFT_D15  <--->  DB15  |
|_______________________________________________|
uint16_t color_table[16]={0x0000,0xf800,0x07e0,0x001f,0xf81f,0xffe0,0x07ff,0xffff,};
void EBI_Init(void)
 DRVEBI_CONFIG_T sEBIConfig;
 DRVEBI_TIMING_T sEBITiming;
 // Open EBI function
 sEBIConfig.eDataWidth  = E_DRVEBI_DATA_16BIT;
 sEBIConfig.eAddrWidth  = E_DRVEBI_ADDR_16BIT;
 sEBIConfig.u32BaseAddress  = DRVEBI_BASE_ADDR;
 sEBIConfig.u32Size    = DRVEBI_MAX_SIZE;
  DrvEBI_Open(sEBIConfig);
 // Disable nWRH & nWRL for EBI support
 outpw(&SYS->GPBMFP, inpw(&SYS->GPBMFP) & ~(0x3<<2));
 outpw(&SYS->ALTMFP, inpw(&SYS->ALTMFP) & ~(0x3<<13));
 // Configure EBI timing
// sEBITiming.eMCLKDIV = E_DRVEBI_MCLKDIV_1; // 1656.0 KHZ  //Display And Read ID ERROR!!!
// sEBITiming.eMCLKDIV = E_DRVEBI_MCLKDIV_2; // 1147.0 KHZ  //Display OK, But Read ID ERROR!!!
 sEBITiming.eMCLKDIV = E_DRVEBI_MCLKDIV_4; //  666.7 KHZ  //Display OK, And Read ID OK!!!
// sEBITiming.eMCLKDIV = E_DRVEBI_MCLKDIV_8; //  400.0 KHZ
// sEBITiming.eMCLKDIV = E_DRVEBI_MCLKDIV_16; //  211.9 KHZ
// sEBITiming.eMCLKDIV = E_DRVEBI_MCLKDIV_32; //  106.4 KHZ
  sEBITiming.u8ExttALE = 0;
 sEBITiming.u8ExtIR2R = 0;
 sEBITiming.u8ExtIW2X = 0;
 sEBITiming.u8ExttAHD = 0;
 sEBITiming.u8ExttACC = 0;
 DrvEBI_SetBusTiming(sEBITiming);
void ILI9327_READ_ID(void)
 uint16_t i;
 ILI9327_CMD(0xEF);    //Device Code Read
 printf("ILI9327 ID DATA: ");
 for(i=1;i<=6;i++){printf("%04x ",(uint16_t)ILI9327_READ());}
 printf("\n\r\n\r");
void ILI9327_RESET(void)
 //PA9 PA15 PB6 is defined as GPIO;
 outpw(&SYS->GPAMFP, inpw(&SYS->GPAMFP) & ~(0x1<< 9));
 outpw(&SYS->GPAMFP, inpw(&SYS->GPAMFP) & ~(0x1<<15));
 outpw(&SYS->GPBMFP, inpw(&SYS->GPBMFP) & ~(0x1<< 6));
 //TFT_RST TFT_DC TFT_BL is defined as Output;
 DrvGPIO_Open(TFT_RST, E_IO_OUTPUT);
 DrvGPIO_Open(TFT_DC , E_IO_OUTPUT);
 DrvGPIO_Open(TFT_BL , E_IO_OUTPUT);
 DrvGPIO_SetBit(TFT_DC );
 DrvGPIO_ClrBit(TFT_BL );
 DrvGPIO_SetBit(TFT_RST);
 DrvSYS_Delay(1000);
 DrvGPIO_ClrBit(TFT_RST);   // RESET LOW  >=   1 ms
 DrvSYS_Delay(2000);
  DrvGPIO_SetBit(TFT_RST);   // RESET HIGH >= 120 ms
 DrvSYS_Delay(200000);
void ILI9327_CLEAR(uint16_t color)
    uint16_t i,j;
 for(i=0;i<240;i++)
  for (j=0;j<400;j++) {ILI9327_DAT(color);}
void Delay_1ms(int delay)
 uint32_t i;
 for(i=0;i<delay;i++)DrvSYS_Delay(1000);
void ILI9327_TEST(void)
 uint16_t i,color;
 printf("%s(%d): Running:  %s()\n\r",__FILE__,__LINE__,__FUNCTION__);
  color = color_table[(i++)%8];
  printf("COLOR = 0x%04x \n\r",color);
  ILI9327_CLEAR(color);
  Delay_1ms(2000);   // 2s
void ILI9327_Init(void)
 printf("*** ILI9327 Driver V1.00 Build by yuanxihua@21cn.com on ("__DATE__ " - " __TIME__ ")\n\r\n\r");
 EBI_Init();
 ILI9327_RESET();
 ILI9327_READ_ID();
    ILI9327_CMD(0xE9);  //
    ILI9327_DAT(0x20);
    ILI9327_CMD(0x11);   //exit_sleep_mode
    DrvSYS_Delay(100000); //100 ms
    ILI9327_CMD(0xD1);   //VCOM Control
    ILI9327_DAT(0x00);
    ILI9327_DAT(0x6b);
    ILI9327_DAT(0x18);
    ILI9327_CMD(0xD0);   //Power_Setting
    ILI9327_DAT(0x07);
    ILI9327_DAT(0x04);
    ILI9327_DAT(0x88);
    ILI9327_CMD(0x36);  //set_address_mode
    ILI9327_DAT(0x88);
    ILI9327_CMD(0xC1);  //Display_Timing_Setting for Normal/Partial Mode
    ILI9327_DAT(0x10);
    ILI9327_DAT(0x10);
    ILI9327_DAT(0x02);
    ILI9327_DAT(0x02);
    ILI9327_CMD(0xC0);   //Panel Driving Setting
    ILI9327_DAT(0x00);
    ILI9327_DAT(0x35);
    ILI9327_DAT(0x00);
    ILI9327_DAT(0x00);
    ILI9327_DAT(0x01);
    ILI9327_DAT(0x02);
    ILI9327_CMD(0xC5);   //Frame Rate Control
    ILI9327_DAT(0x02);
    ILI9327_CMD(0xD2);   //Power_Setting for Normal Mode
    ILI9327_DAT(0x01);
    ILI9327_DAT(0x44);
    ILI9327_CMD(0xC8);  //Gamma Setting
    ILI9327_DAT(0x00);
    ILI9327_DAT(0x56);
    ILI9327_DAT(0x45);
    ILI9327_DAT(0x04);
    ILI9327_DAT(0x03);
    ILI9327_DAT(0x01);
    ILI9327_DAT(0x23);
    ILI9327_DAT(0x12);
    ILI9327_DAT(0x77);
    ILI9327_DAT(0x40);
    ILI9327_DAT(0x09);
    ILI9327_DAT(0x06);
    ILI9327_DAT(0x88);
    ILI9327_DAT(0x88);
    ILI9327_DAT(0x88);
    ILI9327_CMD(0x3A);   //set_pixel_format
 ILI9327_DAT(0x55);
 ILI9327_CMD(0x2A);  //set_column_address
 ILI9327_DAT(0x00);
 ILI9327_DAT(0x00);
 ILI9327_DAT(0x00);
 ILI9327_DAT(0xEF);
 ILI9327_CMD(0x2B);  //set_page_address
 ILI9327_DAT(0x00);
 ILI9327_DAT(0x20);
 ILI9327_DAT(0x01);
 ILI9327_DAT(0xAF);
 ILI9327_CMD(0x29);   //set_display_on
 ILI9327_CMD(0x2C);  //write_memory_start
 DrvGPIO_SetBit(TFT_BL );
 ILI9327_TEST();
void ILI9327_SLEEP(void)
 ILI9327_CMD(0x10);  //enter_sleep_mode
void ILI9327_WAKEUP(void)
void EBI_test(void)
 uint32_t i,j=0;
 uint32_t data;
 EBI_Init();
 printf("MCLK of EBI colck is %d KHz.\n\r", (DrvSYS_GetHCLKFreq()/4)/1000);
 //PA9 PB6 is defined as GPIO;
 outpw(&SYS->GPAMFP, inpw(&SYS->GPAMFP) & ~(0x1<<9));
 outpw(&SYS->GPBMFP, inpw(&SYS->GPBMFP) & ~(0x1<<6));
 //TFT_RST TFT_DC TFT_BLis defined as Output;
 DrvGPIO_Open(E_GPB, 1 , E_IO_OUTPUT); //LED test...
 while(0)
  //test for write
  *(__IO uint16_t *)((uint32_t)0x60000000) = 0xffff;
  *(__IO uint16_t *)((uint32_t)0x60000000) = 0x0000;
 while(0)
  //test for read
  data =  *(__IO uint16_t *)((uint32_t)0x60000000);
  printf("Running %d Times : D15-D0:%1d%1d%1d%1d%1d%1d%1d%1d_%1d%1d%1d%1d%1d%1d%1d%1dB\n\r",j++,
  (data>>15)&0x1,(data>>14)&0x1,(data>>13)&0x1,(data>>12)&0x1,
  (data>>11)&0x1,(data>>10)&0x1,(data>> 9)&0x1,(data>> 8)&0x1,
  (data>> 7)&0x1,(data>> 6)&0x1,(data>> 5)&0x1,(data>> 4)&0x1,
  (data>> 3)&0x1,(data>> 2)&0x1,(data>> 1)&0x1,(data>> 0)&0x1);
  for(i=0;i<0x200000;i++); //delay about 1 second
  printf("Running %d Times...\n\r",j++);
  //test for IO
  GPIOB->DOUT |= (1 << 1);
  DrvGPIO_ClrBit(TFT_DC );
  GPIOB->DOUT &= ~(1 << 1);
文件结束。
文件源自于飘渺九哥微博 |
