- #include "proj_incs.h"
- int main()
- GPIO_LED_0<<IO_MAKE_OUT_ON;
- CLK_MAIN_ChangToXosc();
- GPIO_LED_0<<IO_OFF;
- PERIPH_UART.Init(9600);
- while(1)
- PERIPH_PRINT<<"PUT STR :"<<"string"<<"\r\n";
- lgt_delay_ms_26m(1000);
- GPIO_LED_0<<IO_TOGGLE;
- PERIPH_PRINT<<"PUT CHAR :"<<'c'<<"\r\n";
- PERIPH_PRINT<<"PUT UINT8 DEC :"<<PRINT_FORMAT_INT_DEC<<(uint8)100<<"\r\n";
- PERIPH_PRINT<<"PUT UINT8 HEX :"<<PRINT_FORMAT_INT_HEX<<(uint8)100<<"\r\n";
- PERIPH_PRINT<<"PUT SINT8 DEC :"<<PRINT_FORMAT_INT_DEC<<(sint8)-100<<"\r\n";
- PERIPH_PRINT<<"PUT SINT8 HEX :"<<PRINT_FORMAT_INT_HEX<<(sint8)-100<<"\r\n";
- PERIPH_PRINT<<"PUT UINT16 DEC :"<<PRINT_FORMAT_INT_DEC<<(uint16)100<<"\r\n";
- PERIPH_PRINT<<"PUT UINT16 HEX :"<<PRINT_FORMAT_INT_HEX<<(uint16)100<<"\r\n";
- PERIPH_PRINT<<"PUT SINT16 DEC :"<<PRINT_FORMAT_INT_DEC<<(sint16)-100<<"\r\n";
- PERIPH_PRINT<<"PUT SINT16 HEX :"<<PRINT_FORMAT_INT_HEX<<(sint16)-100<<"\r\n";
- PERIPH_PRINT<<"PUT UINT32 DEC :"<<PRINT_FORMAT_INT_DEC<<(uint32)100<<"\r\n";
- PERIPH_PRINT<<"PUT UINT32 HEX :"<<PRINT_FORMAT_INT_HEX<<(uint32)100<<"\r\n";
- PERIPH_PRINT<<"PUT SINT32 DEC :"<<PRINT_FORMAT_INT_DEC<<(sint32)-100<<"\r\n";
- PERIPH_PRINT<<"PUT SINT32 HEX :"<<PRINT_FORMAT_INT_HEX<<(sint32)-100<<"\r\n";
- PERIPH_PRINT<<"PUT UINT DEC :"<<PRINT_FORMAT_INT_DEC<<100U<<"\r\n";
- PERIPH_PRINT<<"PUT UINT HEX :"<<PRINT_FORMAT_INT_HEX<<100U<<"\r\n";
- PERIPH_PRINT<<"PUT SINT DEC :"<<PRINT_FORMAT_INT_DEC<<-100<<"\r\n";
- PERIPH_PRINT<<"PUT SINT HEX :"<<PRINT_FORMAT_INT_HEX<<-100<<"\r\n";
- uint8 array[8]={0x11,0x22,0x33,0x44,0x55,0x66,0x77,0x88};
- PERIPH_PRINT<<"PUT ARRAY LITEND :"<<PRINT_FORMAT_BLOCK_LITEND<<array<<"\r\n";
- PERIPH_PRINT<<"PUT ARRAY BIGEND :"<<PRINT_FORMAT_BLOCK_BIGEND<<array<<"\r\n";
复制代码 |
