这些例程是这样的,那些程序是什么意思的,我看了那个固件库看了一整天都看不懂
请各位大侠指点指点
TIM3 配置: 产生1路PWM信号;
TIM3CLK = 72 MHz, Prescaler = 0(不分频), TIM3 counter clock = 72 MHz
计算公式:
PWM输出频率 = TIM3 counter clock /(ARR + 1)
我们期望设置为100Hz
如果不对TIM3CLK预分频,那么不可能得到100Hz低频。
我们设置分频比 = 1000, 那么 TIM3 counter clock = 72KHz
TIM_Period = 720 - 1;
频率下不来。
TIM_TimeBaseStructure.TIM_Period = 720 - 1; /* TIM_Period = TIM3 ARR Register */
TIM_TimeBaseStructure.TIM_Prescaler = 0;
TIM_TimeBaseStructure.TIM_ClockDivision = 0;
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
/* PWM1 Mode configuration: Channel1 */
TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
_bright = 1 时, TIM_Pulse = 1
_bright = 255 时, TIM_Pulse = TIM_Period
TIM_OCInitStructure.TIM_Pulse = (TIM_TimeBaseStructure.TIM_Period * _bright) / BRIGHT_MAX; /* 改变占空比 */
TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
TIM_OC4Init(TIM3, &TIM_OCInitStructure);
TIM_OC4PreloadConfig(TIM3, TIM_OCPreload_Enable);
TIM_ARRPreloadConfig(TIM3, ENABLE);
/* TIM3 enable counter */
TIM_Cmd(TIM3, ENABLE);
