发表于 2012-11-20 17:03:37
串口终于可以用了。是J3的短接块没有插好。
关于楼上的问题,我认为如果不需要额外的变动是最好。
$regfile = "m164pdef.dat"
$crystal = 8000000
$baud = 9600 '定义波特率
$hwstack = 64 '定义堆栈
$swstack = 32 '
$framesize = 32
Config Pina.0 = Output
Config Pina.1 = Output
Config Pina.2 = Output
Config Pina.3 = Output
Config Pina.4 = Output
Config Pind.0 = Input : Portd.0 = 0 'RXD
Config Pind.1 = Input : Portd.1 = 0 'TXD
Config Timer1 = Timer , Prescale = 256 'T=17.36uS
Timer1 = 34285 '100mS
On Ovf1 Tim1_isr '定时器0中断程序入口
Do
Wait 1
Porta.2 = Not Porta.2 '指示灯
Print "123ABC" '串口发送字符
Loop
End
