硬件:mega16L 软件:ICC6.31
1、我使用书中的例程(boot基础事例程序)改写成mega16的程序,读取flash,可以看到flash被改写成“串口数据包计算助手”生成的数据。
但我,根据例程(实例18_ATmega48在线程序更新_闪烁方式1)修改后,mega48在线下载后台软件可以下载成功程序,但程序运行的不是IAP下载的程序。不知道是怎么回事。
谢谢。
程序如下:
#include "iom16v.h"
#include "macros.h"
#define mclk 16000000
#define Con_true 1
#define CmdByte IapBuffer[1]
#define PageAddrL IapBuffer[2]
#define PageAddrH IapBuffer[3]
void Iap (void);
union Char_Int
unsigned char chr_dat[2];
unsigned int Int_dat;
#define CHAR_H 1
#define CHAR_L 0
void Delay_mS(unsigned int Time)
unsigned char n;
while(Time>0)
for (n=1;n<187;n++)
asm("nop");
Time--;
void main (void)
DDRC = 0xFF;
PORTC = 0xFF;
DDRB = 0x00; //PB端口输入状态
PORTB = 0xFF; //PB端口开启内建上拉
uart_init(9600);
// uart_putchar('a') ;
while(PINB&0x01)
PORTC ^= 0xFF;
Delay_mS(500);
Iap();
#pragma text:boot_zone
函数名称: Uart_init
功 能: 异步串口初始化
参 数: 无
返回值 : 无
void uart_init(unsigned int baud)
UCSRB=0x00;
UCSRA=0x00; //控制寄存器清零
UCSRC=(1<<URSEL)|(0<<UPM0)|(3<<UCSZ0); //选择UCSRC,异步模式,禁止
baud=mclk/16/baud-1 ; // 校验,1位停止位,8位数据位
UBRRL=baud; //波特率最大为65K
UBRRH=baud>>8; //设置波特率
UCSRB=(1<<TXEN)|(1<<RXEN); //接收、发送使能,接收中断使能
// SREG|=0x80; //全局中断开放
DDRD|=0X02; //配置TX为输出(很重要)
//从RS232发送一个字节
void uart_putchar(char c)
while(!(UCSRA & 0x20));
UDR = c;
//从RS232接收一个字节
int uart_getchar(void)
unsigned char status,res;
if(!(UCSRA & 0x80)) return -1; //no data to be received
status = UCSRA;
res = UDR;
if (status & 0x1c) return -1; // If error, return -1
return res;
unsigned char Iap_Receive (void)
unsigned int counter;
counter = 30000;
while(!(UCSRA&(1<<RXC)))
if (counter==0)
PORTC ^= (1<<5);
counter = 30000;
counter--;
return UDR;
void Iap_OK () //发送应答包 AA 05 50 55 55
unsigned char Iap_Pack_OK[5];
unsigned char i;
Iap_Pack_OK[0] = 0xAA;
Iap_Pack_OK[1] = 0x05;
Iap_Pack_OK[2] = 0x50;
Iap_Pack_OK[3] = 0x55;
Iap_Pack_OK[4] = 0x55;
for (i = 0 ; i < 5 ; i++)
uart_putchar(Iap_Pack_OK);
void Fill_Tb (unsigned int dat, unsigned int addr)
asm("movw R30,R18");
asm("movw R0,R16");
asm("ldi R16,0x01");
asm("sts 0x57,R16");
asm("spm");
while(SPMCR&(1<<SPMEN));
void Erase_Page (unsigned int addr)
asm("ldi R16,0x03");
asm("spm");
void Prog_Page (unsigned int addr)
asm("ldi R16,0x05");
asm("spm");
#pragma ctask Iap
void Iap (void)
unsigned char counter,IapStatu,CheckSum, i;
unsigned char IapBuffer[1800];
union Char_Int Iap_dat,Iap_addr;
CLI(); //整个IAP过程中都将禁止中断
DDRC = (1<<5); //PC5端口上的发光二极管闪烁以指示IAP状态
// uart0_init(); //重新初始化串口模块
IapStatu = 1; //进入IAP状态
// uart_putchar('b') ;
// Iap_OK();
while (IapStatu)
while(Iap_Receive() != 0xAA); //等待包头到来,包头不参与校验计算,可不存储
IapBuffer[0] = Iap_Receive(); //接收包长度字节
for (counter = 0 ; counter < (IapBuffer[0]-2) ; counter++)
IapBuffer[counter+1] = Iap_Receive(); //依长度字节指示,循环接收所有数据
if(CmdByte==0x09)
IapStatu = 0;
continue;
CheckSum = 0;
for (i = 0 ; i < (IapBuffer[0]-2) ; i++)
CheckSum ^= (IapBuffer);
uart_putchar(IapBuffer);
// CheckSum ^= (IapBuffer[IapBuffer[0]-2]);
//uart_putchar('a') ;
if (CheckSum!= 0x00)
continue; //校验失败,返回等待下一次通讯
// uart_putchar('c') ;
if (CmdByte != 'P') //接到退出下载命令,退出IAP状态 'P'=0x50
// uart_putchar('d') ;
IapStatu = 0;
continue;
Iap_OK();
Iap_addr.chr_dat[CHAR_H] = PageAddrH;
Iap_addr.chr_dat[CHAR_L] = PageAddrL;
for(counter = 0 ; counter < 64 ; counter++) //缓冲页面填充
Iap_dat.chr_dat[CHAR_L] = IapBuffer[(counter*2)+4];
Iap_dat.chr_dat[CHAR_H] = IapBuffer[(counter*2)+5];
Fill_Tb(Iap_dat.Int_dat, (unsigned int)(Iap_addr.Int_dat+(counter*2)));
Erase_Page(Iap_addr.Int_dat); //页面擦除
Prog_Page(Iap_addr.Int_dat); //页面写入
// break;
uart_putchar('b') ;
asm("rjmp __start"); //软件实现的从新启动
