CPU XBurst, 600MHz
VPU 720P Decoder
GPU 2D Graphics, Alpha Blending, Up to 100M Pix/S and 1080P
Mem-IF 8/16-bit SRAM, Nor Flash SLC/MLC/TLC NAND Flash , Support 4/8/12/24 bit ECC 16/32-bit DDR2/DDR/Mobile DDR SDRAM
Peripherals AC97/I2S/SPDIF, Audio Code, LCD-IF, TV Encoder, EPD-IF, Camera-IF, Touch ADC
1-wire, PCM, I2C, SPI, UART, SIM-IF, SD/MMC/SDIO, USB Host, USB OTG 2.0, TS-IF
Package BGA345,14mm x 14mm x 1.1mm, 0.65mm pitch
Process 0.13um CMOS
