不知道这个标题是否符合要求啊,因为有比较多的问题,很难在标题上都体现出来,希望莫老大不要封号啊!!
程序:
#include <reg52.h>
typedef unsigned char uint8;
sbit Ir_Pin = P3^3;
uint8 Ir_Buf[4]; //用于保存解码结果
* UART初始化
* 波特率:9600
void uart_init(void)
TMOD = 0x21;
SCON = 0x50;
TH1 = 0xFD;
TL1 = 0xFD;
TR1 = 1;
* UART发送一字节
void UART_Send_Byte(uint8 dat)
SBUF = dat;
while (TI == 0);
TI = 0;
* 获取低电平时间
unsigned int Ir_Get_Low()
TL0 = 0;
TH0 = 0;
TR0 = 1;
while (!Ir_Pin && (TH0&0x80)==0);
TR0 = 0;
return (TH0 * 256 + TL0);
* 获取高电平时间
unsigned int Ir_Get_High()
TL0 = 0;
TH0 = 0;
TR0 = 1;
while (Ir_Pin && (TH0&0x80)==0);
TR0 = 0;
main()
unsigned int temp;
char i,j;
uart_init();
while (1)
start:
while (Ir_Pin);
temp = Ir_Get_Low();
if ((temp < 7833) || (temp > 8755)) //引导脉冲低电平8500~9500us
goto start;
temp = Ir_Get_High();
if ((temp < 3686) || (temp > 4608)) //引导脉冲高电平4000~5000us
goto start;
for (i=0; i<4; i++) //4个字节
for (j=0; j<8; j++) //每个字节8位
if ((temp < 184) || (temp > 737)) //200~800us
goto start;
if ((temp < 184) || (temp > 1843)) //200~2000us
goto start;
Ir_Buf[i] >>= 1;
if (temp > 1032) //1120us
Ir_Buf[i] |= 0x80;
UART_Send_Byte(Ir_Buf[0]);
UART_Send_Byte(Ir_Buf[1]);
UART_Send_Byte(Ir_Buf[2]);
UART_Send_Byte(Ir_Buf[3]);
问题:
1、为什么把定时0的TH0 TL0 设置为0?
2、while (Ir_Pin && (TH0&0x80)==0); 这个语句是什么意思?
3、那两个for循环是什么意思?
