发表于 2013-3-28 15:20:35
今天终于把代码的架构完善了下,重新写了makefile文件,将代码下下来直接编译就可以了,环境不需要配置了!
下下来后直接在根目录下面执行:
make help
就能看到对应的命令!
root@microcreat:/workdir/private/20130325/new/cortexm_uclinux# make help
You can use the following command
compile the uboot:
make uboot; make uboot_clean;
compile the kernel:
make kernel; make kernel_clean;
compile the rootfs:
make rootfs; make rootfs_clean;
clean the target:
make clean;
注:可能有些地方不够用完善,希望大家能修改并指出来,谢谢! |
