说说modbus.h
#include "board.h"
#include"STC_IAP_EEPROM.h"
/* CRC 高位字节值表 */
unsigned char code xuchCRCHi[] = {
0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0,
0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41,
0x00, 0xC1, 0x81, 0x40, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0,
0x80, 0x41, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40,
0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1,
0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41,
0x81, 0x40, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41,
0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x00, 0xC1, 0x81, 0x40,
0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1,
0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40,
0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0,
/* CRC低位字节值表*/
unsigned char code xuchCRCLo[] = {
0x00, 0xC0, 0xC1, 0x01, 0xC3, 0x03, 0x02, 0xC2, 0xC6, 0x06,
0x07, 0xC7, 0x05, 0xC5, 0xC4, 0x04, 0xCC, 0x0C, 0x0D, 0xCD,
0x0F, 0xCF, 0xCE, 0x0E, 0x0A, 0xCA, 0xCB, 0x0B, 0xC9, 0x09,
0x08, 0xC8, 0xD8, 0x18, 0x19, 0xD9, 0x1B, 0xDB, 0xDA, 0x1A,
0x1E, 0xDE, 0xDF, 0x1F, 0xDD, 0x1D, 0x1C, 0xDC, 0x14, 0xD4,
0xD5, 0x15, 0xD7, 0x17, 0x16, 0xD6, 0xD2, 0x12, 0x13, 0xD3,
0x11, 0xD1, 0xD0, 0x10, 0xF0, 0x30, 0x31, 0xF1, 0x33, 0xF3,
0xF2, 0x32, 0x36, 0xF6, 0xF7, 0x37, 0xF5, 0x35, 0x34, 0xF4,
0x3C, 0xFC, 0xFD, 0x3D, 0xFF, 0x3F, 0x3E, 0xFE, 0xFA, 0x3A,
0x3B, 0xFB, 0x39, 0xF9, 0xF8, 0x38, 0x28, 0xE8, 0xE9, 0x29,
0xEB, 0x2B, 0x2A, 0xEA, 0xEE, 0x2E, 0x2F, 0xEF, 0x2D, 0xED,
0xEC, 0x2C, 0xE4, 0x24, 0x25, 0xE5, 0x27, 0xE7, 0xE6, 0x26,
0x22, 0xE2, 0xE3, 0x23, 0xE1, 0x21, 0x20, 0xE0, 0xA0, 0x60,
0x61, 0xA1, 0x63, 0xA3, 0xA2, 0x62, 0x66, 0xA6, 0xA7, 0x67,
0xA5, 0x65, 0x64, 0xA4, 0x6C, 0xAC, 0xAD, 0x6D, 0xAF, 0x6F,
0x6E, 0xAE, 0xAA, 0x6A, 0x6B, 0xAB, 0x69, 0xA9, 0xA8, 0x68,
0x78, 0xB8, 0xB9, 0x79, 0xBB, 0x7B, 0x7A, 0xBA, 0xBE, 0x7E,
0x7F, 0xBF, 0x7D, 0xBD, 0xBC, 0x7C, 0xB4, 0x74, 0x75, 0xB5,
0x77, 0xB7, 0xB6, 0x76, 0x72, 0xB2, 0xB3, 0x73, 0xB1, 0x71,
0x70, 0xB0, 0x50, 0x90, 0x91, 0x51, 0x93, 0x53, 0x52, 0x92,
0x96, 0x56, 0x57, 0x97, 0x55, 0x95, 0x94, 0x54, 0x9C, 0x5C,
0x5D, 0x9D, 0x5F, 0x9F, 0x9E, 0x5E, 0x5A, 0x9A, 0x9B, 0x5B,
0x99, 0x59, 0x58, 0x98, 0x88, 0x48, 0x49, 0x89, 0x4B, 0x8B,
0x8A, 0x4A, 0x4E, 0x8E, 0x8F, 0x4F, 0x8D, 0x4D, 0x4C, 0x8C,
0x44, 0x84, 0x85, 0x45, 0x87, 0x47, 0x46, 0x86, 0x82, 0x42,
0x43, 0x83, 0x41, 0x81, 0x80, 0x40
unsigned char SLAVEADDRESS = 0x00; //从机地址
函数名称:unsigned short crc16(unsigned char *puchMsg, unsigned int usDataLen)
函数功能:CRC16校验函数
入口参数:(unsigned char) *puchMsg:指向需要CRC16校验的消息包(unsigned int)usDataLen:消息包长度
返回值:返回CRC16校验结果
unsigned char uchCRCHi = 0xFF ; /* 高CRC字节初始化 */
unsigned char uchCRCLo = 0xFF ; /* 低CRC 字节初始化 */
unsigned short tmp_crc;
unsigned long int uIndex ; /* CRC循环中的索引 */
while (usDataLen--) /* 传输消息缓冲区 */
uIndex = uchCRCHi ^ (*puchMsg++); /* 计算CRC */
uchCRCHi = uchCRCLo ^ xuchCRCHi[uIndex] ;
uchCRCLo = xuchCRCLo[uIndex] ;
tmp_crc = uchCRCLo;
tmp_crc = tmp_crc << 8;
tmp_crc += uchCRCHi;
return (tmp_crc) ;
函数名称:void askComm0Modbus(void)
函数功能:检查uart0数据
入口参数:无
返回值:无
其他说明:无
unsigned int crcData;//CRC16校验
unsigned char tempData;//数据个数
unsigned int tmp_crc;//接收的CRC16校验
unsigned char i = 0;
switch(uchRX_Buffer[1])
case 0x03://读取寄存器(一个或多个)
crcData = crc16(uchRX_Buffer,6);//CRC16校验
//判断起始地址和寄存器数量是否超界
if( (uchRX_Buffer[2] == 0) && (uchRX_Buffer[3] <= 0x0f)
&& (uchRX_Buffer[4] == 0) && (uchRX_Buffer[5] <= 5) )
tmp_crc = uchRX_Buffer[7];
tmp_crc += uchRX_Buffer[6];
if( crcData == tmp_crc )//校验正确
sendRegisters();
RXData_Counter1 = 0;
case 0x10://设置多个寄存器
if ( (uchRX_Buffer[2] == 0) && (uchRX_Buffer[3] <= 0x0f)
tempData = uchRX_Buffer[5];
tempData = tempData * 2;//数据个数
//没有判断字节数是否和寄存器数量是否一致
tempData += 9;
if (RXData_Counter1 >= tempData)
crcData = crc16(uchRX_Buffer,tempData-2);
tmp_crc = uchRX_Buffer[tempData-1];
tmp_crc += uchRX_Buffer[tempData-2];
if ( crcData == tmp_crc )
if (uchRX_Buffer[3] != 0x0f )
presetMultipleRegisters();
else //修改地址
if (uchRX_Buffer[0] == 0)
SLAVEADDRESS = uchRX_Buffer[8];
Sector_Erase(DATA_FLASH_START_ADDRESS);
Byte_Program(DATA_FLASH_START_ADDRESS,&SLAVEADDRESS);
for(i = 0;i < 12;i++)
Byte_Program(DATA_FLASH_START_ADDRESS + 1 + i,&ZeroPointCorrection_Array);
}//if ( crcData == tmp_crc )
}//void askComm0Modbus(void)
unsigned short crc16(unsigned char *puchMsg, unsigned int usDataLen) 这个是CRC16校验码的生成函数,第一个入口参数是消息侦的地址,第二个入口参数是消息的字节数。返回值是16位的校验码,在实际使用这个校验码时一定要注意,标准的工业modbus规定,最后的两个字节的CRC码是高低倒置的,即低字节在前,高字节在后,所以你得把这个返回值再处理一下。
说一下CRC校验,如果你第一个参数传入的消息侦没有最后两个字节的CRC码,那这个函数的返回值就是要生成的CRC码。如果你传入的消息侦有最后的两字节的CRC码,那么这个函数的返回值就是零。
void askComm0Modbus(void) 这个函数就是解析协议中的命令并执行动作。有注释应该不难理解就不多费吐沫了。 |
