发表于 2014-2-28 15:41:28
# If this option is given, pppd will send an LCP echo-request frame to
# the peer every n seconds. Under Linux, the echo-request is sent when
# no packets have been received from the peer for n seconds. Normally
# the peer should respond to the echo-request by sending an echo-reply.
# This option can be used with the lcp-echo-failure option to detect
# that the peer is no longer connected.
#lcp-echo-interval <n>
# If this option is given, pppd will presume the peer to be dead if n
# LCP echo-requests are sent without receiving a valid LCP echo-reply.
# If this happens, pppd will terminate the connection. Use of this
# option requires a non-zero value for the lcp-echo-interval parameter.
# This option can be used to enable pppd to terminate after the physical
# connection has been broken (e.g., the modem has hung up) in
# situations where no hardware modem control lines are available.
#lcp-echo-failure <n>
你房东的ROS/WayOS的PPPoE不标准,也许是中过招,防护开得太狠了。 |
