HI,各位大侠,我在使用华为EM770W模块,使用中国移动神州行大众卡做GPRS拔号,做100次拔号测试,会有几次出现拔号时长非常长的情况,下面是详说:
1. CPU imx28 454M, 128M DDR2, 128M Nand
2. linux 2.6.35.3
3. pppd 2.4.4
chap-secret及pap-secrets 均为
card * card *
gprs 文件内容为
debug
noauth
hide-password
/dev/ttyUSB0
115200
nocrtscts
modem
nodetach
usepeerdns
noipdefault
defaultroute
user "card"
password "card"
0.0.0.0:0.0.0.0
ipcp-accept-local
ipcp-accept-remote
#lcp-echo-failure 12
#lcp-echo-interval 3
noccp
novj
novjccomp
persist
connect '/sbin/chat -s -v -f /etc/ppp/peers/gprs-chat-connect'
disconnect '/sbin/chat -s -v -f /etc/ppp/peers/gprs-chat-disconnect'
gprs-chat-connect 内容为
TIMEOUT 30
ECHO ON
ABORT '\nBUSY\r'
ABORT '\nERROR\r'
ABORT '\nNO ANSWER\r'
ABORT '\nNO CARRIER\r'
ABORT '\nNO DIALTONE\r'
TIMEOUT 5
'' AT
OK ATE0
TIMEOUT 60
SAY "Press CTRL-C to break the connection process.\n"
OK AT+CGREG=1
OK AT+CGATT=1
#OK AT+CGQMIN=1,0,0,0,0,31
#OK AT+CGACT=1,1
OK AT+CGDCONT=1,"IP","CMNET"
OK ATDT*99***1#
SAY "Waiting for connect...\n"
TIMEOUT 60
CONNECT ''
SAY "Connect Success!\n"
100次启动中有80次是很正常
有10来次,在 AT+CGATT=1 命令发出后无应答,超时后,脚本自动重拔又能连上
有几次是如下现象:
abort on (\nBUSY\r)
abort on (\nERROR\r)
abort on (\nNO ANSWER\r)
abort on (\nNO CARRIER\r)
abort on (\nNO DIALTONE\r)
timeout set to 5 seconds
send (AT^M)
expect (OK)
^M
OKOK
-- got it
send (ATE0^M)
Main power failed!
timeout set to 60 seconds
expect (OK)
^M
^M
OKOK
-- got it
send (AT+CGREG=1^M)
expect (OK)
^M
^M
OKOK
-- got it
send (AT+CGATT=1^M)
Main power failed!
expect (OK)
^M
^M
OKOK
-- got it
send (AT+CGDCONT=1,"IP","CMNET"^M)
Main power failed!
expect (OK)
^M
^M
OKOK
-- got it
send (ATDT*99***1#^M)
Main power failed!
expect (CONNECT)
^M
^M
CONNECTCONNECT
-- got it
send (^M)
Connect Success!
Serial connection established.
using channel 5
Using interface ppp0
Connect: ppp0 <--> /dev/ttyUSB0
sent [LCP ConfReq id=0x1 <asyncmap 0x0> <magic 0x6938dbd7> <pcomp> <accomp>]
rcvd [LCP ConfReq id=0x0 <asyncmap 0x0> <auth chap MD5> <magic 0xf6b0ba> <pcomp> <accomp>]
sent [LCP ConfAck id=0x0 <asyncmap 0x0> <auth chap MD5> <magic 0xf6b0ba> <pcomp> <accomp>]
rcvd [LCP ConfAck id=0x1 <asyncmap 0x0> <magic 0x6938dbd7> <pcomp> <accomp>]
rcvd [LCP DiscReq id=0x1 magic=0xf6b0ba]
rcvd [CHAP Challenge id=0x1 <ca87f89c482f9b80ee613d4c5c77e851>, name = "UMTS_CHAP_SRVR"]
sent [CHAP Response id=0x1 <27324f4b42680de69e36250a4c0d3c17>, name = "card"]
rcvd [CHAP Success id=0x1 ""]
CHAP authentication succeeded
sent [IPCP ConfReq id=0x1 <addr 0.0.0.0> <ms-dns1 0.0.0.0> <ms-dns3 0.0.0.0>]
rcvd [IPCP ConfNak id=0x1 <ms-dns1 10.11.12.13> <ms-dns3 10.11.12.14> <ms-wins 10.11.12.13> <ms-wins 10.11.12.14>]
sent [IPCP ConfReq id=0x2 <addr 0.0.0.0> <ms-dns1 10.11.12.13> <ms-dns3 10.11.12.14>]
rcvd [IPCP ConfNak id=0x2 <ms-dns1 10.11.12.13> <ms-dns3 10.11.12.14> <ms-wins 10.11.12.13> <ms-wins 10.11.12.14>]
sent [IPCP ConfReq id=0x3 <addr 0.0.0.0> <ms-dns1 10.11.12.13> <ms-dns3 10.11.12.14>]
rcvd [IPCP ConfNak id=0x3 <ms-dns1 10.11.12.13> <ms-dns3 10.11.12.14> <ms-wins 10.11.12.13> <ms-wins 10.11.12.14>]
sent [IPCP ConfReq id=0x4 <addr 0.0.0.0> <ms-dns1 10.11.12.13> <ms-dns3 10.11.12.14>]
rcvd [IPCP ConfNak id=0x4 <ms-dns1 10.11.12.13> <ms-dns3 10.11.12.14> <ms-wins 10.11.12.13> <ms-wins 10.11.12.14>]
sent [IPCP ConfReq id=0x5 <addr 0.0.0.0> <ms-dns1 10.11.12.13> <ms-dns3 10.11.12.14>]
rcvd [IPCP ConfNak id=0x5 <ms-dns1 10.11.12.13> <ms-dns3 10.11.12.14> <ms-wins 10.11.12.13> <ms-wins 10.11.12.14>]
sent [IPCP ConfReq id=0x6 <addr 0.0.0.0>]
rcvd [IPCP ConfNak id=0x6 <ms-dns1 10.11.12.13> <ms-dns3 10.11.12.14> <ms-wins 10.11.12.13> <ms-wins 10.11.12.14>]
sent [IPCP ConfReq id=0x7 <addr 0.0.0.0>]
rcvd [IPCP ConfNak id=0x7 <ms-dns1 10.11.12.13> <ms-dns3 10.11.12.14> <ms-wins 10.11.12.13> <ms-wins 10.11.12.14>]
sent [IPCP ConfReq id=0x8 <addr 0.0.0.0>]
rcvd [IPCP ConfNak id=0x8 <ms-dns1 10.11.12.13> <ms-dns3 10.11.12.14> <ms-wins 10.11.12.13> <ms-wins 10.11.12.14>]
sent [IPCP ConfReq id=0x9 <addr 0.0.0.0>]
rcvd [IPCP ConfNak id=0x9 <ms-dns1 10.11.12.13> <ms-dns3 10.11.12.14> <ms-wins 10.11.12.13> <ms-wins 10.11.12.14>]
sent [IPCP ConfReq id=0xa <addr 0.0.0.0>]
rcvd [IPCP ConfNak id=0xa <ms-dns1 10.11.12.13> <ms-dns3 10.11.12.14> <ms-wins 10.11.12.13> <ms-wins 10.11.12.14>]
sent [IPCP ConfReq id=0xb <addr 0.0.0.0>]
rcvd [IPCP ConfNak id=0xb <ms-dns1 10.11.12.13> <ms-dns3 10.11.12.14> <ms-wins 10.11.12.13> <ms-wins 10.11.12.14>]
sent [IPCP ConfReq id=0xc <addr 0.0.0.0>]
rcvd [IPCP ConfNak id=0xc <ms-dns1 10.11.12.13> <ms-dns3 10.11.12.14> <ms-wins 10.11.12.13> <ms-wins 10.11.12.14>]
sent [IPCP ConfReq id=0xd <addr 0.0.0.0>]
rcvd [IPCP ConfNak id=0xd <ms-dns1 10.11.12.13> <ms-dns3 10.11.12.14> <ms-wins 10.11.12.13> <ms-wins 10.11.12.14>]
sent [IPCP ConfReq id=0xe <addr 0.0.0.0>]
rcvd [IPCP ConfNak id=0xe <ms-dns1 10.11.12.13> <ms-dns3 10.11.12.14> <ms-wins 10.11.12.13> <ms-wins 10.11.12.14>]
sent [IPCP ConfReq id=0xf <addr 0.0.0.0>]
rcvd [IPCP ConfNak id=0xf <ms-dns1 10.11.12.13> <ms-dns3 10.11.12.14> <ms-wins 10.11.12.13> <ms-wins 10.11.12.14>]
sent [IPCP ConfReq id=0x10 <addr 0.0.0.0>]
....这样一直收发收发下去, 直接我另一监视脚本超时后把3G模块的电源断掉,杀掉pppd, 再上电,再拔号重来,有时候会长达1个多小时才能最终拔上号,
而且我的手机卡在我手机上使用gprs时也有出现过类似的情况。就是把安卓里面的"数据开关"打开,再打开浏览器,有时候,浏览器连不到网络,要关闭"数据开关"再打开,才行.
希望有经验的大侠们一起交流一下看,到底是什么原因。
