发表于 2014-7-1 15:24:16
Build G:\work-ghzn\DNER-07AV2.10\liciqi08 for device 18F45K22
Using driver g:\HI-TECH Software\PICC-18\9.80\bin\picc18.exe
Make: The target "G:\work-ghzn\DNER-07AV2.10\disp.p1" is out of date.
Executing: "g:\HI-TECH Software\PICC-18\9.80\bin\picc18.exe" --pass1 G:\work-ghzn\DNER-07AV2.10\disp.c -q --chip=18F45K22 -P --runtime=default,+clear,+init,-keep,-download,+stackwarn,-config,+clib,+plib --opt=default,+asm,-debug,-speed,+space,9 --warn=0 -N255 -D__DEBUG=1 -Blarge --double=32 --float=32 --cp=16 --addrqual=ignore -g --asmlist "--errformat=Error [%n] %f; %l.%c %s" "--msgformat=Advisory[%n] %s" "--warnformat=Warning [%n] %f; %l.%c %s"
Error [1348] G:\work-ghzn\DNER-07AV2.10\syslcq.h; 168.20 enum tag "_BOOL" redefined (from g:\HI-TECH Software\PICC-18\9.80\include\GenericTypeDefs.h:65)
Error [986] G:\work-ghzn\DNER-07AV2.10\syslcq.h; 168.22 enum member redeclared
Error [1098] G:\work-ghzn\DNER-07AV2.10\syslcq.h; 168.22 conflicting declarations for variable "FALSE" (g:\HI-TECH Software\PICC-18\9.80\include\GenericTypeDefs.h:65)
Error [986] G:\work-ghzn\DNER-07AV2.10\syslcq.h; 168.33 enum member redeclared
Error [1098] G:\work-ghzn\DNER-07AV2.10\syslcq.h; 168.33 conflicting declarations for variable "TRUE" (g:\HI-TECH Software\PICC-18\9.80\include\GenericTypeDefs.h:65)
Error [255] G:\work-ghzn\DNER-07AV2.10\disp.c; 271.13 not a member of the struct/union ""
Error [182] G:\work-ghzn\DNER-07AV2.10\disp.c; 271.18 illegal conversion between types
int -> union S1225
Error [255] G:\work-ghzn\DNER-07AV2.10\disp.c; 970.18 not a member of the struct/union ""
Error [182] G:\work-ghzn\DNER-07AV2.10\disp.c; 970.18 illegal conversion between types
union S1225 -> unsigned char
Error [181] G:\work-ghzn\DNER-07AV2.10\disp.c; 970.18 non-scalar types can't be converted to other types
Error [255] G:\work-ghzn\DNER-07AV2.10\disp.c; 994.18 not a member of the struct/union ""
Error [182] G:\work-ghzn\DNER-07AV2.10\disp.c; 994.18 illegal conversion between types
Error [181] G:\work-ghzn\DNER-07AV2.10\disp.c; 994.18 non-scalar types can't be converted to other types
Make: The target "G:\work-ghzn\DNER-07AV2.10\keyrom.p1" is out of date.
Executing: "g:\HI-TECH Software\PICC-18\9.80\bin\picc18.exe" --pass1 G:\work-ghzn\DNER-07AV2.10\keyrom.c -q --chip=18F45K22 -P --runtime=default,+clear,+init,-keep,-download,+stackwarn,-config,+clib,+plib --opt=default,+asm,-debug,-speed,+space,9 --warn=0 -N255 -D__DEBUG=1 -Blarge --double=32 --float=32 --cp=16 --addrqual=ignore -g --asmlist "--errformat=Error [%n] %f; %l.%c %s" "--msgformat=Advisory[%n] %s" "--warnformat=Warning [%n] %f; %l.%c %s"
Error [255] G:\work-ghzn\DNER-07AV2.10\keyrom.c; 60.11 not a member of the struct/union ""
Error [182] G:\work-ghzn\DNER-07AV2.10\keyrom.c; 60.16 illegal conversion between types
int -> union S1225
Make: The target "G:\work-ghzn\DNER-07AV2.10\main.p1" is out of date.
Executing: "g:\HI-TECH Software\PICC-18\9.80\bin\picc18.exe" --pass1 G:\work-ghzn\DNER-07AV2.10\main.c -q --chip=18F45K22 -P --runtime=default,+clear,+init,-keep,-download,+stackwarn,-config,+clib,+plib --opt=default,+asm,-debug,-speed,+space,9 --warn=0 -N255 -D__DEBUG=1 -Blarge --double=32 --float=32 --cp=16 --addrqual=ignore -g --asmlist "--errformat=Error [%n] %f; %l.%c %s" "--msgformat=Advisory[%n] %s" "--warnformat=Warning [%n] %f; %l.%c %s"
Make: The target "G:\work-ghzn\DNER-07AV2.10\msccom.p1" is out of date.
Executing: "g:\HI-TECH Software\PICC-18\9.80\bin\picc18.exe" --pass1 G:\work-ghzn\DNER-07AV2.10\msccom.c -q --chip=18F45K22 -P --runtime=default,+clear,+init,-keep,-download,+stackwarn,-config,+clib,+plib --opt=default,+asm,-debug,-speed,+space,9 --warn=0 -N255 -D__DEBUG=1 -Blarge --double=32 --float=32 --cp=16 --addrqual=ignore -g --asmlist "--errformat=Error [%n] %f; %l.%c %s" "--msgformat=Advisory[%n] %s" "--warnformat=Warning [%n] %f; %l.%c %s"
Make: The target "G:\work-ghzn\DNER-07AV2.10\subdeal.p1" is out of date.
Executing: "g:\HI-TECH Software\PICC-18\9.80\bin\picc18.exe" --pass1 G:\work-ghzn\DNER-07AV2.10\subdeal.c -q --chip=18F45K22 -P --runtime=default,+clear,+init,-keep,-download,+stackwarn,-config,+clib,+plib --opt=default,+asm,-debug,-speed,+space,9 --warn=0 -N255 -D__DEBUG=1 -Blarge --double=32 --float=32 --cp=16 --addrqual=ignore -g --asmlist "--errformat=Error [%n] %f; %l.%c %s" "--msgformat=Advisory[%n] %s" "--warnformat=Warning [%n] %f; %l.%c %s"
Error [255] G:\work-ghzn\DNER-07AV2.10\subdeal.c; 152.11 not a member of the struct/union ""
Error [182] G:\work-ghzn\DNER-07AV2.10\subdeal.c; 152.13 illegal conversion between types
int -> union S1225
Make: The target "G:\work-ghzn\DNER-07AV2.10\tqcontrol.p1" is out of date.
Executing: "g:\HI-TECH Software\PICC-18\9.80\bin\picc18.exe" --pass1 G:\work-ghzn\DNER-07AV2.10\tqcontrol.c -q --chip=18F45K22 -P --runtime=default,+clear,+init,-keep,-download,+stackwarn,-config,+clib,+plib --opt=default,+asm,-debug,-speed,+space,9 --warn=0 -N255 -D__DEBUG=1 -Blarge --double=32 --float=32 --cp=16 --addrqual=ignore -g --asmlist "--errformat=Error [%n] %f; %l.%c %s" "--msgformat=Advisory[%n] %s" "--warnformat=Warning [%n] %f; %l.%c %s"
********** Build failed! **********
请问大师,这个错误时哪里没有设置好? |
