发表于 2014-8-5 17:16:27
大神,使用ubuntu9.04 ltib能安装上了,使用默认的./ltib -m config 没有问题,只是编译官网下载的sdk的时候,出错。
我们在./ltib 时增加了一些 Toolchain component options ---> 选项,然后就出现了下面的问题:
+ set -e
+ '[' -n y ']'
+ '[' XTOOL = CSL -a -d /opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro-toolchain/arm-none-linux-gnueabi/include/c++ ']'
+ '[' XTOOL = UCLIBC-SYSROOT ']'
+ i=
+ cp -a /opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro-toolchain//include/c++ /home/changjy/imx6/ltib/ltib/tmp/base_libs//opt/freescale/rootfs/arm/usr/include
cp: cannot stat `/opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro-toolchain//include/c++': No such file or directory
error: Bad exit status from /home/changjy/imx6/ltib/ltib/tmp/rpm-tmp.15560 (%install)
RPM build errors:
Build time for base_libs: 8 seconds
Failed building base_libs
f_buildrpms() returned an error, exiting
traceback:
main:572
Started: Tue Aug 5 01:18:31 2014
Ended: Tue Aug 5 01:23:27 2014
Elapsed: 296 seconds
These packages failed to build:
base_libs
Build Failed
Exiting on error or interrupt
请问这个问题如何解决?另外,为什么编译官网下载的sdk时,会有各种链接问题。 |
