FreeRTOS发现一个问题,重复地删除了一个任务,会死机.看了 void vTaskDelete( xTaskHandle pxTaskToDelete )这个函数,是不是因为空闲任务来不及释放空间?
/* Remove task from the ready list and place in the termination list.
This will stop the task from be scheduled. The idle task will check
the termination list and free up any memory allocated by the
scheduler for the TCB and stack. */
vListRemove( &( pxTCB->xGenericListItem ) );
/* Is the task waiting on an event also? */
if( pxTCB->xEventListItem.pvContainer != NULL )
vListRemove( &( pxTCB->xEventListItem ) );
vListInsertEnd( ( xList * ) &xTasksWaitingTermination, &( pxTCB->xGenericListItem ) );
/* Increment the ucTasksDeleted variable so the idle task knows
there is a task that has been deleted and that it should therefore
check the xTasksWaitingTermination list. */
++uxTasksDeleted;
/* Increment the uxTaskNumberVariable also so kernel aware debuggers
can detect that the task lists need re-generating. */
uxTaskNumber++;
