发表于 2014-10-11 09:21:34
非常感谢qlb1234的回复,我还有几个疑问:
1. 打開一箇命令行窗口 这个操作是在windows下的cmd.exe命令行,而不是linux下的终端命令行吧?
2. 如何将將MPLAB X IDE自帶的GNU工具的路徑和編譯器的路徑加入到環境變量PATH裏?
3. 如果我在MPLAB X IDE 里编译一个项目会出现这样的以下提示,我需要用到的命令是哪些呢?
make -f nbproject/Makefile-default.mk SUBPROJECTS= .build-conf
make[1]: Entering directory `F:/12F1822_I2C_EEPROM/12F1822_I2C_EEPROM.X'
make -f nbproject/Makefile-default.mk dist/default/production/12F1822_I2C_EEPROM.X.production.hex
make[2]: Entering directory `F:/12F1822_I2C_EEPROM/12F1822_I2C_EEPROM.X'
"C:\Program Files\Microchip\xc8\v1.33\bin\xc8.exe" --pass1 --chip=12F1822 -Q -G --asmlist --double=24 --float=24 --opt=default,+asm,-asmfile,+speed,-space,-debug --addrqual=ignore --mode=free -P -N255 --warn=0 --summary=default,-psect,-class,+mem,-hex,-file --output=default,-inhx032 --runtime=default,+clear,+init,-keep,-no_startup,+osccal,-resetbits,-download,-stackcall,+clib --output=-mcof,+elf "--errformat=%%f:%%l: error: %%s" "--warnformat=%%f:%%l: warning: %%s" "--msgformat=%%f:%%l: advisory: %%s" -obuild/default/production/_ext/1472/12F1822_I2C_EEPROM_Example.p1 ../12F1822_I2C_EEPROM_Example.c
"C:\Program Files\Microchip\xc8\v1.33\bin\xc8.exe" --chip=12F1822 -G --asmlist -mdist/default/production/12F1822_I2C_EEPROM.X.production.map --double=24 --float=24 --opt=default,+asm,-asmfile,+speed,-space,-debug --addrqual=ignore --mode=free -P -N255 --warn=0 --summary=default,-psect,-class,+mem,-hex,-file --output=default,-inhx032 --runtime=default,+clear,+init,-keep,-no_startup,+osccal,-resetbits,-download,-stackcall,+clib --output=-mcof,+elf "--errformat=%%f:%%l: error: %%s" "--warnformat=%%f:%%l: warning: %%s" "--msgformat=%%f:%%l: advisory: %%s" -odist/default/production/12F1822_I2C_EEPROM.X.production.elf build/default/production/_ext/1472/12F1822_I2C_EEPROM_Example.p1
Microchip MPLAB XC8 C Compiler (Free Mode) V1.33
Part Support Version: 1.33 (A)
Copyright (C) 2014 Microchip Technology Inc.
License type: Node Configuration
:: warning: Omniscient Code Generation not available in Free mode
Memory Summary:
Program space used 1C9h ( 457) of 800h words ( 22.3%)
Data space used 3Ch ( 60) of 80h bytes ( 46.9%)
EEPROM space used 0h ( 0) of 100h bytes ( 0.0%)
Data stack space used 0h ( 0) of 3Ch bytes ( 0.0%)
Configuration bits used 2h ( 2) of 2h words (100.0%)
ID Location space used 0h ( 0) of 4h bytes ( 0.0%)
Running this compiler in PRO mode, with Omniscient Code Generation enabled,
produces code which is typically 40% smaller than in Free mode.
The MPLAB XC8 PRO compiler output for this code could be 182 words smaller.
See http://microchip.com for more information.
make[2]: Leaving directory `F:/12F1822_I2C_EEPROM/12F1822_I2C_EEPROM.X'
make[1]: Leaving directory `F:/12F1822_I2C_EEPROM/12F1822_I2C_EEPROM.X'
BUILD SUCCESSFUL (total time: 4s)
Loading code from F:/12F1822_I2C_EEPROM/12F1822_I2C_EEPROM.X/dist/default/production/12F1822_I2C_EEPROM.X.production.hex...
Loading symbols from F:/12F1822_I2C_EEPROM/12F1822_I2C_EEPROM.X/dist/default/production/12F1822_I2C_EEPROM.X.production.elf...
Loading completed
