发表于 2014-11-21 13:07:42
在一网站看到的配置代码,不知道有无问题。
PIC24 clock setup
config word FOSCSEL selects which oscillator.
each oscillator option can be with or without PLL (which multiplies by 4)
The builtin RC oscillator is 8mhz, so
FNOSC_FRC is 8mhz, and FNOSC_FRCPLL is 32mhz.
THEN, there's a postscaler. CLKDIVbits.RCDIV sets the divide-by. 0 means
don't.
NOTE: The default setting of the postscaler is DIVIDE BY TWO. If you don't
want it to halve the clock freq, you have to set CLKDIVbits.RCDIV=0 early
in the program.
THEN, whatever the output of all the above, is divided by two.
For example
_FOSCSEL(FNOSC_FRC)
CLKDIVbits.RCDIV = 0;
gives the builtin 8mhz oscillator, not divided by a postscaler, and
finally divided by two = 4MHz.
_FOSCSEL(FNOSC_FRCPLL)
gives builtin 8mhz, times 4 (pll) = 32MHz, divided by 2 = 16 MHz.
UART BAUD RATE SETTINGS.
Builtin RC oscillator @ 8MHZ, PLL enabled, CLKDIV=0 = system clock at 16MHz
U1MODEbits.BRGH = 1;
9600bps: U1BRG=416
19200bps: U1BRG=207
38400bps: U1BRG=103
57600bps: U1BRG=70
115200bps: U1BRG=34 |
