Working GPIO input interrupt demo for FRDM-K22F with Kenitis SDK V1.1.0
The following (after the "- - - - - -") is debugged code for showing SW2, and SW3 pressed or not on the FRDM-K22F module. It is based on Kenitis SDK V1.1.0. It is built with Keil V5.13 and downloaded with JLINK SWD mode.
#include <string.h>
#include <stdio.h>
#include "fsl_uart_hal.h"
#include "gpio_pins.h"
#include "fsl_clock_manager.h"
#include "fsl_port_hal.h"
#include "board.h"
volatile uint8_t switch_2_isr_entered = 0; // Variable to indicate that the SW2
volatile uint8_t switch_3_isr_entered = 0; // Variable to indicate that the SW3
gpio_input_pin_user_config_t Sw2Pins =
.pinName = kGpioSW1,
.config.isPullEnable = false,
.config.pullSelect = kPortPullUp,
.config.isPassiveFilterEnabled = false,
.config.interrupt = kPortIntFallingEdge,
gpio_input_pin_user_config_t Sw3Pins =
.pinName = kGpioSW2,
int main(void)
// init the hardware board
hardware_init();
// init the debug uart
dbg_uart_init();
/* PB17(Sw3Pin),PC1(Sw2Pin) as GPIO */
PORT_HAL_SetMuxMode(PORTB_BASE,17u,kPortMuxAsGpio);
PORT_HAL_SetMuxMode(PORTC_BASE,0u,kPortMuxAsGpio);
// Initialize the GPIO pins
GPIO_DRV_InputPinInit(&Sw2Pins);
GPIO_DRV_InputPinInit(&Sw3Pins);
printf("\nHello World!\n");
for (;;)
if(1==switch_2_isr_entered)
printf("\nSW2 Pressed!\n");
if(1==switch_3_isr_entered)
printf("\nSW3 Pressed!\n");
return 0;
Prepare the Demo
1. Connect a USB cable between the PC host and the OpenSDA USB port on FRDM-K22F.
2. Open a serial terminal with these settings:
• 115200 baud rate
• 8 data bits
• No parity
• One stop bit
• No flow control
3. Download the program to FRDM-K22F board.
4. Either press the reset button on FRDM-K22F to begin running the demo.
5. Press SW2 switch or SW3 switch to check the result.
Here is output.
Attention: My KSDK V1.1.0 path is D:\KSDK_1.1.0. If your KSDK V1.1.0 path is not agree with me, the demo will not work until the configuation in project options->C/C++->Include path,Linker->Scatter File, Linker->Misc controls is correct.
