环境:VM 10.0.1 build-1379776
Linux: Ubuntu 10.04
问题:Build LTIB通不过
lucid@ubuntu:~/freescale/ltib$ ./ltib -m config
Installing host support packages.
This only needs to be done once per host, but may take up to
an hour to complete ...
If an error occurs, a log file with the full output may be found in:
/home/lucid/freescale/ltib/host_config.log
Exiting on error or interrupt
下面是host_config.log:
Build path taken because: directory build, no prebuilt rpm,
Cowardly refusing to clobber existing directory:
/opt/freescale/ltib/usr/src/rpm/BUILD/flex-2.5.37
Remove this by hand if you really want to rebuild this package from scratch
Died at ./ltib line 1392.
traceback:
main::build_host_rpms:1392
main::host_checks:1447
main:554
