请教论坛内高手,请教E8A写M30281FATHP报错。
具体情况是,卖给客户一个正品的E8A(从瑞萨指定代理商那里买的),客户用E8A开发M30281FATHP片子,结果说写入的时候,总是报错。
在FDT环境下,错误信息如下:
Flash Development Toolkit and flash programming components
are provided without support
OS: Windows XP [Admin]
E8/E8a/E1 target power will be set to ON at 5.0V
Clock Frequency (External) = N/A, Clock Mode = N/A, CKM = N/A, and CKP = N/A
Connecting to device 'M30281FA' on 'E8a'
Configuration:
'BOOT Mode' connection - using emulated interface
Opening port 'E8a' ...
Checking for E8/E8a update...
Adaptor checksum OK
Processing Data file :'c:\program files\renesas\fdt4.07\ADPFiles\E8-Rel-Img-a.mot'
Adaptor version number OK
(current E8/E8a Bootstub (Level 0) version = 1.00.00.000, FDT holds version 1.00.00.000, FDT requires version 1.00.XX.XXX)
Adaptor version type OK
(current type = E8aEMULATOR)
(current E8/E8a Adaptor Software (Level 1) version = 1.13.00.000, FDT holds version 1.13.00.000, FDT requires version 1.13.XX.XXX)
Error No 17508: Check target connection
Error No 15024: Boot failed
Attempting to switch off E8/E8a target power...
Target is not powered
我之前只是开发ATMEL51等单片机,瑞萨的芯片和开发环境一直没有接触,卖了个E8A,客户一直要我给解决问题, 请教高手!
