回复: 16
STM32F407采用定时器触发DMA以SPI收发方式访问ADS8329
发表于 2015-8-19 20:12:38 | 显示全部楼层 |阅读模式
最近用到STM32F407通过SPI读取ADS8329,想用定时器触发DMA以SPI读取AD值,在网上找了一圈,国内国外网站找遍了都没有类似的例子,就自己写了一个,发上来希望大家指正。
ADS8329的最高采样率是1Msps,
CONVST - PE8 - TIM1_CH1N
CS - PE12 - TIM1_CH3N
SCLK - PA5
SDO - PA6
SDI - PA7
/**********************程序开始**********************/
/*************本程序实现4个半字循环刷新****************/
u16 SPI1_Rx_Buff[4];   //DMA指向内存地址,存放SPI接收数据
u16 SPI1_Tx_Buff[4]={0xd000,0xd000,0xd000,0xd000}; //存放SPI发送数据
void SPI1_Init(void)
        GPIO_InitTypeDef  GPIO_InitStructure;
        SPI_InitTypeDef  SPI_InitStructure;
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA,ENABLE);//使能GPIOA时钟
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1,ENABLE);//使能SPI1时钟
        //PA5,6,7初始化设置
        GPIO_InitStructure.GPIO_Pin =GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;//PA5~7复用功能输出
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;//复用功能
        GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;//推挽输出
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;//100MHz
        GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_UP;//上拉
        GPIO_Init(GPIOA, &GPIO_InitStructure);//初始化
        GPIO_PinAFConfig(GPIOA, GPIO_PinSource5, GPIO_AF_SPI1);//PA5复用为 SPI1
        GPIO_PinAFConfig(GPIOA, GPIO_PinSource6, GPIO_AF_SPI1);//PA6复用为 SPI1
        GPIO_PinAFConfig(GPIOA, GPIO_PinSource7, GPIO_AF_SPI1);//PA7复用为 SPI1
        //这里只针对SPI口初始化
        RCC_APB2PeriphResetCmd(RCC_APB2Periph_SPI1,ENABLE);//复位SPI1
        RCC_APB2PeriphResetCmd(RCC_APB2Periph_SPI1,DISABLE);//停止复位SPI1
        SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
        SPI_InitStructure.SPI_Mode = SPI_Mode_Master;                //为主SPI
        SPI_InitStructure.SPI_DataSize = SPI_DataSize_16b;                //SPI发送接收16位帧结构
        SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;                //串行同步时钟的空闲状态为低电平
        SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;        //串行同步时钟的第二个跳变沿(上升或下降)数据被采样
        SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;                //NSS信号由软件管理
        SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_4;  //波特率预分频值为4(21MHz)
        SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;        //数据从MSB位开始
        SPI_InitStructure.SPI_CRCPolynomial = 7;        //CRC值计算的多项式
        SPI_Init(SPI1, &SPI_InitStructure);
        SPI_Cmd(SPI1, ENABLE); //使能SPI外设
void DMA_Config(void)
        DMA_InitTypeDef DMA_InitStructure;
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2, ENABLE);
        /* DMA disable*/
        DMA_Cmd(DMA2_Stream2, DISABLE);
        DMA_Cmd(DMA2_Stream3, DISABLE);
        DMA_DeInit(DMA2_Stream2);
        DMA_DeInit(DMA2_Stream3);
        //   SPI1 RX DMA 配置  Stream2
        DMA_InitStructure.DMA_Channel = DMA_Channel_6;
        DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)&SPI1->DR;         //指定DMA的外设基地址为SPI1的数据地址
        DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)SPI1_Rx_Buff;         //指定DMA的内存基地址
        DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;                 //DMA传输方向为读外设 写到内存
        DMA_InitStructure.DMA_BufferSize = 4;//DataSize;                            //传输数量(0-65535,不能为0)
        DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;        //失能外设地址增长
        DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;                 //使能内存地址增长 免去FOR循环
        DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;        //PSIZE=16bit
        DMA_InitStructure.DMA_MemoryDataSize = DMA_PeripheralDataSize_HalfWord;        //MSIZE=16bit
        DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;//DMA_Mode_Normal;//       //DMA模式为非循环模式,非循环模式只进行单次传输。
        DMA_InitStructure.DMA_Priority = DMA_Priority_High;                     //优先权为高
        DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;                  //失能FIFO模式
        DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;       //FIFO的阀值为半满
        DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;                    //内存突发传输为单一
        DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;     //外设突发传输为单一
        DMA_Init(DMA2_Stream2, &DMA_InitStructure);                             //初始化DMA2_Stream2
        //DMA_ITConfig(DMA2_Stream2, DMA_IT_TC, ENABLE);//使能传输完成中断
        //   SPI1 TX DMA 配置   Stream3
        DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)SPI1_Tx_Buff;         //指定DMA的内存基地址
        DMA_InitStructure.DMA_DIR = DMA_DIR_MemoryToPeripheral;                 //DMA传输方向为读内存,写外设
        DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;                 //失能内存地址增长
        DMA_InitStructure.DMA_Priority = DMA_Priority_Medium ;                  //优先权为中等
        DMA_Init(DMA2_Stream3, &DMA_InitStructure);                             //初始化DMA2_Stream3
        //DMA_ITConfig(DMA2_Stream3, DMA_IT_TC, ENABLE);                        //因为是发送虚拟数据。不需要中断
        /* DMA enable*/
        DMA_Cmd(DMA2_Stream2, ENABLE);
        DMA_Cmd(DMA2_Stream3, ENABLE);
void TIM1_Init(u16 period)//period设置24以1MHz采样,period设置240以100KHz采样,period设置2400以10KHz采样,period设置24000以1KHz采样,
        TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
        TIM_OCInitTypeDef TIM_OCInitStructure;
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOE, ENABLE);//使能GPIOE时钟
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE);
        GPIO_InitStructure.GPIO_Pin=GPIO_Pin_8 |GPIO_Pin_9 | GPIO_Pin_12 |GPIO_Pin_13;
        GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AF;//模式必须为复用
        //GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
        GPIO_InitStructure.GPIO_Speed=GPIO_Speed_100MHz;//频率为快速
        GPIO_InitStructure.GPIO_PuPd=GPIO_PuPd_UP;
        GPIO_Init(GPIOE, &GPIO_InitStructure);
        GPIO_PinAFConfig(GPIOE, GPIO_PinSource8, GPIO_AF_TIM1);//PE8 作为 AD的/convst信号
        GPIO_PinAFConfig(GPIOE, GPIO_PinSource9, GPIO_AF_TIM1);
        GPIO_PinAFConfig(GPIOE, GPIO_PinSource12, GPIO_AF_TIM1);//PE12 作为 AD的/CS信号
        GPIO_PinAFConfig(GPIOE, GPIO_PinSource13, GPIO_AF_TIM1);
        //初始化
        TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1; //死区控制用。
        TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;  //向上计数
        TIM_TimeBaseStructure.TIM_Prescaler = 7 - 1;   //Timer clock = 168M /(TIM_Prescaler+1) = 24M
        TIM_TimeBaseStructure.TIM_RepetitionCounter = 4;
        TIM_TimeBaseStructure.TIM_Period = period - 1;
        TIM_TimeBaseInit(TIM1,&TIM_TimeBaseStructure);
        //配置输出比较,产生PWM方波
        TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;//PWM1为正常占空比模式,PWM2为反极性模式
        TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
        TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;
        TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
        TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High;//输出反相 TIM_OCNPolarity_Low;//输出同相,
        TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
        TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCNIdleState_Reset;
        TIM_OCInitStructure.TIM_Pulse = 1;//ccr1;//PE8 作为 AD的/convst信号
        TIM_OC1Init(TIM1,&TIM_OCInitStructure);//触发DMA2_Stream3 channel6
        TIM_OCInitStructure.TIM_Pulse = 1;//ccr2;
        TIM_OC2Init(TIM1,&TIM_OCInitStructure);//触发DMA2_Stream2 channel6
        TIM_OCInitStructure.TIM_Pulse = 23;//ccr3;//PE12 作为 AD的/CS信号
        TIM_OC3Init(TIM1,&TIM_OCInitStructure);
        TIM_Cmd(TIM1,ENABLE);
        TIM_CtrlPWMOutputs(TIM1,ENABLE);
        /* TIM1 DMA 请求使能 */
        TIM_DMACmd(TIM1, TIM_DMA_CC1 | TIM_DMA_CC2, ENABLE);//\\
int main(void)
        SPI1_Init();
        DMA_Config();
        TIM1_Init(24);//1MHz
        //PWM_Init(240);//100KHz
        //PWM_Init(2400);//10KHz
        //PWM_Init(24000);//1KHz
                //CPU很闲
/**********************程序结束**********************/
发表于 2015-8-19 22:55:21 | 显示全部楼层
好东西  mark
出0入16汤圆
发表于 2015-8-20 08:23:58 | 显示全部楼层
只要配置好了,理论上没有问题!
发表于 2015-11-5 17:23:21 | 显示全部楼层
收藏多谢!
发表于 2016-3-8 19:12:46 | 显示全部楼层
liuruoshui 发表于 2015-8-20 08:23
只要配置好了,理论上没有问题!
楼主可以用么,我感觉不行啊,最近也在调‘
 楼主| 发表于 2016-4-7 14:14:01 | 显示全部楼层
绝对可以!
出10入95汤圆
发表于 2016-4-13 19:41:20 | 显示全部楼层
不错,多谢分享!!!
发表于 2016-10-17 21:04:08 | 显示全部楼层
为什么不配置spi_cs引脚?
发表于 2016-10-17 21:04:59 | 显示全部楼层
为什么不配置SPI-CS引脚
 楼主| 发表于 2016-10-21 20:46:18 | 显示全部楼层
guo407214944 发表于 2016-10-17 21:04
为什么不配置SPI-CS引脚
407作主设备,ADS8329为从设备,CONVST和CS时序要配合起来一起工作,407作从设备才需要配置SPI-CS引脚
发表于 2018-7-19 09:08:50 | 显示全部楼层
好东西,MARK
发表于 2018-8-9 11:36:45 | 显示全部楼层
Mark!!!
发表于 2018-8-9 17:04:47 来自手机 | 显示全部楼层
楼主的想法很不错,只是这种做法只适合16位及以下adc, DMA_InitStructure.DMA_BufferSize = 4;//DataSize;这里我想楼主是一次想传输4个16bit的数据,但是实际上每次dma只传输一个16bit.如果你把循环模式取消的话就会发现spi在四个定时器周期后就停止了,每个定时器周期只传输了一个16bit.我想读取一个24位的adc,把spi设置成8位,dma传输数量为4,期待一个dma事件它能传输32bit数据,但是无论我怎么折腾,每个dma时间还是只传输8位数据,即使开启和设置fifo及brust 模式也一样。Google 了全网也没能找到解决办法的,晚点我开个帖子来求大神们集思广益
出0入24汤圆
发表于 2018-8-9 18:17:32 | 显示全部楼层
407的SPI只有一个数据深度的buffer,定时器触发DMA传输数据到SPI存在问题
SPI 16bit模式,21M时钟,发送完成一个数据需要 168/21*16 = 128主时钟周期;
DMA传输一次数据,在F1xx系列上面需要10个主时钟周期左右,F4系列上面的时间只会比F1的短,不会更长,也就是说DMA传输四个数据的时间小于SPI发送一个数据的时间;
DMA传输第一个数据,SPI移位寄存器立刻开始工作,发动缓冲区变为空;
DMA传输第二个数据,SPI移位寄存器尚未发送完成,DMA的数据会存放在发送缓冲区中;
DMA传输第三个数据,SPI移位寄存器依然未发送完成,发送缓冲区中会被新的数据覆盖;
DMA传输第四个数据,同上;
实际只会发送两个数据,第一个和第四个(尚未经过逻辑分析仪抓波形验证)
解决办法是由SPI触发DMA传输,保证DMA传输给SPI的每一个数据都被移位寄存器发送走了;
或者使用SPI的TXFIFO,注意是要SPI自己的FIFO,DMA的FIFO没用。带有FIFO的SPI,某些系列有,某些系列没有,这个很乱,确认的是F1,F4没有,F0,F3,F7有
发表于 2018-8-10 04:08:13 来自手机 | 显示全部楼层
SPI 16bit模式,21M时钟,发送完 ...
非常感谢你专业的解答,我刚才尝试过各种组合设置,证明你的说法。我用的STM32f429 ,那个discovery 板子,spi跑的45m.做了一些记录和抓了一些波形,等周末整理了之后放上来。
另外我很好奇如果用SPI_TX 事件触发spi发送,这样为什么不会一直循环下去呢?我尝试先用TIM触发spi1发送,另外一路dma数据流y配置为spi1_tx触发,他的外设也配置为spi1,但实际上这个数据流 y也是发送了一次就停止了,它没能让自己处于自我循环的模式,不知道为什么。
顺便请问下是不是所以的f7都含有spi fifo 呢?刚才去ST网站上随便找了几个DS看了下都没有写,但是从另外一个F7系列的简介上看到了包含3B的发送fifo和4B的接收fifo,因此就迷惑了,不知道具体哪款有。如果您知道的话请随便列举几个常见的型号,谢谢。
出0入24汤圆
发表于 2018-8-10 11:46:57 | 显示全部楼层
aduecho 发表于 2018-8-10 04:08
非常感谢你专业的解答,我刚才尝试过各种组合设置,证明你的说法。我用的STM32f429 ,那个discovery 板子 ...
自我循环是个什么意思,想要实现TIM触发一次,SPI传输若干字节?
F7系列我是看到参考手册上面讲SPI的有FIFO,应该是F7全系列都是。收发各32bit,有点鸡肋,H7系列是16*8bit,好多了
GMT+8, 2024-5-29 13:32
