发表于 2015-8-22 23:33:30
这个使用了 SPI 接口, 可以参考一下。
混合模式,传送 Request 和 Data 时用 SPI, 传送 ACK 时用模拟的。
- // ARM SWD Mode Port Bit masks
- #if (HW_CAPABILITY&CAP_SWD_HW)
- #ifndef DATA_PORT
- #define DATA_PORT PTAD
- #define DATA_PORT_DDR PTADD
- #define DATA_PORT_PER PTAPE
- #endif
- // SWD data out pin
- #define SWD_OUT PTAD_PTAD2
- #define SWD_OUT_BIT (2) // Bit number!
- #define SWD_OUT_MASK (1<<SWD_OUT_BIT)
- #define SWD_OUT_PER PTAPE_PTAPE2
- #define SWD_OUT_DDR PTADD_PTADD2
- // SWD data out 3-state control
- #define SWD_OUT_EN PTAD_PTAD4
- #define SWD_OUT_EN_BIT (4) // Bit number!
- #define SWD_OUT_EN_MASK (1<<SWD_OUT_EN_BIT)
- #define SWD_OUT_EN_PER PTAPE_PTAPE4
- #define SWD_OUT_EN_DDR PTADD_PTADD4
- // Following assume pin already configured by SWD_LOW(),SWD_HIGH(),SWD_3STATE()
- #define SWD_ENABLE_ASM BCLR SWD_OUT_EN_BIT,DATA_PORT
- #define SWD_3STATE_ASM BSET SWD_OUT_EN_BIT,DATA_PORT
- #define SWD_LOW_ASM BCLR SWD_OUT_BIT,DATA_PORT
- #define SWD_HIGH_ASM BSET SWD_OUT_BIT,DATA_PORT
- #define SWD_DISABLE_ASM BCLR SWD_OUT_EN_BIT,DATA_PORT_DDR
- #define SWD_ENABLE_DRV_ASM BSET SWD_OUT_EN_BIT,DATA_PORT_DDR
- // Following configure pin & driver
- #define SWD_LOW() (SWD_OUT=0, SWD_OUT_DDR=1, SWD_OUT_EN=0, SWD_OUT_EN_DDR=1)
- #define SWD_HIGH() (SWD_OUT=1, SWD_OUT_DDR=1, SWD_OUT_EN=0, SWD_OUT_EN_DDR=1)
- #define SWD_3STATE() (SWD_OUT_EN=1, SWD_OUT_EN_DDR=1, SWD_OUT_DDR=1)
- #define SWD_DISABLE() (SWD_OUT_EN=1, SWD_OUT_EN_DDR=0, SWD_OUT_DDR=0) // PUPs
- // SWD data in pin
- #define SWD_IN PTAD_PTAD0
- #define SWD_IN_BIT (0) // Bit number!
- #define SWD_IN_MASK (1<<SWD_IN_BIT)
- #define SWD_IN_PER PTAPE_PTAPE0
- #define SWD_IN_DDR PTADD_PTADD0
- // SWCLK out pin
- #define SWCLK_OUT PTAD_PTAD3
- #define SWCLK_OUT_BIT (3) // Bit number!
- #define SWCLK_OUT_MASK (1<<SWCLK_OUT_BIT)
- #define SWCLK_OUT_PER PTAPE_PTAPE3
- #define SWCLK_OUT_DDR PTADD_PTADD3
- // SWCLK enable pin - controls buffer enable
- #define SWCLK_OUT_EN PTBD_PTBD1
- #define SWCLK_OUT_EN_BIT (1) // Bit number!
- #define SWCLK_OUT_EN_MASK (1<<SWCLK_OUT_EN_BIT)
- #define SWCLK_OUT_EN_PER PTBPE_PTBPE1
- #define SWCLK_OUT_EN_DDR PTBDD_PTBDD1
- // Following assume pin direction already set
- #define SWCLK_LOW_ASM BCLR SWCLK_OUT_BIT,DATA_PORT
- #define SWCLK_HIGH_ASM BSET SWCLK_OUT_BIT,DATA_PORT
- #define SWCLK_LOW() (SWCLK_OUT=0, SWCLK_OUT_DDR=1, SWCLK_OUT_EN=0, SWCLK_OUT_EN_DDR=1)
- #define SWCLK_HIGH() (SWCLK_OUT=1, SWCLK_OUT_DDR=1, SWCLK_OUT_EN=0, SWCLK_OUT_EN_DDR=1)
- #define SWCLK_3STATE() (SWCLK_OUT_EN=1, SWCLK_OUT_EN_DDR=1, SWCLK_OUT_DDR=1) // PUPs
- #define SWCLK_DISABLE() (SWCLK_OUT_EN=1, SWCLK_OUT_EN_DDR=0, SWCLK_OUT_DDR=0) // PUPs
- #endif // CAP_SWD
- * SWD.h
- * Created on: 04/08/2012
- * Author: PODonoghue
- #ifndef SWD_H_
- #define SWD_H_
- #include "Common.h"
- // Ack values displaced by offset introduced during read (left justified 8-bit value)
- #define SWD_ACK_OK (0x1<<5)
- #define SWD_ACK_WAIT (0x2<<5)
- #define SWD_ACK_FAULT (0x4<<5)
- #define SWD_ACK_PROTOCOL (0x7<<5)
- void swd_interfaceIdle(void);
- void swd_init(void);
- void swd_txIdle8(void);
- U8 swd_test(void);
- U8 swd_sendCommandWithWait(U8 command);
- U8 swd_connect(void);
- U8 swd_readReg(U8 command, U8 *data);
- U8 swd_writeReg(U8 command, const U8 *data);
- U8 swd_readAPReg(const U8 *address, U8 *buff);
- U8 swd_writeAPReg(const U8 *address, const U8 *buff);
- U8 swd_clearStickyError(void);
- U8 swd_abortAP(void);
- #endif /* SWD_H_ */
- /*! \file
- \brief ARM-SWD routines
- \verbatim
- USBDM
- Copyright (C) 2007 Peter O'Donoghue
- This program is free software; you can redistribute it and/or modify
- it under the terms of the GNU General Public License as published by
- the Free Software Foundation; either version 2 of the License, or
- (at your option) any later version.
- This program is distributed in the hope that it will be useful,
- but WITHOUT ANY WARRANTY; without even the implied warranty of
- MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
- GNU General Public License for more details.
- You should have received a copy of the GNU General Public License
- along with this program; if not, write to the Free Software
- Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
- \endverbatim
- Change History
- | 21 Feb 2014 | Fixed unbalanced stack in swd_sendCommandWithWait() V4.10.6.30
- | 10 Feb 2014 | Dramatically extended retry times to allow for slow clocks V4.10.6.20
- | 30 Aug 2012 | ARM-JTAG & ARM-SWD Changes V4.9.5
- \endverbatim
- #include "Configure.h"
- #include "Commands.h"
- #include "SWD.h"
- #include "BDM.h"
- #include "BDM_CF.h"
- #include "CmdProcessing.h"
- #include "BDMCommon.h"
- #include "SPI.h"
- #include "TargetDefines.h"
- #include "SWD.h"
- #if TARGET_CAPABILITY & CAP_ARM_SWD
- //! SPI Masks - Mask to enable SPI as master Tx
- #define SPIxC1_OFF (SPIxC1_MSTR_MASK) //!< SPI Masks - Mask to disable SPI
- #define SPIxC1_M_ON_TX (SPIxC1_SPE_MASK|SPIxC1_MSTR_MASK|SPIxC1_CPOL_MASK|SPIxC1_CPHA_MASK|SPIxC1_SSOE_MASK|SPIxC1_LSBFE_MASK)
- #define SPIxC1_M_ON_RX (SPIxC1_SPE_MASK|SPIxC1_MSTR_MASK|SPIxC1_CPOL_MASK) //!< SPI Masks - Mask to enable SPI as master Tx
- #define SPIxC2_M_8 (0) //!< SPI Masks - 8-bit mode
- #define SPIxC2_M_16 (SPIxC2_SPIMODE_MASK) //!< SPI Masks - 8-bit mode
- // Can't use enumerations in assembly code
- #define BDM_RC_OKx (0)
- #define BDM_RC_NO_CONNECTIONx (5)
- #define BDM_RC_ACK_TIMEOUTx (30)
- #define BDM_RC_ARM_PARITY_ERRORx (51)
- #define BDM_RC_ARM_FAULT_ERRORx (52)
- #define SWD_READ_IDCODE 0xA5 // (Park,Stop,Parity,A[32],R/W,AP/DP,Start) = 10100101
- // Masks for SWD_WR_DP_ABORT clear sticky
- #define SWD_DP_ABORT_CLEAR_STICKY_ERRORS_B3 0x1E
- // Masks for SWD_WR_DP_ABORT abort AP
- #define SWD_DP_ABORT_ABORT_AP_B3 0x01
- // Masks for SWD_RD_DP_STATUS
- #define SWD_RD_DP_STATUS_ANYERROR_B3 0xB2
- #pragma MESSAGE DISABLE C1404 // Disable warnings about missing return value
- #pragma MESSAGE DISABLE C5703 // Disable warnings about unused parameter
- //! Sets the SWD interface to an idle state
- //! RESET=3-state, SWCLK=High, SWDIO=3-state (SPI off)
- void swd_interfaceIdle(void) {
- #ifdef RESET_3STATE
- RESET_3STATE();
- #endif
- SWD_3STATE();
- SWCLK_HIGH();
- SPIC1 = SPIxC1_OFF;
- //! Initialise the SWD interface and sets it to an idle state
- //! @note This includes once-off initialisation such as PUPs etc
- void swd_init(void) {
- // 4 pins SWD_OUT, SWD_OUT_EN, SWCLK_OUT, SWCLK_OUT_EN
- // Individually controlled PUPs
- SWD_OUT_PER = 1; // Prevent float when disabled
- SWD_OUT_EN_PER = 1; // Prevent drive when disabled
- SWCLK_OUT_PER = 1; // Prevent float when disabled
- SWCLK_OUT_EN_PER = 1; // Prevent drive when disabled
- SWD_IN_DDR = 0; // Make input
- SWD_IN_PER = 1; // Shouldn't be req. as external PUP for speed
- #ifdef RESET_IN_DDR
- RESET_IN_DDR = 0; // Make input
- #endif
- #ifdef RESET_IN_PER
- RESET_IN_PER = 1; // Needed for input level translation to 5V
- #endif
- #ifdef RESET_OUT_PER
- RESET_OUT_PER = 1; // Holds RESET_OUT inactive when unused
- #endif
- (void)spi_setSpeed(0);
- swd_interfaceIdle();
- //! Turns off the SWD interface
- //! Depending upon settings, may leave target power on.
- void swd_off( void ) {
- #if ((HW_CAPABILITY & CAP_FLASH) != 0)
- (void)bdmSetVpp(BDM_TARGET_VPP_OFF);
- #endif
- if (!bdm_option.leaveTargetPowered) {
- VDD_OFF();
- SWCLK_DISABLE();
- SWD_DISABLE();
- RESET_DISABLE();
- #define SWD_DATA1_CLK1 SWCLK_OUT_MASK|SWD_OUT_EN_MASK
- #define SWD_DATA0_CLK1 SWCLK_OUT_MASK|0
- //! Transmits 1 clock with SWDIO 3-state
- void swd_turnAround() {
- asm {
- // 1 clock turn-around
- mov #SWD_OUT_MASK,DATA_PORT // SWDIO=3-state,SWCLK=0
- ldx bitDelay // Low time delay
- dbnzx *-0 // [4n fppp]
- bset SWCLK_OUT_BIT,DATA_PORT // SWCLK=1
- ldx bitDelay // High time delay
- //! Transmits 8-bits of idle (SDIO=0)
- void swd_txIdle8(void) {
- asm {
- mov #SPIxC2_M_8,SPIxC2 // Initialise SPI (8 bit)
- mov #SPIxC1_M_ON_TX,SPIC1 // Enable SPI
- clr DATA_PORT // Enable SWD drive
- cmp SPIxS // Dummy status read
- clr SPIxD // Tx data (=0)
- L1:
- brclr SPIS_SPRF_BIT,SPIxS,L1 // Wait until Tx/Rx complete
- lda SPIxD // Discard rx data
- mov #SWCLK_OUT_MASK|SWD_OUT_EN_MASK,DATA_PORT // Setup for SWCLK=1, SWD=3-state
- clr SPIC1 // Disable SPI
- #if (SWD_IN_BIT != 0)
- #error "SWD_IN must be bit #0"
- #endif
- //! SWD command phase
- //! Writes 8-bit command and receives 3-bit response
- //! It will retry on WAIT response a limited number of times
- //! @param command - 8-bit command to write to SWD (including parity!)
- //! @return \n
- //! == \ref BDM_RC_OK => Success \n
- //! == \ref BDM_RC_ARM_FAULT_ERROR => FAULT response from target \n
- //! == \ref BDM_RC_ACK_TIMEOUT => Excessive number of WAIT responses from target \n
- //! == \ref BDM_RC_NO_CONNECTION => Unexpected/no response from target
- //! @note A turn-around clock period will be added on error responses
- uint8_t swd_sendCommandWithWait(uint8_t command) {
- asm {
- sta txTiming1 // Save data (for retry)
- ldx #(2000/250) // Set up outer retry count
- retry_outer:
- pshx // Save outer retry count
- mov #250,rxTiming1 // Reset inner retry count
- retry:
- // 8-bit Start|APnDP|R/W|Parity|Stop|Park
- lda txTiming1 // Get Tx data
- sta SPIxD // Tx data
- L1:
- ldx SPIxD // Discard rx data
- SWD_3STATE_ASM // SWD=3-state
- bclr SWCLK_OUT_BIT,DATA_PORT // SWCLK=0
- // 1st bit ACK
- clra // Clear initial data value
- ldx DATA_PORT // Capture data before rising edge
- rorx
- rora
- // 2nd bit ACK
- rorx
- rora
- // 3rd bit ACK
- ldx DATA_PORT
- rorx
- rora
- tax
- lda #BDM_RC_OKx
- cbeqx #SWD_ACK_OK,balanceStack
- // Do turn-around clock on anything other than ACK_OK response
- lda bitDelay // Low time delay
- dbnza *-0 // [4n fppp]
- lda bitDelay // High time delay
- // Check for wait response
- cpx #SWD_ACK_WAIT // Wait response?
- bne identifyError // No - exit with other error
- // Check for wait timeout
- dbnz rxTiming1,retry // Retry limit reached
- pulx
- dbnzx retry_outer
- lda #BDM_RC_ACK_TIMEOUTx // Too many retries
- bra done // Return error (stack already balanced)
- identifyError:
- lda #BDM_RC_ARM_FAULT_ERRORx // Identify error
- cbeqx #SWD_ACK_FAULT,balanceStack
- lda #BDM_RC_NO_CONNECTIONx
- balanceStack:
- pulx // Balance stack
- done:
- #pragma MESSAGE DEFAULT C5703 // Restore warnings about unused parameter
- //! Transmits 32-bit value
- //! Sequence as follows:
- //! - 1-clock turn-around
- //! - 32-bit data value
- //! - 1-bit parity
- //! - 8-bit idle
- //! @param data - ptr to 32-bit data to Tx
- static void swd_tx32(const uint8_t *data) {
- asm {
- mov #SPIxC2_M_16,SPIxC2 // Initialise SPI (16 bit)
- mov #SPIxC1_M_ON_TX,SPIxC1 // Enable SPI
- lda 3,x // Start Tx 1st & 2nd bytes
- sta SPIxDL
- lda 2,x
- sta SPIxDH
- lda 0,x // Do byte-wide parity
- eor 1,x
- eor 2,x
- eor 3,x
- ldhx 0,x // Get 3rd & 4th bytes
- L1:
- brclr SPIS_SPRF_BIT,SPIxS,L1 // Wait until previous Tx/Rx complete
- cphx SPIxD16 // Discard read data
- sthx SPIxD16 // Tx 3rd & 4th bytes
- // Calculate nibble parity
- psha // [2]
- nsa // [1]
- eor 1,sp // [4]
- ais #1 // [2]
- // Calculate final parity
- tax // [1]
- clra // [1]
- rorx // [1]
- adc #0 // [2]
- rorx // [1]
- adc #0 // [2]
- rorx // [1]
- adc #0 // [2]
- rorx // [1]
- adc #0 // [2]
- //parity in A.0
- L2:
- brclr SPIS_SPRF_BIT,SPIxS,L2 // Wait until previous Tx/Rx complete
- ldhx SPIxD16 // Discard read data
- #if SWD_OUT_BIT >= 1 // move to SWD_OUT position
- lsla
- #endif
- #if SWD_OUT_BIT == 2
- lsla
- #else
- #error Fix this code
- #endif
- and #SWD_OUT_MASK // SWD=p, SWCLK=0
- sta DATA_PORT // Set up - no effect yet
- clr SPIC1 // Disable SPI,
- bset SWCLK_OUT_BIT,DATA_PORT // SWD=p, SWCLK=1
- // Start Tx of 8-bit idle
- // Wait for Idle Tx to complete
- L3:
- brclr SPIS_SPRF_BIT,SPIxS,L3 // Wait until Tx/Rx complete
- cmp SPIxD // Discard rx data
- rts
- //! Receives a 32-bit value with parity at end (33 total)
- //! - 8-bit idle
- //! @param data - ptr to buffer for Rx data
- //! @return BDM_RC_OK \n
- //! BDM_RC_ARM_PARITY_ERROR
- static uint8_t swd_rx32(uint8_t *data) {
- #define SPIS_SPTEF_BIT (5)
- #define SPIS_SPRF_BIT (7)
- asm {
- sthx SPIxD16 // Tx dummy/Rx
- L1:
- brclr SPIS_SPRF_BIT,SPIxS,L1 // Wait until Rx complete
- lda SPIxDH // Save data
- sta 2,x
- lda SPIxDL
- sta 3,x
- L2:
- brclr SPIS_SPRF_BIT,SPIxS,L2 // Wait until Rx complete
- sta 0,x
- lda SPIxDL
- sta 1,x
- bclr SWCLK_OUT_BIT,DATA_PORT // Setup for SWCLK=0
- clr SPIC1 // Disable SPI (SWCLK=0)
- // Parity bit
- lda DATA_PORT // Capture data before rising clock edge
- and #SWD_IN_MASK // Convert parity to byte width
- // Single Parity bit remains - position is unimportant
- // Do parity calculation
- eor 0,x // Do byte-wide parity on data & parity bit
- eor 1,x
- eor 2,x
- eor 3,x
- psha // [2]
- nsa // [1]
- eor 1,sp // [4]
- ais #1 // [2]
- tax // [1]
- clra // [1]
- rorx // [1]
- adc #0 // [2]
- rorx // [1]
- adc #0 // [2]
- rorx // [1]
- adc #0 // [2]
- rorx // [1]
- adc #0 // [2]
- and #1
- // Parity in A.0 - should be 0
- beq okExit
- lda #BDM_RC_ARM_PARITY_ERRORx
- okExit:
- L3:
- rts
- //! Switches interface to SWD
- //! - 64-bit sequence of 1's
- //! - 8-bit magic number 0xE79E
- //! @note Interface is reset even if already in SWD mode so IDCODE must be read
- //! to enable interface
- static void swd_JTAGtoSWD(void) {
- asm {
- bsr txOnes // Send 64 clocks
- ldhx #0xE79E // Send magic #
- sthx SPIxD16
- L5:
- brclr SPIS_SPTEF_BIT,SPIxS,L5 // Wait until Tx buffer empty
- L6:
- brclr SPIS_SPTEF_BIT,SPIxS,L6 // Wait until Tx buffer empty
- ldhx SPIxD16 // Discard last data
- L7:
- brclr SPIS_SPRF_BIT,SPIxS,L7 // Wait until Tx complete
- ldhx SPIxD16 // Discard rx data
- clr SPIC1 // Disable SPI (SWCLK=1)
- rts
- txOnes:
- ldhx #0xFFFF // Tx 64 bits with '1'
- sthx SPIxD16
- L1:
- brclr SPIS_SPTEF_BIT,SPIxS,L1 // Wait until Tx buffer empty
- sthx SPIxD16
- L2:
- brclr SPIS_SPTEF_BIT,SPIxS,L2 // Wait until Tx buffer empty
- sthx SPIxD16
- L3:
- brclr SPIS_SPTEF_BIT,SPIxS,L3 // Wait until Tx buffer empty
- sthx SPIxD16
- L4:
- brclr SPIS_SPTEF_BIT,SPIxS,L4 // Wait until Tx buffer empty
- rts
- //! SWD - Try to connect to the target
- //! This will do the following:
- //! - Switch the interface to SWD mode
- //! - Read IDCODE
- //! @return \n
- uint8_t swd_connect(void) {
- uint8_t buff[4];
- swd_JTAGtoSWD();
- swd_txIdle8();
- // Target must respond to read IDCODE immediately
- return swd_readReg(SWD_READ_IDCODE, buff);
- //! Read ARM-SWD DP & AP register
- //! @param command - SWD command byte to select register etc.
- //! @param data - buffer for 32-bit value read
- //! @return \n
- //! == \ref BDM_RC_NO_CONNECTION => Unexpected/no response from target \n
- //! == \ref BDM_RC_ARM_PARITY_ERROR => Parity error on data read
- //! @note Action and Data returned depends on register (some responses are pipelined)\n
- //! SWD_RD_DP_IDCODE - Value from IDCODE reg \n
- //! SWD_RD_DP_STATUS - Value from STATUS reg \n
- //! SWD_RD_DP_RESEND - LAST value read (AP read or DP-RDBUFF), FAULT on sticky error \n
- //! SWD_RD_DP_RDBUFF - Value from last AP read and clear READOK flag in STRL/STAT, FAULT on sticky error \n
- //! SWD_RD_AP_REGx - Value from last AP read, clear READOK flag in STRL/STAT and INITIATE next AP read, FAULT on sticky error
- uint8_t swd_readReg(uint8_t command, uint8_t *data) {
- uint8_t rc = swd_sendCommandWithWait(command);
- if (rc != BDM_RC_OK) {
- return rc;
- return swd_rx32(data);
- //! Write ARM-SWD DP & AP register
- //! @param data - buffer containing 32-bit value to write
- //! @return \n
- //! @note Action depends on register (some responses are pipelined)\n
- //! SWD_WR_DP_ABORT - Write value to ABORT register (accepted) \n
- //! SWD_WR_DP_CONTROL - Write value to CONTROL register (may be pending), FAULT on sticky error. \n
- //! SWD_WR_DP_SELECT - Write value to SELECT register (may be pending), FAULT on sticky error. \n
- //! SWD_WR_AP_REGx - Write to AP register. May initiate action e.g. memory access. Result is pending, FAULT on sticky error.
- uint8_t swd_writeReg(uint8_t command, const uint8_t *data) {
- return rc;
- swd_tx32(data);
- return rc;
- //! Write register of Access Port
- //! @param 16-bit address \n
- //! A[15:8] => DP-AP-SELECT[31:24] (AP # Select) \n
- //! A[7:4] => DP-AP-SELECT[7:4] (Bank select within AP) \n
- //! A[3:2] => APACC[3:2] (Register select within bank)
- //! @param buff \n
- //! - [1..4] => 32-bit register value
- //! @return
- //! == \ref BDM_RC_OK => success
- //! @note - Access is completed before return
- uint8_t swd_writeAPReg(const uint8_t *address, const uint8_t *buff) {
- static const uint8_t writeAP[] = {SWD_WR_AP_REG0, SWD_WR_AP_REG1, SWD_WR_AP_REG2, SWD_WR_AP_REG3};
- uint8_t rc;
- uint8_t regNo = writeAP[(address[1]&0xC)>>2];
- uint8_t selectData[4];
- selectData[0] = address[0];
- selectData[1] = 0;
- selectData[2] = 0;
- selectData[3] = address[1]&0xF0;
- // Set up SELECT register for AP access
- rc = swd_writeReg(SWD_WR_DP_SELECT, selectData);
- return rc;
- // Initiate write to AP register
- rc = swd_writeReg(regNo, buff);
- return rc;
- // Read from READBUFF register to allow stall/status response
- return swd_readReg(SWD_RD_DP_RDBUFF, selectData);
- //! Read register of Access Port
- //! @return
- uint8_t swd_readAPReg(const uint8_t *address, uint8_t *buff) {
- static const uint8_t readAP[] = {SWD_RD_AP_REG0, SWD_RD_AP_REG1, SWD_RD_AP_REG2, SWD_RD_AP_REG3};
- uint8_t rc;
- uint8_t regNo = readAP[(address[1]&0xC)>>2];
- return rc;
- // Initiate read from AP register (dummy data)
- rc = swd_readReg(regNo, buff);
- return rc;
- return swd_readReg(SWD_RD_DP_RDBUFF, buff);
- //! ARM-SWD - clear sticky bits
- //! @return error code
- uint8_t swd_clearStickyError(void) {
- static const uint8_t swdClearErrors[4] = {0,0,0,SWD_DP_ABORT_CLEAR_STICKY_ERRORS_B3};
- return swd_writeReg(SWD_WR_DP_ABORT, swdClearErrors);
- //! ARM-SWD - clear sticky bits and abort AP transactions
- uint8_t swd_abortAP(void) {
- {0,0,0,SWD_DP_ABORT_CLEAR_STICKY_ERRORS_B3|SWD_DP_ABORT_ABORT_AP_B3};
- uint8_t swd_test(void) {
- return swd_connect();
- // swd_JTAGtoSWD();
- // return BDM_RC_OK;
- // return swd_connect();
- #endif // HW_CAPABILITY && CAP_SWD_HW
