Mon Nov 02 09:51:37 2015: JLINK command: device = ADuC7024, return = 0
Mon Nov 02 09:51:37 2015: DLL version: V4.14
Mon Nov 02 09:51:37 2015: Firmware: J-Link ARM V8 compiled Sep 20 2012 13:27:01
Mon Nov 02 09:51:37 2015: JTAG speed is initially set to: 32 kHz
Mon Nov 02 09:51:37 2015: TotalIRLen = 4, IRPrint = 0x01
Mon Nov 02 09:51:38 2015: Hardware reset with strategy 2 was performed
Mon Nov 02 09:51:38 2015: Initial reset was performed
Mon Nov 02 09:51:38 2015: Found 1 JTAG device, Total IRLen = 4:
Mon Nov 02 09:51:38 2015: #0 Id: 0x3F0F0F0F, IRLen: 4, IRPrint: 0x1 ARM7TDMI Core
Mon Nov 02 09:51:38 2015: J-Link found 1 JTAG device(s). ARM core Id: 3F0F0F0F ARM7
Mon Nov 02 09:51:38 2015: Device at TAP0 selected
Mon Nov 02 09:51:38 2015: RTCK is not connected
Mon Nov 02 09:51:38 2015: Auto JTAG speed: 8000 kHz
Mon Nov 02 09:51:38 2015: 640 bytes downloaded and verified (1.82 Kbytes/sec)
Mon Nov 02 09:51:38 2015: Loaded debugee: D:\Program Files\IAR Systems\Embedded Workbench 5.4 Evaluation\arm\config\flashloader\AnalogDevices\FlashADuC702x.out
Mon Nov 02 09:51:38 2015: Target reset
Mon Nov 02 09:51:40 2015: TotalIRLen = 4, IRPrint = 0x01
Mon Nov 02 09:51:41 2015: RTCK is not connected
Mon Nov 02 09:51:41 2015: Auto JTAG speed: 8000 kHz
Mon Nov 02 09:51:41 2015: Hardware reset with strategy 2 was performed
Mon Nov 02 09:51:41 2015: 22440 bytes downloaded into FLASH and verified (7.05 Kbytes/sec)
Mon Nov 02 09:51:41 2015: Target reset
Mon Nov 02 09:51:55 2015: The stack 'IRQ_STACK' is filled to 100% (64 bytes used out of 64). The warning threshold is set to 90.%
Mon Nov 02 09:51:58 2015: The stack 'IRQ_STACK' is filled to 100% (64 bytes used out of 64). The warning threshold is set to 90.%
在线仿真每次点击break,都警告 The stack 'IRQ_STACK' is filled to 100% (64 bytes used out of 64). The warning threshold is set to 90.% 怎么解决呀。。。
附上编译的信息:
Building configuration: test - Debug
Updating build tree...
IAR ANSI C/C++ Compiler V5.50.0.21878/W32 EVALUATION for ARM
Copyright (C) 1999-2010 IAR Systems AB.
1 000 bytes of CODE memory
512 bytes of CONST memory
Errors: none
Warnings: none
Linking
IAR ELF Linker V5.50.0.51878/W32 for ARM
Copyright (C) 2007-2010 IAR Systems AB.
22 140 bytes of readonly code memory
300 bytes of readonly data memory
7 971 bytes of readwrite data memory
Errors: none
Warnings: none
Link time: 0.03 (CPU) 0.03 (elapsed)
test.out
Converting
Total number of errors: 0
Total number of warnings: 0
ADuC7024_datasheet
Memory
62 kB Flash/EE memory, 8 kB SRAM
In-circuit download, JTAG-based debug
Software-triggered in-circuit reprogrammability
