发表于 2016-1-6 13:34:02
PL-2701 Super-Speed USB Host to Host Bridge Controller
PL2701 is a single-chip SuperSpeed USB (USB 3.0) host-to-host bridge controller designed for connecting two computers or devices with USB hosts running Android™, Linux, iOS, Mac OS, or Windows® operating system. SuperSpeed USB (USB 3.0) reaches data transfer rates up to 5Gbps, offering 10x faster performance over Hi-Speed USB (USB 2.0) and is backward compatible with USB 2.0 hosts, devices, and hubs.
PL2701 uses a “Hybrid Multi-Class” channel allowing two USB hosts to share resources, such as a keyboard or mouse, network, mass storage devices, displays, and multimedia. PL2701 default supports Remote Network Driver Interface Specification (RNDIS), WinUSB, HID, Audio, and Mass Storage USB device classes. PL2701 also provides a flexible endpoint assignment mechanism that allows many applications to be implemented through this high performance host-to-host bridge controller.
Full compliance with the USB3.0 Specification v1.0
USB-IF Logo Certified (TID 340000113)
Transfer data and share resources between two or more PCs with speed up to 5Gbps
Support 16 endpoints (Excluding EP0) to be configured as interrupt, bulk, and isochronous endpoints
Hybrid FIFO Channels (Pass-Through FIFO Channel and DMA FIFO Channel) for versatile usages
8-bit high performance 1T 8032 MCU from 30MHz to 60MHz
One I2c Master up to 1MHz, One SPI Master up to 60MHz, One eMMC reader up to 30MHz
PWMx2, UARTx1, GPIOsx16
On-Chip 5v-3.3v internal regulator
Bus powered from either USB port
PKG : QFN64 packaging
这个好像支持Linux |
