发表于 2018-1-3 10:19:58
在官方EVK板上跑了个demo镜像:
https://emcraft.com/products/819#overview
U-Boot 2017.09-rc1-cortexm-2.5.0 (Oct 17 2017 - 01:47:42 +0300)
CPU: i.MX RT105x at 600MHz
Model: NXP i.RT1050 EVK
DRAM: 32 MiB
MMC: FSL_SDHC: 0
reading uboot.env
Video: 480x272x24
In: serial@40184000
Out: serial@40184000
Err: serial@40184000
Net: eth0: ethernet@402D8000
391736 bytes read in 109 ms (3.4 MiB/s)
reading mxrt105x-evk.ini
100 bytes read in 11 ms (8.8 KiB/s)
fatexec: 'setenv ipaddr 192.168.1.251'
fatexec: 'setenv netmask 255.255.0.0'
Hit any key to stop autoboot: 0
reading rootfs.uImage
7684098 bytes read in 1754 ms (4.2 MiB/s)
## Booting kernel from Legacy Image at 80007fc0 ...
Image Name: Linux-4.5.0-00417-g1e71634a15d7-
Image Type: ARM Linux Multi-File Image (uncompressed)
Data Size: 7684034 Bytes = 7.3 MiB
Load Address: 80008000
Entry Point: 80008001
Contents:
Image 0: 7674368 Bytes = 7.3 MiB
Image 1: 9654 Bytes = 9.4 KiB
Verifying Checksum ... OK
## Flattened Device Tree from multi component Image at 80007FC0
Booting using the fdt at 0x80759a0c
Loading Multi-File Image ... OK
Loading Device Tree to 81e77000, end 81e7c5b5 ... OK
Starting kernel ...
Booting Linux on physical CPU 0x0
Linux version 4.5.0-00417-g1e71634a15d7-dirty (yur@linux-7d45) (gcc version 4.7.4 20130508 (prerelease) (20170818-165657- build on build.emcraft by build) ) #151 Sun Oct 15 15:50:07 MSK 2017
CPU: ARMv7-M [411fc271] revision 1 (ARMv7M), cr=00000000
CPU: WBA data cache, WBA instruction cache
Machine model: NXP IMXRT1050 board
debug: ignoring loglevel setting.
On node 0 totalpages: 8192
free_area_init_node: node 0, pgdat 80759320, node_mem_map 81ec0000
Normal zone: 64 pages used for memmap
Normal zone: 0 pages reserved
Normal zone: 8192 pages, LIFO batch:0
pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
pcpu-alloc: [0] 0
Built 1 zonelists in Zone order, mobility grouping off. Total pages: 8128
Kernel command line: console=ttyLP0,115200 consoleblank=0 ignore_loglevel ip=192.168.1.251:172.17.0.1::255.255.0.0::eth0:off
PID hash table entries: 128 (order: -3, 512 bytes)
Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
Memory: 23792K/32768K available (2188K kernel code, 118K rwdata, 360K rodata, 4824K init, 95K bss, 8976K reserved, 0K cma-reserved)
Virtual kernel memory layout:
vector : 0x00000000 - 0x00001000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0x00000000 - 0xffffffff (4095 MB)
lowmem : 0x80000000 - 0x82000000 ( 32 MB)
.text : 0x80008000 - 0x8028531c (2549 kB)
.init : 0x80286000 - 0x8073c000 (4824 kB)
.data : 0x8073c000 - 0x80759a00 ( 119 kB)
.bss : 0x80759a00 - 0x807719f8 ( 96 kB)
NR_IRQS:16 nr_irqs:16 16
sched_clock: 32 bits at 75MHz, resolution 13ns, wraps every 28633115129ns
clocksource: vf-pit: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 25483472618 ns
Calibrating delay loop... 1196.85 BogoMIPS (lpj=5984256)
pid_max: default: 4096 minimum: 301
Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
devtmpfs: initialized
clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
pinctrl core: initialized pinctrl subsystem
mxs_phy 400d9000.usbphy: Invalid GPIO: -2
mxs_phy 400da000.usbphy: Invalid GPIO: -2
imxrt105x-pinctrl 401f8000.iomuxc: initialized IMX pinctrl driver
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
PTP clock support registered
clocksource: Switched to clocksource vf-pit
TCP established hash table entries: 1024 (order: 0, 4096 bytes)
TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
TCP: Hash tables configured (established 1024 bind 1024)
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
futex hash table entries: 16 (order: -5, 192 bytes)
fuse init (API version 7.24)
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
io scheduler noop registered
io scheduler cfq registered (default)
mxsfb 402b8000.lcdif: initialized
40184000.serial: ttyLP0 at MMIO 0x40184000 (irq = 44, base_baud = 375000) is a FSL_LPUART
console [ttyLP0] enabled
Serial: VF610 driver
libphy: fec_enet_mii_bus: probed
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci-mxc: Freescale On-Chip EHCI Host driver
usbcore: registered new interface driver uas
usbcore: registered new interface driver usb-storage
ci_hdrc ci_hdrc.1: EHCI Host Controller
ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 1
ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
g_serial gadget: Gadget Serial v2.4
g_serial gadget: g_serial ready
i2c /dev entries driver
ft5x0x_ts 0-0038: resolution: 479x271
ft5x0x_ts 0-0038: Operating withoug nReset pin (-2)
input: ft5x0x_ts as /devices/virtual/input/input0
ft5x0x_ts 0-0038: fft5x0x_i2c_Read: i2c read error.
[FTS] Firmware version = 0x1b
[FTS] report rate is 270Hz.
[FTS] touch threshold is 108.
i2c i2c-0: LPI2C adapter registered
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
sdhci-esdhc-imx 402c0000.esdhc: could not get default state
/soc/aips-bus@40000000/esdhc@402c0000: voltage-ranges unspecified
mmc0: SDHCI controller on 402c0000.esdhc [402c0000.esdhc] using DMA
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
NET: Registered protocol family 10
sit: IPv6 over IPv4 tunneling driver
input: gpio-keys as /devices/platform/gpio-keys/input/input1
Freeing unused kernel memory: 4824K (80286000 - 8073c000)
init started: BusyBox v1.24.2 (2017-10-12 12:11:53 MSK)
mmc0: host does not support reading read-only switch, assuming write-enable
mmc0: new high speed SDHC card at address b368
mmcblk0: mmc0:b368 NCard 3.74 GiB
mmcblk0: p1
FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
random: dropbear urandom read with 5 bits of entropy available
/ # Micrel KSZ8081 or KSZ8091 402d8000.etherne:02: attached PHY driver [Micrel KSZ8081 or KSZ8091] (mii_bus:phy_addr=402d8000.etherne:02, irq=-1)
IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
/ # fec 402d8000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
/ # ls
bin etc lib root tmp
crankdemo httpd mnt sbin usr
dev init proc sys var
