发表于 2018-2-27 19:53:39
- CPU_STK *OSTaskStkInit (OS_TASK_PTR p_task,
- void *p_arg,
- CPU_STK *p_stk_base,
- CPU_STK *p_stk_limit,
- CPU_STK_SIZE stk_size,
- OS_OPT opt)
- CPU_STK *p_stk;
- (void)opt; /* 'opt' is not used, prevent warning */
- p_stk = &p_stk_base[stk_size]; /* Load stack pointer */
- p_stk = (CPU_STK *)((CPU_STK)(p_stk) & ~7u); /* Align the stack to 8-bytes. */
- /* Registers stacked as if auto-saved on exception */
- *(--p_stk) = (CPU_STK)0x01000000uL; /* xPSR */
- *(--p_stk) = (CPU_STK)p_task; /* Entry Point */
- *(--p_stk) = (CPU_STK)OS_TaskReturn; /* R14 (LR) */
- *(--p_stk) = (CPU_STK)0x12121212uL; /* R12 */
- *(--p_stk) = (CPU_STK)0x03030303uL; /* R3 */
- *(--p_stk) = (CPU_STK)0x02020202uL; /* R2 */
- *(--p_stk) = (CPU_STK)0x01010101uL; /* R1 */
- *(--p_stk) = (CPU_STK)p_arg; /* R0 : argument */
- *(--p_stk) = (CPU_STK)0x11111111uL; /* R11 */
- *(--p_stk) = (CPU_STK)0x10101010uL; /* R10 */
- *(--p_stk) = (CPU_STK)0x09090909uL; /* R9 */
- *(--p_stk) = (CPU_STK)0x08080808uL; /* R8 */
- *(--p_stk) = (CPU_STK)0x07070707uL; /* R7 */
- *(--p_stk) = (CPU_STK)0x06060606uL; /* R6 */
- *(--p_stk) = (CPU_STK)0x05050505uL; /* R5 */
- *(--p_stk) = (CPU_STK)0x04040404uL; /* R4 */
- #if defined(__ARMVFP__)
- *(--p_stk) = (CPU_STK)0xFFFFFFFDuL; /* EXEC_RETURN; See Note 5 */
- #endif
- return (p_stk);
复制代码 |
