发表于 2018-4-25 00:38:11
"C:\Program Files (x86)\IAR Systems\....\arm\bin\ielfdumparm.exe"
ielfdumparm
IAR ELF Dumper V8.22.1.15669 for ARM
Copyright 2007-2018 IAR Systems AB.
Usage: IElfDump input_file [output_file]
Available command line options:
--all Dump all sections
--arm Disassemble in Arm mode if mode cannot be deduced by the image.
--code Dump only code sections
--disasm_data Use disassembly format for data sections
--no_bom Don't use a Byte Order Mark in Unicode output
--no_header Do not produce a list header
--no_rel_sections
Do not output associated .rel sections
--no_strtab Do not include strtab sections
--no_utf8_in Non-IAR input files are by default assumed to use UTF-8
encoding unless this option is used.
--output file
-o file Name of text file to create
--range A-B Disassemble only addresses in the specified range
(from A to B).
--raw Use raw text format
--section #|name[,...]
-s #|name[,...] Dump only section(s) with given numbers/names
--source Include source in disassembled code in executables
--text_out encoding
Encoding to use for text output files
utf8 UTF-8
utf16le Little-endian UTF-16
utf16be Big-endian UTF-16
locale Locale specific encoding
--thumb Disassemble in thumb mode if mode cannot be deduced by the image.
--use_full_std_template_names
Don't use short names for standard C++ templates
--utf8_text_in Non-source text input files with no BOM use UTF-8 encoding
--version Output version information and exit
-a All sections, except strtab sections
-f file Read command line options from file
ielfdumparm in.out out.s --code
