发表于 2018-6-8 17:59:17
[2015-09-14 08:47:42:940_S:] AT+CPIN?
[2015-09-14 08:47:42:956_R:] AT+CPIN?
[2015-09-14 08:47:42:956_R:] +CPIN: READY
[2015-09-14 08:47:42:956_R:] OK
[2015-09-14 08:47:42:958_S:] AT+CREG?
[2015-09-14 08:47:42:972_R:] AT+CREG?
[2015-09-14 08:47:42:972_R:] +CREG: 0,1
[2015-09-14 08:47:42:972_R:] OK
[2015-09-14 08:47:42:973_S:] AT+CGREG?
[2015-09-14 08:47:42:988_R:] AT+CGREG?
[2015-09-14 08:47:42:988_R:] +CGREG: 0,1
[2015-09-14 08:47:42:988_R:] OK
/* Use AT+QIMODE command to select TCPIP Stack mode, it is non-transparent mode when AT+QIMODE=0, and AT+QIMODE=1 is transparent (This tool only support non-transparent mode) */
[2015-09-14 08:47:42:992_S:] AT+QIMODE=0
[2015-09-14 08:47:43:004_R:] AT+QIMODE=0
[2015-09-14 08:47:43:004_R:] OK
/* Use AT+QICSGP=1,"CMNET" to set APN as "CMNET" */
[2015-09-14 08:47:43:015_S:] AT+QICSGP=1,"CMNET"
[2015-09-14 08:47:43:036_R:] AT+QICSGP=1,"CMNET"
[2015-09-14 08:47:43:036_R:] OK
/* (4) Start TCPIP task */
[2015-09-14 08:47:43:047_S:] AT+QIREGAPP
[2015-09-14 08:47:43:068_R:] AT+QIREGAPP
[2015-09-14 08:47:43:068_R:] OK
/* Check the current connecting mode(1: GPRS connecting mode,0: CSD connecting mode) */
[2015-09-14 08:47:43:080_S:] AT+QICSGP?
[2015-09-14 08:47:43:100_R:] AT+QICSGP?
[2015-09-14 08:47:43:100_R:] +QICSGP: 1
[2015-09-14 08:47:43:100_R:] OK
/* The current connecting mode is GPRS connecting mode */
/* Active the GPRS context */
[2015-09-14 08:47:43:115_S:] AT+QIACT
[2015-09-14 08:47:43:131_R:] AT+QIACT
[2015-09-14 08:47:44:155_R:] OK
/* Get the local IP address */
[2015-09-14 08:47:44:168_S:] AT+QILOCIP
[2015-09-14 08:47:44:187_R:] AT+QILOCIP
[2015-09-14 08:47:44:187_R:] 10.2.69.101
/* Use ATV1 to set the response format */
[2015-09-14 08:47:49:687_S:] ATV1
[2015-09-14 08:47:49:706_R:] ATV1
[2015-09-14 08:47:49:706_R:] OK
/* Use AT+QIHEAD=1 to add the header information when receive data */
[2015-09-14 08:47:49:720_S:] AT+QIHEAD=1
[2015-09-14 08:47:49:737_R:] AT+QIHEAD=1
[2015-09-14 08:47:49:737_R:] OK
/* Use AT+QIDNSIP=0 to use the IP address to establish TCP/UDP session, while AT+QIDNSIP=1 is use the domain name to establish TCP/UDP session */
[2015-09-14 08:47:49:746_S:] AT+QIDNSIP=0
[2015-09-14 08:47:49:753_R:] AT+QIDNSIP=0
[2015-09-14 08:47:49:769_R:] OK
/* Use AT+QIOPEN="TCP","116.247.104.27","6003" to connect to a TCP server (IP address: 116.247.104.27:6003). If return "CONNECT OK" means successfully connected to the remote server */
[2015-09-14 08:47:49:776_S:] AT+QIOPEN="TCP","116.247.104.27","6003"
[2015-09-14 08:47:49:785_R:] AT+QIOPEN="TCP","116.247.104.27","6003"
[2015-09-14 08:47:49:801_R:] OK
[2015-09-14 08:47:52:207_R:] CONNECT OK
/* AT+QISEND, send data to server, ">" from the UART indicates the following input data is considered as data to be send. After receiving ">", input data (TEST), the maximum length of the data is 1460, the data beyond 1460 will be omitted. Then use <CTRL+Z> to send data. When receive SEND OK means the data has been sent */
[2015-09-14 08:48:00:334_S:] AT+QISEND
[2015-09-14 08:48:00:343_R:] AT+QISEND
[2015-09-14 08:48:00:359_R:] > 1234567890
/* Use AT+QISACK to query whether all the data has been sent out */
[2015-09-14 08:48:00:552_R:]
[2015-09-14 08:48:00:567_R:] SEND OK
[2015-09-14 08:48:01:255_R:] IPD10:1234567890
[2015-09-14 08:48:01:648_S:] AT+QISACK
[2015-09-14 08:48:01:671_R:] AT+QISACK
[2015-09-14 08:48:01:671_R:] +QISACK: 10, 10, 0
[2015-09-14 08:48:01:671_R:] OK
/* Use ATE1 to enable echo mode */
[2015-09-14 08:48:35:647_S:] ATE1
[2015-09-14 08:48:35:662_R:] ATE1
[2015-09-14 08:48:35:662_R:] OK
/* Use AT+QICLOSE to close the connecting of TCP/UDP */
[2015-09-14 08:48:35:674_S:] AT+QICLOSE
[2015-09-14 08:48:35:694_R:] AT+QICLOSE
[2015-09-14 08:48:35:694_R:] CLOSE OK
[2015-09-14 08:48:37:824_S:] ATE1
[2015-09-14 08:48:37:838_R:] ATE1
[2015-09-14 08:48:37:838_R:] OK
/* Use AT+QIDEACT to deactivate GPRS context */
[2015-09-14 08:48:38:336_S:] AT+QIDEACT
[2015-09-14 08:48:38:350_R:] AT+QIDEACT
[2015-09-14 08:48:39:437_R:] DEACT OK
