void BSP_UART_Init(BUFF_TcbType* pbcb);
void BSP_UART_RxStart(UART_HandleTypeDef* huart, BUFF_TcbType* pbcb);
void BSP_UART_Getchars(UART_HandleTypeDef* huart, BUFF_TcbType* pbcb);
void BSP_UART_FlushRxbuff(UART_HandleTypeDef* huart, BUFF_TcbType* pbcb);
void BSP_UART_Putchars(UART_HandleTypeDef *huart, BUFF_TcbType* pbcb, uint8_t* pd, uint8_t size);
#define USART_FPGA USART1
#define USART_PC USART3
/* Description :
Initialize the BUFF_TcbType structure
pbcb->pr = pbcb->rxbuff;
pbcb->pti = pbcb->txbuff;
pbcb->pto = pbcb->txbuff;
pbcb->rxcount = 0;
pbcb->txcount = 0;
pbcb->hal_txcount = 0;
/* Description:
main routine calls this function to launch UART data Recieving (Enable the RXNE INT),
and the receive loop between bsp layer and hal layer will keep on going.
HAL_UART_Receive_IT(huart, pbcb->hal_rxbuff,HAL_RX_BUFF_SIZE);
/* Description:
Obtain or move the received datas from HAL buffer to BSP buffer
@ *ps , pointer of source
@ *pd , pointer of destination
{ /*main routine move data from hal layer to bsp layer periodically */
/*HAL_UART_RxCpltCallback(huart) wouldn't be called if the main routine works correctlly*/
/*the main program must be blocked if this funcition was called*/
if(huart->RxXferCount)
/*transfer data from HAL to BSP*/
*pbcb->pr=*huart->pRxBuffOutPtr;
/*update BSP layer data structure*/
pbcb->rxcount++;
pbcb->pr++;
/*update HAL layer structure*/
__disable_irq();
huart->RxXferCount--;
__enable_irq();
huart->pRxBuffOutPtr++;
/*update HAL layer data structure*/
if(huart->pRxBuffOutPtr == &pbcb->hal_rxbuff[HAL_RX_BUFF_SIZE])
huart->pRxBuffOutPtr = &pbcb->hal_rxbuff[0];
/* Description:
This function nerve be called unless overflow occured or main rountine was blocked
and didn't obtain data from rx bsp buffer in time.
void HAL_UART_RxCpltCallback(UART_HandleTypeDef *huart)
//BSP_Debug();
/* Description:
Flush the RX buffer of bsp layer after the received msg was accepted
void BSP_UART_FlushRxbuff( UART_HandleTypeDef *huart,BUFF_TcbType* pbcb)
/*reload control information for buff of BSP layer*/
uint8_t i;
__disable_irq();
for(i = 0; i < pbcb->rxcount; i++)
pbcb->rxbuff[i] = 0;
pbcb->rxcount = 0;
__enable_irq();
/* Description:
While datas in the hal layer were transmitted , this function will be called automatically
by HW system, we shall load datas from bsp layer to hal layer in this function , and launch
the next transmition, the Tx loop between bsp layer and hal layer will keep on going.
void HAL_UART_TxCpltCallbackExt(UART_HandleTypeDef *huart, BUFF_TcbType* pbcb)
/*channel uart to pc tx completed*/
int8_t tmp ,i ,idx;
int16_t d;
if(huart->Instance == USART_PC)
idx=0; /*subscript*/
if(huart->Instance == USART_FPGA)
idx=1;
/*step 1: check if all the datas in bsp tx buff were transmitted */
if(pbcb->txcount > 0)
/*step 2: check how many datas are in the tx buff*/
if(pbcb->txcount > HAL_TX_BUFF_SIZE)
tmp = HAL_TX_BUFF_SIZE;
tmp = pbcb->txcount;
/*step 3: remove data from bsp layer to hal layer */
for(i = 0; i < tmp; i++)
/*refresh pbcb */
pbcb->hal_txbuff[i] = *pbcb->pto++;
pbcb->txcount--;
pbcb->hal_txcount++;
/*ring buffer ,pointer move to head*/
if( pbcb->pto == (pbcb->txbuff + BSP_TX_BUFF_SIZE))
/*if it is 485 bus , set the dircetion to tx*/
__BSP_RS485_TXD();
/*step 4: arm to transimit bsp data*/
HAL_UART_Transmit_IT(huart, pbcb->hal_txbuff, pbcb->hal_txcount);
/*data in bsp buff has been tx*/
for(d = 5000; d >0; d--) /*hold on here until the datas on the bus were transmitted*/
__BSP_RS485_RXD();
/* Description
put chars into bsp layer buffer, if huart->State !=HAL_UART_STATE_BUSY_TX
launch transimition process ,then the loop between bsp layer and hal layer keep going
@ huart ,hal layer object
@ pbcb, bsp layer object
@ *pd, pointer to datas to be transfer
@ size, number of data to be transfer
int8_t i,tmp;
/*step 1: put the chars into bsp buffer*/
__disable_irq();
for(i=0;i<size;i++)
*pbcb->pti++= *pd++;
pbcb->txcount++;
/*ring buffer ,pointer move to head from rear*/
if( pbcb->pti == (pbcb->txbuff + BSP_TX_BUFF_SIZE))
__enable_irq();
/*step 2: if huart->state is free for tx, move data from bsp to hal and start a transfer*/
if((huart->State == HAL_UART_STATE_READY) || (huart->State == HAL_UART_STATE_BUSY_RX))
/*refresh pbcb */
pbcb->txcount--;
if(huart->Instance ==USART_PC)
__BSP_RS485_TXD();
/*arm to transimit bsp data*/
/*if huart->state is busy for tx ,do nothing*/
