芯片是 STM32F072C8T6
已解决, 确认是 NbOfPages 的问题, 网上的代码 果然不靠谱
成功实现将 F072的JLINK OB, 弄成 可通过DFU更新固件了...现已升到JLINK_V644C里的..
更新APP用户程序时, 卡在Download Phase 94%处不动了...请问是什么原因, 刚做好时, 第一次能下载成功.....之后再下载就卡着失败了
usbd_dfu_if.c 里的代码, 贴出几处关键部份...............
大伙看看这是否有错误, 是否NbOfPages值错误了
NbOfPages = (USBD_DFU_APP_END_ADD - USBD_DFU_APP_DEFAULT_ADD) / FLASH_PAGE_SIZE;
(F800-4800) / 800 = 0x16 也是22个页, 是否应该23页呢?
#define USBD_DFU_APP_END_ADD 0x0800F800 //ADDR_FLASH_PAGE_31, APP 最后一个扇区的首地址
//#define USBD_DFU_APP_DEFAULT_ADD 0x08004800 //APP 程序起始地址 usbd_conf.h
//#define FLASH_PAGE_SIZE 0x800U //2K 大小/页 stm32f0xx_hal_flash_ex.h
#define FLASH_ERASE_TIME (uint16_t)50
#define FLASH_PROGRAM_TIME (uint16_t)50
#define FLASH_DESC_STR "@Internal Flash /0x08000000/09*002Ka,23*002Kg"
uint16_t MEM_If_Erase_FS(uint32_t Add)
/* USER CODE BEGIN 2 */
uint32_t NbOfPages = 0;
uint32_t PageError = 0;
/* Variable contains Flash operation status */
HAL_StatusTypeDef status;
FLASH_EraseInitTypeDef eraseinitstruct;
/* Get the number of sector to erase from 1st sector*/
eraseinitstruct.TypeErase = FLASH_TYPEERASE_PAGES;
eraseinitstruct.PageAddress = USBD_DFU_APP_DEFAULT_ADD;
eraseinitstruct.NbPages = NbOfPages;
status = HAL_FLASHEx_Erase(&eraseinitstruct, &PageError);
if (status != HAL_OK)
return USBD_FAIL;
return (USBD_OK);
/* USER CODE END 2 */
uint16_t MEM_If_Write_FS(uint8_t *src, uint8_t *dest, uint32_t Len)
/* USER CODE BEGIN 3 */
uint32_t i = 0;
for(i = 0; i < Len; i += 4)
/* Device voltage range supposed to be [2.7V to 3.6V], the operation will
be done by byte */
if(HAL_FLASH_Program(FLASH_TYPEPROGRAM_WORD, (uint32_t)(dest + i), *(uint32_t *)(src + i))
== HAL_OK)
/* Check the written value */
if(*(uint32_t *)(src + i) != *(uint32_t *)(dest + i))
/* Flash content doesn't match SRAM content */
return 2;
/* Error occurred while writing data in Flash memory */
return 1;
return (USBD_OK);
/* USER CODE END 3 */
uint8_t *MEM_If_Read_FS(uint8_t *src, uint8_t *dest, uint32_t Len)
/* Return a valid address to avoid HardFault */
/* USER CODE BEGIN 4 */
uint32_t i = 0;
uint8_t *psrc = src;
for(i = 0; i < Len; i++)
dest = *psrc++;
return (uint8_t *)(dest);
/* USER CODE END 4 */
uint16_t MEM_If_GetStatus_FS(uint32_t Add, uint8_t Cmd, uint8_t *buffer)
/* USER CODE BEGIN 5 */
switch (Cmd)
case DFU_MEDIA_PROGRAM:
buffer[1] = (uint8_t)FLASH_PROGRAM_TIME;
buffer[2] = (uint8_t)(FLASH_PROGRAM_TIME << 8);
buffer[3] = 0;
case DFU_MEDIA_ERASE:
default:
buffer[1] = (uint8_t)FLASH_ERASE_TIME;
buffer[2] = (uint8_t)(FLASH_ERASE_TIME << 8);
buffer[3] = 0;
return (USBD_OK);
/* USER CODE END 5 */
