请教下,sdram 调试有数据错乱 ??】
上图片中,2个框框里面的数据内容会同步发生变化,这个是怎么回事啊 ?
sdram 使用 MT48LC16M16
相关配置代码如下:
uint8_t BSP_SDRAM_Init(void)
uint8_t sdramstatus = SDRAM_ERROR;
FMC_SDRAM_TimingTypeDef SDRAM_Timing;
SDRAM_HandleTypeDef SDRAM_Handle;
FMC_SDRAM_CommandTypeDef command = {0};
/* SDRAM device configuration */
SDRAM_Handle.Instance = FMC_SDRAM_DEVICE;
SDRAM_Timing.LoadToActiveDelay = 2;
SDRAM_Timing.ExitSelfRefreshDelay = 7;
SDRAM_Timing.SelfRefreshTime = 4;
SDRAM_Timing.RowCycleDelay = 7;
SDRAM_Timing.WriteRecoveryTime = 2;
SDRAM_Timing.RPDelay = 2;
SDRAM_Timing.RCDDelay = 2;
SDRAM_Handle.Init.SDBank = FMC_SDRAM_BANK2; /* 硬件设计上用的BANK2 ,使用 FMC_SDNE1, FMC_SDCKE1 */*/
SDRAM_Handle.Init.ColumnBitsNumber = FMC_SDRAM_COLUMN_BITS_NUM_9;
SDRAM_Handle.Init.RowBitsNumber = FMC_SDRAM_ROW_BITS_NUM_13;
SDRAM_Handle.Init.MemoryDataWidth = FMC_SDRAM_MEM_BUS_WIDTH_16;
SDRAM_Handle.Init.InternalBankNumber = FMC_SDRAM_INTERN_BANKS_NUM_4;
SDRAM_Handle.Init.CASLatency = FMC_SDRAM_CAS_LATENCY_3;
SDRAM_Handle.Init.WriteProtection = FMC_SDRAM_WRITE_PROTECTION_DISABLE;
SDRAM_Handle.Init.SDClockPeriod = SDCLOCK_PERIOD; /* FMC时钟200MHz,2分频后给SDRAM,即100MHz */
SDRAM_Handle.Init.ReadBurst = FMC_SDRAM_RBURST_ENABLE; /* 使能读突发 */
SDRAM_Handle.Init.ReadPipeDelay = FMC_SDRAM_RPIPE_DELAY_0;
/* SDRAM controller initialization */
// BSP_SDRAM_MspInit(&SDRAM_Handle, NULL); /* __weak function can be rewritten by the application */
if(HAL_SDRAM_Init(&SDRAM_Handle, &SDRAM_Timing) != HAL_OK)
/* SDRAM initialization sequence */
BSP_SDRAM_Initialization_sequence(&SDRAM_Handle, &command);
sdramstatus = SDRAM_OK;
return sdramstatus;
MT48LC16M16 相关资料
我的行列设置应该是没有错的吧 ???
