介绍Annex WI-FI RDS, 是运行在ESP8266, 有Web IDE,使用Basic 语言, HTML。他是今年2019 年3月才推出的。
用 AnnexToolKit , 通过串口刷入
刷好后, 可以通过浏览器访问ESP8266
访问192.168.1.8, 看到Web IDE, 可以开始编程了
代码是大概这样的, 下面是控制续电器开关
- CODE: example1.bas
- ' ANNEX WI-FI Basic
- 'example-1
- 'Simple button controlling a pin toggle function
- 'can be connected to a relay module
- relay = 16 ' the relay is connected on the pin GPIO16 (D0 on nodemcu module)
- v = 0 ' initial value of the output
- onHtmlReload create_page 'defines the page that will be sent at first connection
- gosub create_page ' draw the page at the first run
- wait ' wait for events
- create_page: ' this is the html page
- ' clear the screen
- cls
- html button$("RELAY", toggle_relay) ' draws a button
- html led$(v) ' draws a led
- return
- toggle_relay:
- v = 1 - v ' invert the status of the output
- pin(relay) = v 'set the output pin (the relay)
- refresh 'refresh the status of the led
- return
运行Run 后, 看到输出界面是这样的, 一个Relay 的按钮,输出相对在GPIO16 (或NodeMCU的D0)
有兴趣可以看看:
https://sites.google.com/site/annexwifi/home
附件: Annex Package.zip 是刷机软件, 解压, 直接运行。
