(VIP++福利贴:本资源由坛友 saddam911 提出申请,由阿莫网上搜集与上传,版权归原作者。)
VESA and Industry Standards and Guidelines for Computer Display Monitor Timing
详细定义了各种视频格式(640x480、800x600、1280x720、1280x1024、1920x1080)的时序要求,包括时钟、行同步、场同步信号等,VESA MONITOR TIMING STANDARD。非常好的用户参考资料。
Timing Specifications for 1856x1392 at 60& 75 hz 83-84 Timing Specifications for 1856x1392 at 120 Hz CVT (Reduced Blanking) iming Specifications for 1920x1080 at 60 Hz 1新1 86 Timing Specifications for I920x1200at60 Hz CVt( Reduced blanking)………….287 iming Specifications for 1920x1200 at 60, 75&85 Hz ∴288-90 Timing Specifications for 1920x1200 at 120 HZ CVT (Reduced Blanking) 91 Timing Specifications for 1920x 1440 at 120 HZ CVT (Reduced Blanking, Timing Specifications for 1920x1440 at 60&75 hz 92-93 94 Timing Specifications for 2048x1152 at 60 Hz(Reduced Blanking) Timing Specifications for 2560x1600 at 60 Hz CVT (Reduced Blanking) 96 Timing Specifications for 2560x1600 at 60, 75 85 HZ 97-99 Timing Specifications for 2560x1600 at 120 Hz CVT (Reduced Blanking) 100 Tables Table 1-1: Summary of Display Monitor Timings- Standards and Guidelines Table 2-1: Summary of DMT ID, sTD 2 Byte &cvt 3 Byte Codes 9 VESA Display Monitor Timing Standard Version 1.0. Rev. 12 o Copyright 1994-2008 Video Electronics Standards Association Page 3 of 100 Intellectual Property C Copyright 1994-2008 Video Electronics Standards Association. All other rights reserved While every precaution has been taken in the preparation of this standard, VESA and its contributors assume no responsibility for errors or omissions, and make no warrantieS, expressed or implied, of functionality or suitability for any purpose. Trademarks All trademarks used in this document are property of their respective owners. VESA is a trademark of the Video electronics standards association Patents VESa draws attention to the fact that it is claimed that compliance with this specification may involve the use of a patent or other intellectual property right(collectively, "PR"). VESa takes no position concerning the evidence, validity, and scope of this IPR Attention is drawn to the possibility that some of the elements of this vESa Specification may be the subject of IPR other than those identified above( Silicon Image). VESA shall not be held responsible for identifying any or all such IPR, and has made no inquiry into the possible existence of any such IPR THIS SPECIFICATION IS BEING OFFERED WITHOUT ANY WARRANTY WHATSOEVER. AND IN PARTICULAR. ANY WARRANTY OF NON-INFRINGEMENT IS EXPRESSLY DISCLAIMED ANY IMPLEMENTATION OF THIS SPECIFICATION SHALL BE MADE ENTIRELY AT THE IMPLEMENTERS OWN RISK. AND NEITHER VESA NOR ANY OF ITS MEMBERS OR SUBMITTERS SHALL HAVE ANY LIABILITY WHATSOEVER TO ANY IMPLEMENTER OR THIRD PARTY FOR ANY DAMAGES OF ANY NATURE WHATSOEVER DIRECTLY OR INDIRECTLY ARISING FROM THE IMPLEMENTATION OF THIS SPECIFICATION Support If you have a product that incorporates any of the standards in this document, you should ask the company that manufactured your product for assistance. If you are a display or controller manufacturer, VESA can assist you with any clarifications you may require. All comments or reported errors should be submitted in writing to VESA using one of the following method ax: 408-957-9277, Technical Support Email: support(a vesa. org Mail: Video electronics Standards association 860 Hillview Ct. Suite 150 Milpitas, ca 95035 VESA Display Monitor Timing Standard Version 1.0. Rev. 12 o Copyright 1994-2008 Video Electronics Standards Association Page 4 of 100 Revision History Version 1.0 Revision 0.0 Sept. 12, 1994 Initial Release of the Standard Version 1.0 revision o1 Oct 10, 1994 Fixed sync polarity of 1024x768@ 60& 70 Hz. Removed page numbers so new timings could be added Version 0 Revision 0.2 Nov 4, 1994 Added notes comments to clarify timing of interlaced modes Version 1.0 revision 0.3 Feb 16, 1995 Fixed miscellaneous typos Version 1.o revision 0.4 May 4, 1995 Added EDID IDs for DDC, fixed 1024x768 interlace vertical times Version l o revision 0.5 June 14, 1995 Added BiOS mode #s, fixed miscellaneous typos Version 1. 0 Revision 0.6 pril 10, 1996 Added new modes from VDMTPROP V10, Ro. 6 passed in March1996(85 Hz stds,ll52x864a75,1280x960a60) Version 1.0 Revision 0.6a Sept.8, 1996 Reformatted to Word 6 for electronic distribution Version 1. 0 Revision 0.7 Dec. 18, 1996 Added new modes from VDMTREVVI.O, RO.8 passed in Dec.1996(1280x1024a60,1600x1200a60,65,70,75,85 Version 1.0 Revision 0.8 July22,1998 Added1792x1344,1856X1392&1920x1440ll60,75Hz Corrected EDId code for 1600x 1200(@85 Hz Version 1.0 Revision 0.9 Ag.21,2003 Added848x480@60H,CVT1280x768tMT 1360x768(@60 Hz, CVT 1400x1050 timings, &c 1920x1200 timings based on uS japan workgroup requests Version 1.0 Revision 10 July 14, 2004 Added CVt 1.30MA(1440x900 ) CVT 1. 76MA (1680x1050)formats Version 1.0 Revision l1 May 1, 2007 Added several DMT CVT Reduced Blanking Timings, 1280X800c60/7585 Hz timings,2560x1600a60/75/85Hz and dmt Ids Version 1.0 Revision 12 Nov 17, 2008 Added timing definitions for 1280x720(@ 60Hz, 1366x768@ 60 Hz(Normal reduced Blanking), 1600x900(@ 60 |
