我的keil是5.37
今早编译正点原子的STM32F407的demo,编译不了,重装了keil也不行;
试试编译之前自己的工程,也不行,不知道咋啦;
- Error: C9555E: Failed to check out a license.
- The license file could not be found. Check that ARMLMD_LICENSE_FILE is set correctly.
- ARMLMD_LICENSE_FILE is not set. You must set this to the path to your license.
- Information about this error is available at: http://ds.arm.com/support/lic87/m1
- General licensing information is available at: http://ds.arm.com/support/licensing/
- If you need further help, provide this complete error report to your supplier or license.support@arm.com.
- - ARMLMD_LICENSE_FILE: unset
- - LM_LICENSE_FILE: unset
- - ARM_TOOL_VARIANT: unset
- - ARM_PRODUCT_PATH: unset
- - Product location: C:\Keil_v5\ARM\sw\mappings
- - Toolchain location: C:\Keil_v5\ARM\Bin
- - Selected tool variant: product
- - Checkout feature: compiler5
- - Feature version: 5.0202006
- - Flex error code: -1
- Product: ARM Compiler 5.06
- Component: ARM Compiler 5.06 update 7 (build 960)
- Tool: ArmCC [4d365d]
- "..\OBJ\LED.axf" - 55 Error(s), 0 Warning(s).
- Target not created.
- Build Time Elapsed: 00:00:05
复制代码 |
