发表于 2006-7-16 01:10:19
在WINAVR的手册里就已经明确地说明了数据的类型:(贴上来大家参考)
“What registers are used by the C compiler?
• Data types:
char is 8 bits, int is 16 bits, long is 32 bits, long long is 64 bits, float and
double are 32 bits (this is the only supported floating point format), pointers
are 16 bits (function pointers are word addresses, to allow addressing the whole 128K program memory space on the ATmega devices with > 64 KB of flash
ROM). There is a -mint8 option (see Options for the C compiler avr-gcc) to
make int 8 bits, but that is not supported by avr-libc and violates C standards
(int must be at least 16 bits). It may be removed in a future release.
• Call-used registers (r18-r27, r30-r31):
May be allocated by gcc for local data. You may use them freely in assembler
subroutines. Calling C subroutines can clobber any of them - the caller is responsible for saving and restoring.
• Call-saved registers (r2-r17, r28-r29):
May be allocated by gcc for local data. Calling C subroutines leaves them unchanged. Assembler subroutines are responsible for saving and restoring these
registers, if changed. r29:r28 (Y pointer) is used as a frame pointer (points to
local data on stack) if necessary.
• Fixed registers (r0, r1):
Never allocated by gcc for local data, but often used for fixed purposes:
r0 - temporary register, can be clobbered by any C code (except interrupt handlers
which save it), may be used to remember something for a while within one piece of
assembler code r1 - assumed to be always zero in any C code, may be used to remember something for a while within one piece of assembler code, but must then be cleared after use (clr r1). This includes any use of the [f]mul[s] instructions, which return their result in r1:r0. Interrupt handlers save and clear r1 on entry, and restore r1 on exit (in case it was non-zero).
• Function call conventions:
Arguments - allocated left to right, r25 to r8. All arguments are aligned to start in even-numbered registers (odd-sized arguments, including char, have one free
register above them). This allows making better use of the movw instruction on
the enhanced core. If too many, those that don’t fit are passed on the stack.
Return values: 8-bit in r24 (not r25!), 16-bit in r25:r24, up to 32 bits in r22-r25, up to 64 bits in r18-r25. 8-bit return values are zero/sign-extended to 16 bits by the caller (unsigned char is more efficient than signed char - just clr r25). Arguments to functions with variable argument lists (printf etc.) are all passed on stack, and char is extended to int.
Warning:
There was no such alignment before 2000-07-01, including the old patches for
gcc-2.95.2. Check your old assembler subroutines, and adjust them accordingly.
