发表于 2006-9-28 22:23:43
重点:(注意:本例程一定要将串口的2,3脚短联做自发自收演示)
procedure TForm1.Button1Click(Sender: TObject);
var
i: integer;
str: string;
begin
str := '';
for i := 0 to 2047 do
begin
str := str + Char(i and $ff);//所有字符0x00~0xff
end;
Comm1.PortOpen := true;//打开串口(注意:本例将串口的2,3脚短联做自发自收演示)
Comm1.Output := str;//发送2048个字符到串口
end;
procedure TForm1.Comm1ReceiveData(Sender: TObject; Buffer: PAnsiChar;//旧事件处理方法用Buffer: Pointer
BufferLength: Word);
var
i: integer;
str: string;
begin
Memo1.Lines.Add('SPCOMM控件改造应用方法一:(String)');
SetString(str, Buffer, BufferLength);//从串口接收BufferLength个字节
if Length(str) <> BufferLength then Exit;
for i := 0 to BufferLength - 1 do
begin
if (i and $f) = 0 then
begin
Buffers := inttohex(i, 4) + ': ';
end;
if (i and $ff) = Byte(str[i + 1]) then//str从str[1]开始
Buffers := Buffers + '0x' + inttohex(Byte(str[i + 1]), 2) + ' '
else //接收错误显示
Buffers := Buffers + '**/' + inttohex(Byte(str[i + 1]), 2) + ' ';
if (i and $f) = $f then
begin
Memo1.Lines.Add(Buffers);//输出一行显示数据
Buffers := '';
end;
end;
Memo1.Lines.Add('');
Memo1.Lines.Add('SPCOMM控件改造应用方法二:(Array)');
begin
begin
end;
if (i and $ff) = Byte(Buffer) then//Buffer从Buffer[0]开始
Buffers := Buffers + '0x' + inttohex(Byte(Buffer), 2) + ' '
else //接收错误显示
Buffers := Buffers + '**' + inttohex(Byte(Buffer), 2) + ' ';
begin
Buffers := '';
end;
end;
Memo1.Lines.Add('SPCOMM控件改造应用方法三:(Pointer)');
begin
begin
end;
if (i and $ff) = Byte((Buffer + i)^) then//Buffer+i从Buffer开始
Buffers := Buffers + '0x' + inttohex(Byte((Buffer + i)^), 2) + ' '
else //接收错误显示
Buffers := Buffers + '**' + inttohex(Byte((Buffer + i)^), 2) + ' ';
begin
Buffers := '';
end;
end;
Memo1.Lines.Add('SPCOMM控件改造应用方法四:(Pointer)');
begin
begin
end;
if (i and $ff) = Byte(Buffer^) then
Buffers := Buffers + '0x' + inttohex(Byte(Buffer^), 2) + ' '
else //接收错误显示
Buffers := Buffers + '**' + inttohex(Byte(Buffer^), 2) + ' ';
begin
Buffers := '';
end;
Inc(Buffer, SizeOf(Char));//移动字符指针
end;
end; |
