昨天焊了一个板子,写了一个非常简单的程序,通过ISP写入,运行正常,但是我又把程序放在AVR STDIO4里面纯软件仿真,在TIMER中断的入口加个断电,发现不能进入TIMER中断,奇怪.同时 PORTA口也没有变化.请马老师谈谈在AVRSTDIO纯软件仿真时遇到类似问题的解决方法.
#include <iom16v.h>
#include <macros.h>
void init_devices(void);
const unsigned char digital[10]={0xFC,0x18,0xF2,0xBA,0x1E,0xAE,0xEE,0x38,0xFE,0xBE}; //数码管显示数字的预定义
unsigned char index=0; //显示数字的索引
init_devices();
while(1) //主循环
WDR(); //清看门狗
void port_init(void)
PORTA = 0xFF; //高电平数码管灭,低电平亮
DDRA = 0xFF; //PA口输出状态,连接数码管
PORTB = 0x00;
DDRB = 0x00;
PORTC = 0x00; //m103 output only
DDRC = 0x00;
PORTD = 0x00;
DDRD = 0x00;
//TIMER1 initialize - prescale:256
// WGM: 0) Normal, TOP=0xFFFF
// desired value: 1Hz
// actual value: 1.000Hz (0.0%)
void timer1_init(void)
TCCR1B = 0x00; //stop
TCNT1H = 0x57; //setup
TCNT1L = 0x41;
OCR1AH = 0xA8;
OCR1AL = 0xBF;
OCR1BH = 0xA8;
OCR1BL = 0xBF;
//OCR1CH = $OCR1CH$;
//OCR1CL = $OCR1CL$;
ICR1H = 0xA8;
ICR1L = 0xBF;
TCCR1A = 0x00;
TCCR1B = 0x04; //start Timer
//时钟中断服务函数,1秒钟执行一次
#pragma interrupt_handler timer1_ovf_isr:9
void timer1_ovf_isr(void)
//TIMER1 has overflowed //这里加断电不能断掉.
TCNT1H = 0x57; //reload counter high value
TCNT1L = 0x41; //reload counter low value
PORTA=~digital[index];
UDR=index;
index++;
if(index>=10)index=0;
//UART0 initialize
// desired baud rate: 9600
// actual: baud rate:9600 (0.0%)
// char size: 8 bit
// parity: Disabled
void uart0_init(void)
UCSRB = 0x00; //disable while setting baud rate
UCSRA = 0x00;
UCSRC = BIT(URSEL) | 0x06;
UBRRL = 0x47; //set baud rate lo
UBRRH = 0x00; //set baud rate hi
UCSRB = 0x18;
//call this routine to initialize all peripherals
//stop errant interrupts until set up
CLI(); //disable all interrupts
port_init();
timer1_init();
uart0_init();
MCUCR = 0x00;
GICR = 0x00;
TIMSK = 0x04; //timer interrupt sources
SEI(); //re-enable interrupts
//all peripherals are now initialized
