The first sector of cluster 2 (the data region of the disk) is computed using the BPB fields for the
volume as follows. First, we determine the count of sectors occupied by the root directory:
RootDirSectors = ((BPB_RootEntCnt * 32) + (BPB_BytsPerSec – 1)) / BPB_BytsPerSec;
以下是BPB_RootEntCnt的说明:
BPB_RootEntCnt For FAT12 and FAT16 volumes, this field contains the count of 32-
byte directory entries in the root directory. For FAT32 volumes,
this field must be set to 0. For FAT12 and FAT16 volumes, this
value should always specify a count that when multiplied by 32
results in an even multiple of BPB_BytsPerSec. For maximum
compatibility, FAT16 volumes should use the value 512.
大家看看RootDirSectors = ((BPB_RootEntCnt * 32) + (BPB_BytsPerSec – 1)) / BPB_BytsPerSec;是怎么得出来的?望指教!谢谢!!
-----此内容被mcuhost于2007-06-07,10:18:48编辑过 |
