发表于 2007-9-14 16:40:01
USBprog - An open source all purpose tool (AVRISP mkII, ARM7/ARM9, JTAG, RS232, IO)
usbprog 3.0 (preassembled)
usbprog 2.0 Kit
usbprog adapter - The kit ist available for 22 EUR and the
preassembled adaptor is available for 32 EUR click here.
New hardware version 3.0 is now available. Read more!
AVRISP mk2 clone OpenOCD Adapter
USBprog Flashtool for Windows Installer.exe
usbprog Online (Program for Linux and Windows)
100% open source, all plans and source codes are open!
1. What is usbprog?
usbprog is a free programming adapter. You can easily install different firmware versions from an "online pool" over USB. The adapter can be used for programming and debugging AVR and ARM processors, as USB to RS232 converter, as JTAG interface or as simple I/O interface (5 lines).
2. Who needs usbprog?
Hardware and software developers who work with Windows, Linux and other operating systems.
3. What is so special about the concept of usbprog?
Given time, there will be a growing pool of firmware versions. If you have to work with a new module you will ideally find the matching firmware to program or connect to this new module in the online pool.
If there is no matching firmware for the required module you shouldn't hastily buy a far too expensive adapter, but ask if it paid to write a new firmware for usbprog and thus to invest in the firmware pool. Often it is done quite quickly, because you can enhance existing software tools. Like in the case of the AVRISP mk2 clone that can be used with every application that supports the original adapter of Atmel, or the adapter for the OpenOCD, a product developed within 2 to 3 days.
As the whole project is an open source project, it should be interesting for a long time!
If you have any questions, information or criticism feel free to write an email to sauter@ixbat.de
Abstract of the FIRMWARE pool:
AVRISP mk2 clone (more)
OpenOCD Interface (ARM Debugging) (more) NEW!!!
SimplePort (6 I/O lines)
USB to RS232 converter (without drivers!!)
JTAGICE mk2 clone (under development)
The software on the adapter can be directly changed by the consisting USB connection via an easy to use update mechanism. This works easily with a graphical programm, available for Windows and Linux.
The hardware can be ordered as a kit including PCB in our ==> online shop
Therefore the schemes are available in our downloads section (schematic circuit diagram, PCB layout, etc.).
