查询一个文件的开始簇
unsigned int baseentry = 0;
unsigned int entrycount = 0;
unsigned long fatGetDirEntry(unsigned int entry)
unsigned long sector;
struct direntry *de = 0; // 防止compiler warning
struct winentry *we;
unsigned int hasBuffer;
unsigned int b;
int i,index;
char *p;
entrycount = 0;
DirNameBuffer = 0;
// 读取目录区数据
sector = fatClustToSect(FirstDirSector);
hasBuffer = 0;
index = 16;
do
if(index == 16) // 是否该一人一扇区time for next sector ?
ReadBlock(sector++);
de = (struct direntry *)BUFFER;
index = 0;
if(*de->deName != 0xE5)
// 如果if not a deleted entry
if(de->deAttributes == ATTR_LONG_FILENAME)//长文件名
// we have a long name entry
we = (struct winentry *) de;
b = 13 *( (we->weCnt-1) & 0x0f); // index into string
p = &LongNameBuffer;
for (i=0;i<5;i++) *p++ = we->wePart1[i*2]; // copy first part
for (i=0;i<6;i++) *p++ = we->wePart2[i*2]; // second part
for (i=0;i<2;i++) *p++ = we->wePart3[i*2]; // and third part
if (we->weCnt & 0x40) *p = 0; // in case dirnamelength is multiple of 13
if ((we->weCnt & 0x0f) == 1) hasBuffer = 1; // mark that we have a long entry
// we have a short name entry
// check if this is the end of a multi-part long name entry
if(hasBuffer)
// a long entry name has been collected
// is it a directory ?
if(de->deAttributes == ATTR_DIRECTORY)
unsigned long save = FirstDirSector;
unsigned int save2 = baseentry;
unsigned long rval;
strcpy(DirNameBuffer,LongNameBuffer);
strcat(DirNameBuffer,"/");
// rprintfStr(LongNameBuffer); rprintfProgStrM("/"); //EOL();
// call recursively
FirstDirSector = ((unsigned long)de->deHighClust << 16) + de->deStartCluster;
rval = fatGetDirEntry(entry);
FirstDirSector = save;
baseentry = save2;
if (rval)
return rval;
// reload original sector
ReadBlock(sector-1);//ataReadSectors( DRIVE0, sector-1, 1, SectorBuffer);
entrycount--; // decrement entry counter
*DirNameBuffer = 0;
else // normal file entry
if(entrycount == entry)
hasBuffer = 0; // clear buffer
entrycount++; // increment entry counter
// else ignore short_name_only entries
de++;
index++;
} while (*de->deName || index == 16); // 0 in de->deName[0] if no more entries
if (hasBuffer == 0) // end of entries
return 0;
FileSize = de->deFileSize;
LCD_write_english_string(0,1,LongNameBuffer);
return (unsigned long) ((unsigned long)de->deHighClust << 16) + de->deStartCluster;
