发表于 2011-5-26 19:35:28
Component List:
C1 = 2000uF per AMP, 40V (adjust capacity to power supply amps)
C2,C3,C12,C15,C18,C21 = 0.1uF CER
C4 = 0.01uF CER
C5A,C5B,C5C,C5D = 0.01uF CER
C6,C7 = 0.05uF CER
C8 = Not used
C9,C11,C19,C20 = 1uF CER
C10 = 470uF 15V EL RADIAL
C13 = 4.7礔 50V EL RADIAL
C14 = 0.001uF CER
C16,C17 = 22pF CER
D1,D2,D4,D5 = 1N4148
D3 = 1N4004
Br1 = 1<10A BRIDGE RECTIFIER (adjust seize to power supply amps)
DZ1 = 1N4751 30V ZENER
IC1 = LM317KCS TO220
IC2 = LM337LZ TO92
IC3 = LT1491CN special HV opamp, do not substitute
IC4 = PIC16F876A
Q1 = 2N3906
Q2A to Q2D = TIP142TU 1 to 5 transistors (adjust quantity to power supply amps)
Q3A to Q3D = 2N3904 (adjust quantity to power supply amps)
X1 = 20 mHz HC49 DigiKey PN: 300-6042-ND
LED1 = T1 3/4 RED OR GREEN LED
LCD = LCD, 2X16, HD44780 intelligent controller DigiKey PN: 67-1758-ND insulate from case
P1 = 500 Ohms
P2 = 10 kOhms
P3,P4 = 5 kOhms
R1 = 1 kOhms 10W
R2 = 1.5 kOhms
R3,R11,R12,R13,R14,R16,R17,R25,R26,R27 = 10 kOhms
R4 = 56 Ohms
R5A to R5D = 0.22 Ohms (adjust quantity to power supply amps)
R6,R28,R29 = 47k Ohms
R7 = as per schematic (adjust value to power supply amps)
R8 = 240 Ohms
R9 = 270 Ohms
R10 = 390 Ohms
R15 = 39 kOhms
R18 = 39 kOhms
R19 = 8.2 kOhms
R20,R22,R23,R32 = 1 kOhms
R21 = 5.6 kOhms
R24 = 33 Ohms 1/2W
R30,R31 = 4.7 kOhms
SW1 = SPST min toggle
SW2,SW3,SW4,SW5,SW6,SW7,SW8,SW9 = NO_SP push button
T1 = 24 V 1<8A (adjust seize to power supply amps)
T2 = 6.3 V, 150 mA
MISC:
3 Terminals
Transistors Heat Sink, up to: 1A = 30W, 2A = 60W, 4A = 120W, 8A = 240W to dissipate
Line filter, Case PCB, IC sockets� |
