发表于 2008-4-9 09:53:25
是不是ADCS1:ADCS0设置,我不知你是用ASM还是C。给你一个CCSC的例子
//// EX_ADMM.C ////
//// This program displays the min and max of 30 A/D samples over ////
//// the RS-232 interface. The process is repeated forever. ////
//// If required configure the CCS prototype card as follows: ////
//// Insert jumper from output of POT to pin A5 ////
//// Use a 10K POT to vary the voltage. ////
//// Jumpers: ////
//// PCM,PCH pin C7 to RS232 RX, pin C6 to RS232 TX ////
//// PCD none ////
//// This example will work with the PCM, PCH, and PCD compilers. ////
//// The following conditional compilation lines are used to ////
//// include a valid device for each compiler. Change the device, ////
//// clock and RS232 pins for your hardware if needed. ////
//// (C) Copyright 1996,2007 Custom Computer Services ////
//// This source code may only be used by licensed users of the CCS ////
//// C compiler. This source code may only be distributed to other ////
//// licensed users of the CCS C compiler. No other use, ////
//// reproduction or distribution is permitted without written ////
//// permission. Derivative programs created using this software ////
//// in object code form are not restricted in any way. ////
#if defined(__PCM__) // Preprocessor directive that chooses the compiler
#include <16F877.h> // Preprocessor directive that selects the chip
#fuses HS,NOWDT,NOPROTECT,NOLVP // Preprocessor directive that defines the chip fuses
#use delay(clock=20000000) // Preprocessor directive that specifies clock speed
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7) // Preprocessor directive that includes RS232 libraries
#elif defined(__PCH__)
#include <18F452.h>
#elif defined(__PCD__)
#include <30F2010.h>
#fuses HS,NOWDT
#device ADC=8
#use rs232(baud=9600, UART1A)
void main() {
unsigned int8 i, value, min, max;
printf("Sampling:"); // Printf function included in RS232 library
#ifdef __PCD__
setup_adc_ports(sAN0); // Built-in A/D setup function
#else
setup_adc_ports(AN0);
setup_adc(ADC_CLOCK_INTERNAL); // Built-in A/D setup function
set_adc_channel(0); // Built-in A/D setup function
do {
min=255;
max=0;
for(i=0; i<=30; ++i) {
delay_ms(100); // Built-in delay function
value = read_adc(); // Built-in A/D read function
if(value<min)
min=value;
if(value>max)
max=value;
printf("\r\nMin: %2X Max: %2X\n\r",min,max);
} while (TRUE);
