4月17号linux-2.6.25稳定版发布,伟研科技 http://www.gzweiyan.com 将该内核移植到S3C2440平台上,下面是我们移植的第一步:
编译内核:
1) 解压内核,当前目录为/new_disk/weiyan/
tar jxf /new_disk/weiyan/linux-2.6.25.tar.bz2
cd linux-2.6.25
2) 修改体系架构并指定交叉编译器
vi Makefile ,将193行和194行的
#ARCH ?= $(SUBARCH)
#CROSS_COMPILE ?=
修改为
ARCH ?= arm
CROSS_COMPILE ?= arm-linux- #最后有“—”,Makefile会调用arm-linux-gcc
3) 载入默认配置
make s3c2410_defconfig
make menuconfig
按Esc键保存退出。
4) 添加生成U-Boot镜像的工具
cp /new_disk/weiyan/mkimage ./
vi scripts/mkuboot.sh ,将
MKIMAGE=$(type -path "${CROSS_COMPILE}mkimage")
修改为MKIMAGE=$PWD/mkimage
vi arch/arm/mach-s3c2440/mach-smdk2440.c
5) 添加nand划分信息
static struct mtd_partition wy_nand_part[] = {
[0] = { //u-boot及内存存放的分区
.name = "BOOT",
.size = SZ_2M,
.offset = 0,
[1] = { //文件系统存放的分区
.name = "ROOTFS",
.offset = SZ_2M,
.size = SZ_32M,
[2] = { //剩余空间
.name = "BACKUP",
.offset = SZ_32M + SZ_2M,
.size = SZ_32M - SZ_2M,
static struct s3c2410_nand_set wy_nand_sets[] = {
[0] = {
.name = "NAND",
.nr_chips = 1,
.nr_partitions = ARRAY_SIZE(wy_nand_part),
6) 添加nand flash的读写匹配时间,各时间定义如图
static struct s3c2410_platform_nand wy_nand_info = {
.tacls = 10,
.twrph0 = 25,
.twrph1 = 10,
.nr_sets = ARRAY_SIZE(wy_nand_sets),
.sets = wy_nand_sets,
.partitions = wy_nand_part,
7) 添加支持硬件校验:
make menuconfig
Device Drivers --->
<*> Memory Technology Device (MTD) support --->
<*> NAND Device Support ---> S3C2410 NAND Hardware ECC
8) 编译并拷贝到tftp下载目录
make uImage && cp arch/arm/boot/uImage /new_disk/tftp
Image Name: Linux-2.6.25
Created: Mon Apr 7 13:50:19 2008
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 1591184 Bytes = 1553.89 kB = 1.52 MB
Load Address: 0x30008000
Entry Point: 0x30008000
Image arch/arm/boot/uImage is ready
启动新内核:
dm9000 i/o: 0x18000300, id: 0x90000a46
MAC: 00:0c:20:02:0a:5b
TFTP from server 192.168.1.5; our IP address is 192.168.1.6
Filename 'uImage'.
Load address: 0x31000000
Loading: #################################################################
done
Bytes transferred = 1591268 (1847e4 hex)
## Booting image at 31000000 ...
Data Size: 1591204 Bytes = 1.5 MB
Load Address: 30008000
Entry Point: 30008000
Verifying Checksum ... OK
OK
Starting kernel ...
Uncompressing Linux....................................................................................................... done, booting the kernel.
Linux version 2.6.25 (root@ubuntu-server) (gcc version 3.4.1) #4 Mon Apr 21 04:28:37 CST 2008
CPU: ARM920T [41129200] revision 0 (ARMv4T), cr=c0007177
Machine: SMDK2440
Memory policy: ECC disabled, Data cache writeback
CPU S3C2440A (id 0x32440001)
S3C244X: core 406.425 MHz, memory 135.475 MHz, peripheral 67.737 MHz
S3C24XX Clocks, (c) 2004 Simtec Electronics
CLOCK: Slow mode (2.116 MHz), fast, MPLL on, UPLL on
CPU0: D VIVT write-back cache
CPU0: I cache: 16384 bytes, associativity 64, 32 byte lines, 8 sets
CPU0: D cache: 16384 bytes, associativity 64, 32 byte lines, 8 sets
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
Kernel command line: root=/dev/mtdblock1 rootfstype=jffs2 console=ttySAC0 ip=192.168.1.6:192.168.1.5:192.168.1.5:255.255.255.0:WEIYAN:eth0:off
S3C24XX NAND Driver, (c) 2004 Simtec Electronics
s3c2440-nand s3c2440-nand: Tacls=2, 14ns Twrph0=4 29ns, Twrph1=2 14ns
NAND device: Manufacturer ID: 0xec, Chip ID: 0x76 (Samsung NAND 64MiB 3,3V 8-bit)
Scanning device for bad blocks
Creating 3 MTD partitions on "NAND 64MiB 3,3V 8-bit":
0x00000000-0x00200000 : "BOOT"
0x00200000-0x02200000 : "ROOTFS"
0x02200000-0x04000000 : "BACKUP"
Empty flash at 0x0096200c ends at 0x00962200
Empty flash at 0x01470628 ends at 0x01470800
jffs2_scan_eraseblock(): Node at 0x01470dfc {0x1985, 0xe001, 0xe0021985) has invalid CRC 0x00000044 (calculated 0x515918d5)
VFS: Mounted root (jffs2 filesystem).
Freeing init memory: 140K
JFFS2 notice: (775) check_node_data: wrong data CRC in data node at 0x01470578: read 0x5cc80399, calculated 0x36a47240.
init started: BusyBox v1.9.1 (2008-04-19 19:49:32 CST)
starting pid 777, tty '': '/etc/init.d/rcS'
starting initial script, WEIYAN
Please press Enter to activate this console.
starting pid 795, tty '': '/bin/sh'
[root@WEIYAN /]$ ls
bin etc linuxrc opt sbin tmp var
dev lib mnt proc sys usr
[root@WEIYAN /]$
以下蓝色文字由站长:armok 于:2008-04-30,05:23:24 加入。 你的原标题:“<font color=black>Linux-2.6.25移植” 不合符规定。请更改成能说明帖子大意的标题
试想一下,如果本论坛的帖子标题清一色的‘帮助!’,‘ADC求救!’等笼统的标题,你在阅读的过程中会造成许多麻烦。
所以本论坛规定:一定要起一个能说明帖子大意的标题。不允许“关于 AVR 的 ADC 使用!”这种笼统标题。作为标题,必须说明清楚:
①你是在请教问题,还是在介绍有关的知识?
②ADC的问题有许多,你是想说那方面的内容?
注意以上两点,标题应该改成如:“请教:ADC 可以不使用中断吗?”。
起一个能说明帖子大意的标题,除了减轻我们的帖子分类整理工作,还方便其它人阅读,节省大家的时间。
注:使用合格的标题,对你来说只是举手之劳,但却会为我们的管理工作提供很大的便利。谢谢你的支持。
