发表于 2010-10-20 00:01:56
startup.c的代码如下
// startup.c - Boot code for Stellaris.
// Copyright (c) 2005-2007 Luminary Micro, Inc. All rights reserved.
// Software License Agreement
// Luminary Micro, Inc. (LMI) is supplying this software for use solely and
// exclusively on LMI's microcontroller products.
// The software is owned by LMI and/or its suppliers, and is protected under
// applicable copyright laws. All rights are reserved. You may not combine
// this software with "viral" open-source software in order to form a larger
// program. Any use in violation of the foregoing restrictions may subject
// the user to criminal sanctions under applicable laws, as well as to civil
// liability for the breach of the terms and conditions of this license.
// THIS SOFTWARE IS PROVIDED "AS IS". NO WARRANTIES, WHETHER EXPRESS, IMPLIED
// OR STATUTORY, INCLUDING, BUT NOT LIMITED TO, IMPLIED WARRANTIES OF
// MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE APPLY TO THIS SOFTWARE.
// LMI SHALL NOT, IN ANY CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL, OR
// CONSEQUENTIAL DAMAGES, FOR ANY REASON WHATSOEVER.
// This is part of revision 1928 of the Stellaris Peripheral Driver Library.
// Enable the IAR extensions for this source file.
#pragma language=extended
// Forward declaration of the default fault handlers.
void ResetISR(void);
static void NmiSR(void);
static void FaultISR(void);
static void IntDefaultHandler(void);
extern void Timer0A_ISR(void);
extern void Timer1A_ISR(void);
extern void SysTick_ISR(void);
// The entry point for the application.
extern int main(void);
// Reserve space for the system stack.
#ifndef STACK_SIZE
#define STACK_SIZE 64
static unsigned long pulStack[STACK_SIZE];
// A union that describes the entries of the vector table. The union is needed
// since the first entry is the stack pointer and the remainder are function
// pointers.
typedef union
void (*pfnHandler)(void);
unsigned long ulPtr;
uVectorEntry;
// The minimal vector table for a Cortex M3. Note that the proper constructs
// must be placed on this to ensure that it ends up at physical address
// 0x0000.0000.
__root const uVectorEntry g_pfnVectors[] @ "INTVEC" =
{ .ulPtr = (unsigned long)pulStack + sizeof(pulStack) },
// The initial stack pointer
ResetISR, // The reset handler
NmiSR, // The NMI handler
FaultISR, // The hard fault handler
IntDefaultHandler, // The MPU fault handler
IntDefaultHandler, // The bus fault handler
IntDefaultHandler, // The usage fault handler
0, // Reserved
0, // Reserved
0, // Reserved
0, // Reserved
IntDefaultHandler, // SVCall handler
IntDefaultHandler, // Debug monitor handler
0, // Reserved
IntDefaultHandler, // The PendSV handler
SysTick_ISR, // The SysTick handler
IntDefaultHandler, // GPIO Port A
IntDefaultHandler, // GPIO Port B
IntDefaultHandler, // GPIO Port C
IntDefaultHandler, // GPIO Port D
IntDefaultHandler, // GPIO Port E
IntDefaultHandler, // UART0 Rx and Tx
IntDefaultHandler, // UART1 Rx and Tx
IntDefaultHandler, // SSI Rx and Tx
IntDefaultHandler, |
