首先请大家看下这两个初始化程序对不:
unsigned short *SD_DataAdd =(unsigned short *)0xb0000020;//
unsigned short *SD_DataAdd1 =(unsigned short *)0xb0000024;//
unsigned short *SD_DataAdd2 =(unsigned short *)0xb0000028;//
unsigned short *SD_DataAdd3 =(unsigned short *)0xb000002c;//
unsigned short *SD_DataAdd4 =(unsigned short *)0xb0000030;//
void SPI_Init()
*SD_DataAdd1 = 0xa2;
*SD_DataAdd3 = 0x00;
int sd_init(void)
UINT8 resp,cnt=0;
int ret,i;
ret = sd_reset(); /*reset SD*/
if(ret != 0) /*reset fail*/
return -1;
do{ /*send CMD1 to init*/
SD_DISABLE;
spi_write_out(0xff);
for(i=0; i<100; i++)
SD_ENABLE;
resp = sd_command(CMD1,0); /*read respones*/
printf("%x ", resp);
cnt++;
if(cnt>=200)
SD_DISABLE;
return -1;
}while(resp != 0);
SD_DISABLE; /*disable SD*/
return 0;
我在main函数中调用这两个函数初始化,中间是不是需要延时?
延时多少时间?
延时函数怎么写最标准?
急急急急急急急急急急急急急急急急急急急急急急急急急急急急急急急急急急急急急急急急急急急 |
