各位前辈,我用的dspic30f5011做can通信用,在发送数据的时候报错,发送总线有故障,也接受不到任何数据,但是在换回模式的时候可以发送和接收数据,下面是我的程序,请各位前辈,帮忙指点一下;
/***************************************************************CAN通讯模块的控制程序**************************************************************/
#include "p30f5011.h"
#define FCY 20000000 // 5MPLL16 20 MHz
#define FCAN 20000000 // 20 MHz
#define BITRATE 125000 // 通讯波特率
#define NTQ 16 // Number of Tq cycles which will make the
//CAN Bit Timing .
#define BRP_VAL ((FCAN/(2*NTQ*BITRATE))-1) //Formulae used for C1CFG1bits.BRP
unsigned int b;
//数据缓冲的定义//发送缓冲区
unsigned int OutData0[4] = {0x5251, 0x5453, 0x5655, 0x5857};
unsigned int OutData1[2] = {0x5A59, 0x5C5B};
unsigned int OutData2[4] = {0x6261, 0x6463, 0x6665, 0x6867};
unsigned int OutData3[2] = {0x6A69, 0x6C6B};//接受缓冲区
unsigned int InData0[4] = {0, 0, 0, 0};
unsigned int InData1[2] = {0, 0};
unsigned int InData2[4] = {0, 0, 0, 0};
unsigned int InData3[2] = {0, 0};
/***************************************************************CAN通讯模块的初始化**************************************************************/
void CAN_init(void)
// TRISFbits.TRISF0=1;
// TRISFbits.TRISF1=0;
C1CTRLbits.REQOP = 0x4; //请求进入配置模式???
while (C1CTRLbits.OPMODE!=0x4){} //确认进入配置模式??
C1CTRLbits.CANCKS = 1; //Select the CAN Master Clock . It is equal to Fcy here.
// equal to Fcy.(Fcy=4Mhz)
C1CFG1bits.SJW=00; //Synchronized jump width time is 1 x TQ when SJW is equal to 00
C1CFG1bits.BRP = BRP_VAL; //((FCY/(2*NTQ*BITRATE))-1)
C1CFG2 = 0x02ed; // SEG1PH=6Tq, SEG2PH=3Tq, PRSEG=6Tq,Sample 3 times, Each bit time is 16Tq
///Interrupt Section of CAN Peripheral
C1INTF = 0; //Reset all The CAN Interrupts
IFS1bits.C1IF = 0; //Reset the Interrupt Flag status register
C1INTE = 0x00ff; //Enable all CAN interrupt sources tx0 rx0
IEC1bits.C1IE = 1;//Enable the CAN1 Interrupt
// Configure Receive registers, Filters and Masks
C1RX0CON =0x0002;
C1RX1CON = 0x0000; // Receive Buffer1 and 0 Status use fliter 2
// Acceptance Mask Register0SID and Register1SID associated with Recieve Buffer0
// and Receive Buffer1 for CAN1 and CAN2
C1RXM0SID = C1RXM1SID = 0x0001; //接收的为标准数据桢
// Acceptance Mask Register0EIDH and Register1EIDH associated with Recieve Buffer0
C1RXM0EIDH = C1RXM1EIDH = 0x0FFF;
// Acceptance Mask Register0EIDL and Register1EIDL associated with Recieve Buffer0
C1RXM0EIDL = C1RXM1EIDL = 0xFC00;
//Initializing of Acceptance Filter n Standard Identifier for CAN1
C1RXF0SID = 0x0AA8; //CAN1 Receive Acceptance Filter2 SID ??
C1RXF2SID = 0x15c0; //CAN1 Receive Acceptance Filter2 SID
C1RXF2EIDH = 0x0004; //CAN1 Receive Acceptace Filter2 Extended Identifier high byte
C1RXF2EIDL = 0x8C00; //CAN1 Receive Acceptance Filter2 Extended identifier low byte
//Initializing of Acceptance Filter n Standard Identifier for CAN2
// Configure Transmit Registers Buffer 0 and Transmit Buffer 1
C1TX0CON = 0x0003;// High priority
C1TX0SID = 0x50A8;// SID
C1TX0EID = 0x0000;// EID
C1TX0DLC = 0x01C0; //Select the Data word Length for CAN1 Transmit Buffer0 which is 8 byte
// Data Field 1,Data Field 2, Data Field 3, Data Field 4
// 8 bytes selected by DLC
C1TX0B1 = OutData0[0];
C1TX0B2 = OutData0[1];
C1TX0B3 = OutData0[2];
C1TX0B4 = OutData0[3];
C1TX1CON = 0x0002; // High Intermediate priority
C1TX1SID = 0xA860; // SID
C1TX1EID = 0x0000;// EID
C1TX1DLC = 0x8DA0; //Select the Data word Length for CAN1 Transmit Buffer1 which
// is 4 byte
//Data Field 1, Data Field 2
// 4 bytes selected by DLC
C1TX1B1 = OutData1[0];
C1TX1B2 = OutData1[1];
C1TX2CON = 0x0001; // High Intermediate priority
C1TX2SID = 0xA860; // SID
C1TX2EID = 0x0000;// EID
C1TX2DLC = 0x8DA0; //Select the Data word Length for CAN1 Transmit Buffer1 which
// is 4 byte
C1TX2B1 = OutData1[0];
C1TX2B2 = OutData1[1];
//Change to Loopback Operation Mode from Configuration Mode
// C1CTRLbits.CANCAP = 1;
C1CTRLbits.REQOP = 0;
while(C1CTRLbits.OPMODE != 0);//Wait for CAN1 mode change from Configuration Mode to Loopback mode
} //end main loop
//Interrupt Section for CAN1
unsigned int buf=0;
unsigned int buf1[8],buf2[8];
int main()
int ff;
CAN_init();
// _LATF1 = 1;
C1TX0CONbits.TXREQ = 1;
C1TX1CONbits.TXREQ = 1;
C1TX2CONbits.TXREQ = 1;
while(C1TX0CONbits.TXREQ != 0);
// b = b + 2;
for(ff = 10000;ff <= 0 ; ff --)
return 0;
void __attribute__((interrupt,auto_psv)) _C1Interrupt(void)
IFS1bits.C1IF = 0; //Clear interrupt flag
if(C1INTFbits.TX0IF)
C1INTFbits.TX0IF = 0; //If the Interrupt is due to Transmit0 of CAN1 Clear the Interrupt
if(C1INTFbits.TX1IF)
C1INTFbits.TX1IF = 0; //If the Interrupt is due to Transmit1 of CAN1 Clear the Interrupt
if(C1INTFbits.TX2IF)
C1INTFbits.TX2IF = 0; //If the Interrupt is due to Transmit1 of CAN1 Clear the Interrupt
if(C1INTFbits.RX0IF)
C1INTFbits.RX0IF = 0; //If the Interrupt is due to Receive0 of CAN1 Clear the Interrupt
InData0[0] = buf1[0]= C1RX0B1;
InData0[1] = buf1[1]=C1RX0B2; //Move the recieve data from Buffers to InData
InData0[2] = buf1[2]=C1RX0B3;
InData0[3] = buf1[3]=C1RX0B4;
C1RX0CONbits.RXFUL=0;
if ((InData0[0]==OutData0[0]) && (InData0[1]==OutData0[1]) && (InData0[2]==OutData0[2]) && (InData0[3]==OutData0[3]))
b = b +10;
if(C1INTFbits.RX1IF)
C1INTFbits.RX1IF = 0; //If the Interrupt is due to Receive1 of CAN1 Clear the Interrupt
InData1[0] =buf2[0]= C1RX1B1; //Move the data received to Indata Registers
InData1[1] = buf2[1]=C1RX1B2;
C1RX1CONbits.RXFUL=0;
if ((InData1[0]==OutData1[0]) && (InData1[1]==OutData1[1]))
b = b +2;
if(C1INTFbits.TXWAR)
b = b +4;
if(C1INTFbits.TXEP)
b = b +6;
if(C1INTFbits.TXBO)
b = b +8;
