发表于 2013-3-15 17:11:44
File Name : ADXL345.C
Description :
Author : Jones.Lee
Copyright : Jones_Workspace
Version&Date : <2012.8.26>&<V1.0>
Connector Fuction :
Notes :
/*---Head Files---*/
#include "ADXL345.h"
#include "uart.h"
#include "math.h"
/*---Variable Definition--*/
int Gravity_X = 0;
int Gravity_Y = 0;
int Gravity_Z = 0;
int Gravity[3] = { 0, 0, 0};
float Angle_X = 0;
float Angle_Y = 0;
float Angle_Z = 0;
float Angle[3] = { 0, 0, 0};
/*---Function Definiton---*/
unsigned char ReadID(void);
void ADXL345_Init(void);
void Read_Accelerate(unsigned int * pwGyroX, unsigned int * pwGyroY, unsigned int * pwGyroZ);
void Read_Accelerate_Filter(unsigned int * pwGyroX,unsigned int * pwGyroY, unsigned int * pwGyroZ);
void Read_Angle(float * pwAngleX,float * pwAngleY,float * pwAngleZ);
unsigned char Checksun(char * byData, unsigned char byLen);
unsigned char ADXL345_Read_Byte( unsigned char byAD,unsigned short int byRA);
void ADXL345_Write_Byte( unsigned char byAD,unsigned short int byRA,unsigned char DataToWrite);
void ADXL345_Read_Bytes(unsigned char byAD, unsigned char byRA,unsigned char * pData, unsigned char byCount);
void ADXL345_Write_Bytes(unsigned char byAD, unsigned char byRA,unsigned char * pData, unsigned char byCount);
/*---Macro Definition-----*/
#define IIC_ADDR 0x53 //ADXL345的地址
#define IIC_WR 0xA6 //写地址
#define IIC_RE 0xA7 //读地址
#define GREATH_DATA 3.9 // 2/0xff
#define DEG_RAD 57.32 //就是180/ 3.14
#define FLAG_RAD_DEG 1
Fuction Name : ADXL345_Init
Description :
Input parameter : Class Name Action
void
Output parameter : Class Name Action
void
Author&Date : Jones.Lee & 2012.6.28
Notes :
unsigned char MSub;
unsigned char byData[13];
//数据通信格式;设置为自检功能禁用,4线制SPI接口,低电平中断输出,13位全分辨率,输出数据右对齐,16g量程
MSub = 0x31;
byData[0] = 0x2B;
ADXL345_Write_Bytes(IIC_WR, MSub, byData, 1);
MSub = 0x1E;
byData[ 0] = 0x00; //X轴误差补偿; (15.6mg/LSB)
byData[ 1] = 0x00; //Y轴误差补偿; (15.6mg/LSB)
byData[ 2] = 0x00; //Z轴误差补偿; (15.6mg/LSB)
byData[ 3] = 0x00; //DUR 敲击延时0:禁用; (1.25ms/LSB)
byData[ 4] = 0x00; //Latent 检测第一次敲击后的延时0:禁用; (1.25ms/LSB)
byData[ 5] = 0x00; //Window 敲击窗口0:禁用; (1.25ms/LSB)
byData[ 6] = 0x01; //THREST_Act 保存检测活动阀值; (62.5mg/LSB)
byData[ 7] = 0x01; //THREST_INACT 保存检测静止阀值; (62.5mg/LSB)
byData[ 8] = 0x2B; //TIME_INACT 检测活动时间阀值; ( 1s/LSB)
byData[ 9] = 0x00; //ACT_INACT_CTL 交流直流转换位
byData[10] = 0x09; //THREST_FF 自由落体检测推荐阀值; (62.5mg/LSB)
byData[11] = 0xFF; //TIME_FF 自由落体检测时间阀值,设置为最大时间; (5ms/LSB)
byData[12] = 0x80;
ADXL345_Write_Bytes(IIC_WR, MSub, byData, 13);
MSub = 0x2C;
byData[ 0] = 0x0A; //BW_RATE
byData[ 1] = 0x28; //POWER_CTL 开启Link,测量功能;关闭自动休眠,休眠,唤醒功能
byData[ 2] = 0x00; //INT_ENABLE 所有均关闭
byData[ 3] = 0x00; //INT_MAP 中断功能设定,不使用中断
byData[ 4] = 0x00; //INT_SOURS
ADXL345_Write_Bytes(IIC_WR, MSub, byData, 4);
//FIFO模式设定,Stream模式,触发连接INT1,31级样本缓冲
// MSub = 0x31;
// byData[ 0] = 0x0B; //16G
// ADXL345_Write_Bytes(IIC_WR, MSub, byData, 1);
MSub = 0x38;
byData[ 0] = 0x9F; //FIFO_CTL 读写
Fuction Name : Read_Accelerate
Description :
unsigned int* pwGyroX
unsigned int* pwGyroY
unsigned int* pwGyroZ
void
Author&Date : Jones.Lee & 2012.10.5
Notes :
void Read_Accelerate(unsigned int * pwGyroX,unsigned int * pwGyroY, unsigned int * pwGyroZ)
unsigned char MSub;
unsigned char byData[6];
unsigned int wTemp;
MSub = 0x32;
ADXL345_Read_Bytes(IIC_WR, MSub, byData, 6);
wTemp = 0;
wTemp = byData[1] << 8;
wTemp |= byData[0];
*pwGyroX = wTemp;
wTemp = 0;
wTemp = byData[3] << 8;
wTemp |= byData[2];
*pwGyroY = wTemp;
wTemp = 0;
wTemp = byData[5] << 8;
wTemp |= byData[4];
*pwGyroZ = wTemp;
// 接收十次数据 然后截尾均值,防止出现意外
uint32 wGyroX[10],wGyroY[10],wGyroZ[10];
uint8 i;
for(i = 0;i < 10; i++ )
Read_Accelerate(&wGyroX[i],&wGyroY[i],&wGyroZ[i]);
//* pwGyroX =Trimmean(wGyroX,10);
//* pwGyroY =Trimmean(wGyroY,10);
unsigned char i;
// unsigned char cnt;
// static unsigned int err_mid[3];
unsigned int mid[3];
short int mids[3];
double midf[3];
unsigned int greath;
unsigned short int m;
greath = greath; //消除Warning
m = m;
Read_Accelerate(mid,mid+1,mid+2);
for(i = 0; i < 3; i++)
mids[i] = mid[i];
midf[i] = mids[i];
midf[i] = ((midf[i]*GREATH_DATA)); // GREATH_DATA表示 3.9mg/LSB
#if 0 //这种算法很简单,但是不好。有误差
greath = sqrt(pow(midf[0],2)+pow(midf[1],2)+pow(midf[2],2));
*pwAngleX =asin(midf[0]/greath); //x轴的偏角
*pwAngleY =asin(midf[1]/greath);
*pwAngleZ =asin(midf[2]/greath);
#else //这种算法很复杂,建立模型,但是很简单,我套用公式,也懂了
*pwAngleX = atan( midf[0] / ( sqrt( pow( midf[1] , 2 ) + pow( midf[2] ,2 ))));//x轴的偏角
*pwAngleY = atan( midf[1] / ( sqrt( pow( midf[0] , 2 ) + pow( midf[2] , 2))));
*pwAngleZ = atan( ( sqrt( pow( midf[0] , 2 ) + pow( midf[1] , 2))) / midf[2]);
#if FLAG_RAD_DEG //转化为角度。
*pwAngleX *=DEG_RAD;
*pwAngleY *=DEG_RAD;
*pwAngleZ *=DEG_RAD;
#if 0 //检验 在运行 清零
if(*pwAngleX<0)
*pwAngleX *=-1;
UART_Send_Byte('s');
UART_Send_Byte('x');
m = *pwAngleX;
INT_ASC(m);
if(*pwAngleY<0)
*pwAngleY *=-1;
UART_Send_Byte('y');
m = *pwAngleY;
INT_ASC(m);
if(*pwAngleZ<0)
*pwAngleZ *=-1;
UART_Send_Byte('z');
m = *pwAngleZ;
INT_ASC(m);
UART_Send_Byte(0x0D);
UART_Send_Byte(0x0A);
Fuction Name : Checksun
Description :
char * byData
unsigned char byLen
unsigned char
Notes :
unsigned char i;
char byChecksum;
byChecksum = 0;
for (i = 0; i < byLen; i++)
byChecksum += byData[i];
return byChecksum;
void ADXL345_Write_Byte(uint8 byAD,uint16 byRA, uint8 DataToWrite)
I2C_Send_Ctrl(byAD); //发送ADXL地址
I2C_Send_Byte(byRA); //发送地址
I2C_Send_Byte(DataToWrite); //发送字节
I2C_Stop();//产生一个停止条件
delay_ms(3);// 这个延时绝对不能去掉
uint8 ADXL345_Read_Byte(uint8 byAD,uint16 byRA)
unsigned char temp=0;
I2C_Send_Ctrl(byAD); //先呼叫从机为写模式
I2C_Send_Byte(byRA); //发送写地址
I2C_Send_Ctrl(byAD+1); //转为读模式
temp=I2C_Recieve_Byte();
I2C_Stop(); //产生一个停止条件
return temp;
while(byCount)
*pData++=ADXL345_Read_Byte(byAD,byRA++);
byCount--;
while(byCount--)
ADXL345_Write_Byte(byAD,byRA,*pData);
byRA++;
pData++;
