F28069 AD连续转换问题,配置了但是进不去中断了,怎么回事?? 1段配置死活进不去中断,2可以,但是是定时器触发的,但是我想配置成连续转换的,不要定时器触发模式,参考http://www.deyisupport.com/quest ... /p/23308/79645.aspx 这个还是没搞懂,求解!!
/*1:这段不正常*/
// Configure ADC
EALLOW;
AdcRegs.ADCCTL1.bit.ADCREFSEL = 1; // Page485 选择外部VREF
AdcRegs.ADCCTL2.bit.ADCNONOVERLAP = 0; // Enable non-overlap mode 0允许重叠/1不允许
AdcRegs.INTSEL1N2.bit.INT1E = 1; //Enabled ADCINT1
AdcRegs.INTSEL1N2.bit.INT1CONT = 0; //Disable ADCINT1 Continuous mode
AdcRegs.INTSEL1N2.bit.INT1SEL = 1; //setup EOC1 to trigger ADCINT1 to fire
AdcRegs.ADCSAMPLEMODE.bit.SIMULEN0 = 1; // 同时采样
AdcRegs.ADCSOC0CTL.bit.CHSEL = 0; //set SOC0 channel select to ADCINA0
AdcRegs.ADCSOC1CTL.bit.CHSEL = 8; //set SOC1 channel select to ADCINB0
AdcRegs.ADCSOC0CTL.bit.TRIGSEL = 0; //set SOC0 start trigger on software
AdcRegs.ADCSOC1CTL.bit.TRIGSEL = 0; //set SOC1 start trigger on software
AdcRegs.ADCSOC0CTL.bit.ACQPS = 6; //set SOC0 S/H Window to 7 ADC Clock Cycles, (6 ACQPS plus 1)
AdcRegs.ADCSOC1CTL.bit.ACQPS = 6; //set SOC0 S/H Window to 7 ADC Clock Cycles, (6 ACQPS plus 1)
AdcRegs.ADCCTL1.bit.INTPULSEPOS = 1; //ADCINT1 trips after AdcResults latch
AdcRegs.ADCINTSOCSEL1.bit.SOC0 = 1; //软件触发源ADCINT1
AdcRegs.ADCINTSOCSEL2.bit.SOC8 = 1; //ADCINT2 will trigger SOC0. TRIGSEL field is ignored.
//使用ADCSOCFRC1启动
AdcRegs.ADCSOCFRC1.bit.SOC0 = 1;
AdcRegs.ADCSOCFRC1.bit.SOC8 = 1;
EDIS;
/*2:这段正常*/
// AdcRegs.ADCCTL1.bit.ADCREFSEL = 1; // Page485 选择外部VREF
// AdcRegs.ADCCTL2.bit.ADCNONOVERLAP = 0; // Enable non-overlap mode 0允许重叠/1不允许
// AdcRegs.INTSEL1N2.bit.INT1E = 1; // 中断使能 Enabled ADCINT1
// //AdcRegs.INTSEL1N2.bit.INT1CONT = 1; // Disable ADCINT1 Continuous mode 1打开连续中断/0关掉(20130613)
// AdcRegs.INTSEL1N2.bit.INT1CONT = 0; // Disable ADCINT1 Continuous mode 1打开连续中断/0关掉
// AdcRegs.INTSEL1N2.bit.INT1SEL = 1; // 中断线1选择/Connect ADCINT1 to EOC1
// AdcRegs.ADCSAMPLEMODE.bit.SIMULEN0 = 1; // 同时采样
// AdcRegs.ADCSOC0CTL.bit.CHSEL = 0; // soc通道选择 ADCINA0
// AdcRegs.ADCSOC1CTL.bit.CHSEL = 8; // set SOC1 channel select to ADCINB0
// AdcRegs.ADCSOC0CTL.bit.TRIGSEL = 1; // T0 触发源选择
// AdcRegs.ADCSOC1CTL.bit.TRIGSEL = 1; //
// AdcRegs.ADCSOC0CTL.bit.ACQPS = 6; // set SOC0 S/H Window to 7 ADC Clock Cycles, (6 ACQPS plus 1) 采样时间
// AdcRegs.ADCSOC1CTL.bit.ACQPS = 6; // set SOC1 S/H Window to 7 ADC Clock Cycles, (6 ACQPS plus 1)
// AdcRegs.ADCCTL1.bit.INTPULSEPOS = 1; // 结果存入寄存器才产生中断 ADCINT1 trips after AdcResults latch
// EDIS; |
