/* header file for the MICROCHIP PIC18 microcontrollers
PIC18F6527
PIC18F6622
PIC18F8527
PIC18F8622
PIC18F6627
PIC18F6722
PIC18F8627
PIC18F8722
#ifndef __PIC18FXX22_H
#define __PIC18FXX22_H
static volatile near unsigned char TOSU @ 0xFFF;
static volatile near unsigned char TOSH @ 0xFFE;
static volatile near unsigned char TOSL @ 0xFFD;
static volatile near unsigned char STKPTR @ 0xFFC;
static volatile near unsigned char PCLATU @ 0xFFB;
static volatile near unsigned char PCLATH @ 0xFFA;
static volatile near unsigned char PCL @ 0xFF9;
static volatile far unsigned char * TBLPTR @ 0xFF6;
static volatile near unsigned char TBLPTRU @ 0xFF8;
static volatile near unsigned char TBLPTRH @ 0xFF7;
static volatile near unsigned char TBLPTRL @ 0xFF6;
static volatile near unsigned char TABLAT @ 0xFF5;
static volatile near unsigned char PRODH @ 0xFF4;
static volatile near unsigned char PRODL @ 0xFF3;
static volatile near unsigned char INTCON @ 0xFF2;
static near unsigned char INTCON2 @ 0xFF1;
static volatile near unsigned char INTCON3 @ 0xFF0;
static volatile near unsigned char INDF0 @ 0xFEF;
static volatile near unsigned char POSTINC0 @ 0xFEE;
static volatile near unsigned char POSTDEC0 @ 0xFED;
static volatile near unsigned char PREINC0 @ 0xFEC;
static volatile near unsigned char PLUSW0 @ 0xFEB;
static volatile near unsigned char FSR0H @ 0xFEA;
static volatile near unsigned char FSR0L @ 0xFE9;
static volatile near unsigned char WREG @ 0xFE8;
static volatile near unsigned char INDF1 @ 0xFE7;
static volatile near unsigned char POSTINC1 @ 0xFE6;
static volatile near unsigned char POSTDEC1 @ 0xFE5;
static volatile near unsigned char PREINC1 @ 0xFE4;
static volatile near unsigned char PLUSW1 @ 0xFE3;
static volatile near unsigned char FSR1H @ 0xFE2;
static volatile near unsigned char FSR1L @ 0xFE1;
static near unsigned char BSR @ 0xFE0;
static volatile near unsigned char INDF2 @ 0xFDF;
static volatile near unsigned char POSTINC2 @ 0xFDE;
static volatile near unsigned char POSTDEC2 @ 0xFDD;
static volatile near unsigned char PREINC2 @ 0xFDC;
static volatile near unsigned char PLUSW2 @ 0xFDB;
static volatile near unsigned char FSR2H @ 0xFDA;
static volatile near unsigned char FSR2L @ 0xFD9;
static volatile near unsigned char STATUS @ 0xFD8;
static volatile near unsigned char TMR0H @ 0xFD7;
static volatile near unsigned char TMR0L @ 0xFD6;
// 16-Bit definition
static volatile near unsigned int TMR0 @ 0xFD6;
static near unsigned char T0CON @ 0xFD5;
static volatile near unsigned char OSCCON @ 0xFD3;
static volatile near unsigned char HLVDCON @ 0xFD2;
static volatile near unsigned char WDTCON @ 0xFD1;
static volatile near unsigned char RCON @ 0xFD0;
static volatile near unsigned char TMR1H @ 0xFCF;
static volatile near unsigned char TMR1L @ 0xFCE;
static volatile near unsigned int TMR1 @ 0xFCE;
static near unsigned char T1CON @ 0xFCD;
static volatile near unsigned char TMR2 @ 0xFCC;
static near unsigned char PR2 @ 0xFCB;
static near unsigned char T2CON @ 0xFCA;
static volatile near unsigned char SSP1BUF @ 0xFC9;
static near unsigned char SSP1ADD @ 0xFC8;
static volatile near unsigned char SSP1STAT @ 0xFC7;
static volatile near unsigned char SSP1CON1 @ 0xFC6;
static volatile near unsigned char SSP1CON2 @ 0xFC5;
static volatile near unsigned char ADRESH @ 0xFC4;
static volatile near unsigned char ADRESL @ 0xFC3;
static volatile near unsigned int ADRES @ 0xFC3;
static volatile near unsigned char ADCON0 @ 0xFC2;
static near unsigned char ADCON1 @ 0xFC1;
static near unsigned char ADCON2 @ 0xFC0;
static volatile near unsigned char CCPR1H @ 0xFBF;
static volatile near unsigned char CCPR1L @ 0xFBE;
static volatile near unsigned int CCPR1 @ 0xFBE;
static volatile near unsigned char CCP1CON @ 0xFBD;
static volatile near unsigned char CCPR2H @ 0xFBC;
static volatile near unsigned char CCPR2L @ 0xFBB;
static volatile near unsigned int CCPR2 @ 0xFBB;
static volatile near unsigned char CCP2CON @ 0xFBA;
static volatile near unsigned char CCPR3H @ 0xFB9;
static volatile near unsigned char CCPR3L @ 0xFB8;
static volatile near unsigned int CCPR3 @ 0xFB8;
static volatile near unsigned char CCP3CON @ 0xFB7;
#if defined(_18F8527) || defined(_18F8622) || defined(_18F8627) || defined(_18F8722)
static volatile near unsigned char ECCP1AS @ 0xFB6;
static volatile near unsigned char CVRCON @ 0xFB5;
static volatile near unsigned char CMCON @ 0xFB4;
static volatile near unsigned char TMR3H @ 0xFB3;
static volatile near unsigned char TMR3L @ 0xFB2;
static volatile near unsigned int TMR3 @ 0xFB2;
static near unsigned char T3CON @ 0xFB1;
static volatile near unsigned char PSPCON @ 0xFB0;
static near unsigned char SPBRG1 @ 0xFAF;
static volatile near unsigned char RCREG1 @ 0xFAE;
static volatile near unsigned char TXREG1 @ 0xFAD;
static volatile near unsigned char TXSTA1 @ 0xFAC;
static volatile near unsigned char RCSTA1 @ 0xFAB;
static near unsigned char EEADRH @ 0xFAA;
static near unsigned char EEADR @ 0xFA9;
static volatile near unsigned char EEDATA @ 0xFA8;
static volatile near unsigned char EECON2 @ 0xFA7;
static volatile near unsigned char EECON1 @ 0xFA6;
static near unsigned char IPR3 @ 0xFA5;
static volatile near unsigned char PIR3 @ 0xFA4;
static near unsigned char PIE3 @ 0xFA3;
static near unsigned char IPR2 @ 0xFA2;
static volatile near unsigned char PIR2 @ 0xFA1;
static near unsigned char PIE2 @ 0xFA0;
static near unsigned char IPR1 @ 0xF9F;
static volatile near unsigned char PIR1 @ 0xF9E;
static near unsigned char PIE1 @ 0xF9D;
static near unsigned char MEMCON @ 0xF9C;
static near unsigned char OSCTUNE @ 0xF9B;
#if defined(_18F8627) || defined(_18F8722)
static volatile near unsigned char TRISJ @ 0xF9A;
static volatile near unsigned char TRISH @ 0xF99;
static volatile near unsigned char TRISG @ 0xF98;
static volatile near unsigned char TRISF @ 0xF97;
static volatile near unsigned char TRISE @ 0xF96;
static volatile near unsigned char TRISD @ 0xF95;
static volatile near unsigned char TRISC @ 0xF94;
static volatile near unsigned char TRISB @ 0xF93;
static volatile near unsigned char TRISA @ 0xF92;
static volatile near unsigned char LATJ @ 0xF91;
static volatile near unsigned char LATH @ 0xF90;
static volatile near unsigned char LATG @ 0xF8F;
static volatile near unsigned char LATF @ 0xF8E;
static volatile near unsigned char LATE @ 0xF8D;
static volatile near unsigned char LATD @ 0xF8C;
static volatile near unsigned char LATC @ 0xF8B;
static volatile near unsigned char LATB @ 0xF8A;
static volatile near unsigned char LATA @ 0xF89;
static volatile near unsigned char PORTJ @ 0xF88;
static volatile near unsigned char PORTH @ 0xF87;
static volatile near unsigned char PORTG @ 0xF86;
static volatile near unsigned char PORTF @ 0xF85;
static volatile near unsigned char PORTE @ 0xF84;
static volatile near unsigned char PORTD @ 0xF83;
static volatile near unsigned char PORTC @ 0xF82;
static volatile near unsigned char PORTB @ 0xF81;
static volatile near unsigned char PORTA @ 0xF80;
static near unsigned char SPBRGH1 @ 0xF7F;
static volatile near unsigned char BAUDCON1 @ 0xF7E;
static near unsigned char SPBRGH2 @ 0xF7D;
static volatile near unsigned char BAUDCON2 @ 0xF7C;
static near unsigned char ECCP1DEL @ 0xF79;
static volatile near unsigned char TMR4 @ 0xF78;
static near unsigned char PR4 @ 0xF77;
static near unsigned char T4CON @ 0xF76;
static volatile near unsigned char CCPR4H @ 0xF75;
static volatile near unsigned char CCPR4L @ 0xF74;
static volatile near unsigned int CCPR4 @ 0xF74;
static volatile near unsigned char CCP4CON @ 0xF73;
static volatile near unsigned char CCPR5H @ 0xF72;
static volatile near unsigned char CCPR5L @ 0xF71;
static volatile near unsigned int CCPR5 @ 0xF71;
static volatile near unsigned char CCP5CON @ 0xF70;
static near unsigned char SPBRG2 @ 0xF6F;
static volatile near unsigned char RCREG2 @ 0xF6E;
static volatile near unsigned char TXREG2 @ 0xF6D;
static volatile near unsigned char TXSTA2 @ 0xF6C;
static volatile near unsigned char RCSTA2 @ 0xF6B;
static volatile near unsigned char ECCP3AS @ 0xF6A;
static near unsigned char ECCP3DEL @ 0xF69;
static volatile near unsigned char ECCP2AS @ 0xF68;
static near unsigned char ECCP2DEL @ 0xF67;
static volatile near unsigned char SSP2BUF @ 0xF66;
static near unsigned char SSP2ADD @ 0xF65;
static volatile near unsigned char SSP2STAT @ 0xF64;
static volatile near unsigned char SSP2CON1 @ 0xF63;
static volatile near unsigned char SSP2CON2 @ 0xF62;
/* Definitions for STKPTR register */
static volatile near bit STKUNF @ ((unsigned)&STKPTR*8)+6;
static volatile near bit STKFUL @ ((unsigned)&STKPTR*8)+7;
/* Definitions for INTCON register */
static volatile near bit RBIF @ ((unsigned)&INTCON*8)+0;
static volatile near bit INT0IF @ ((unsigned)&INTCON*8)+1;
static volatile near bit TMR0IF @ ((unsigned)&INTCON*8)+2;
static near bit RBIE @ ((unsigned)&INTCON*8)+3;
static near bit INT0IE @ ((unsigned)&INTCON*8)+4;
static near bit TMR0IE @ ((unsigned)&INTCON*8)+5;
static near bit PEIE @ ((unsigned)&INTCON*8)+6;
static near bit GIE @ ((unsigned)&INTCON*8)+7;
/* Alternate definitions for INTCON register */
static near bit GIEL @ ((unsigned)&INTCON*8)+6;
static near bit GIEH @ ((unsigned)&INTCON*8)+7;
/* Definitions for INTCON2 register */
static near bit RBIP @ ((unsigned)&INTCON2*8)+0;
static near bit INT3IP @ ((unsigned)&INTCON2*8)+1;
static near bit TMR0IP @ ((unsigned)&INTCON2*8)+2;
static near bit INTEDG3 @ ((unsigned)&INTCON2*8)+3;
static near bit INTEDG2 @ ((unsigned)&INTCON2*8)+4;
static near bit INTEDG1 @ ((unsigned)&INTCON2*8)+5;
static near bit INTEDG0 @ ((unsigned)&INTCON2*8)+6;
static near bit RBPU @ ((unsigned)&INTCON2*8)+7;
/* Definitions for INTCON3 register */
static volatile near bit INT1IF @ ((unsigned)&INTCON3*8)+0;
static volatile near bit INT2IF @ ((unsigned)&INTCON3*8)+1;
static volatile near bit INT3IF @ ((unsigned)&INTCON3*8)+2;
static near bit INT1IE @ ((unsigned)&INTCON3*8)+3;
static near bit INT2IE @ ((unsigned)&INTCON3*8)+4;
static near bit INT3IE @ ((unsigned)&INTCON3*8)+5;
static near bit INT1IP @ ((unsigned)&INTCON3*8)+6;
static near bit INT2IP @ ((unsigned)&INTCON3*8)+7;
/* Definitions for STATUS register */
static volatile near bit CARRY @ ((unsigned)&STATUS*8)+0;
static volatile near bit DC @ ((unsigned)&STATUS*8)+1;
static volatile near bit ZERO @ ((unsigned)&STATUS*8)+2;
static volatile near bit OV @ ((unsigned)&STATUS*8)+3;
static volatile near bit NEGATIVE @ ((unsigned)&STATUS*8)+4;
/* Definitions for T0CON register */
static near bit T0PS0 @ ((unsigned)&T0CON*8)+0;
static near bit T0PS1 @ ((unsigned)&T0CON*8)+1;
static near bit T0PS2 @ ((unsigned)&T0CON*8)+2;
static near bit PSA @ ((unsigned)&T0CON*8)+3;
static near bit T0SE @ ((unsigned)&T0CON*8)+4;
static near bit T0CS @ ((unsigned)&T0CON*8)+5;
static near bit T08BIT @ ((unsigned)&T0CON*8)+6;
static near bit TMR0ON @ ((unsigned)&T0CON*8)+7;
/* Definitions for OSCCON register */
static near bit SCS0 @ ((unsigned)&OSCCON*8)+0;
static near bit SCS1 @ ((unsigned)&OSCCON*8)+1;
static volatile near bit IOFS @ ((unsigned)&OSCCON*8)+2;
static volatile near bit OSTS @ ((unsigned)&OSCCON*8)+3;
static near bit IRCF0 @ ((unsigned)&OSCCON*8)+4;
static near bit IRCF1 @ ((unsigned)&OSCCON*8)+5;
static near bit IRCF2 @ ((unsigned)&OSCCON*8)+6;
static near bit IDLEN @ ((unsigned)&OSCCON*8)+7;
/* Definitions for HLVDCON register */
static near bit HLVDL0 @ ((unsigned)&HLVDCON*8)+0;
static near bit HLVDL1 @ ((unsigned)&HLVDCON*8)+1;
static near bit HLVDL2 @ ((unsigned)&HLVDCON*8)+2;
static near bit HLVDL3 @ ((unsigned)&HLVDCON*8)+3;
static near bit HLVDEN @ ((unsigned)&HLVDCON*8)+4;
static volatile near bit IRVST @ ((unsigned)&HLVDCON*8)+5;
static near bit VDIRMAG @ ((unsigned)&HLVDCON*8)+7;
/* Definitions for WDTCON register */
static near bit SWDTEN @ ((unsigned)&WDTCON*8)+0;
/* Definitions for RCON register */
static volatile near bit BOR @ ((unsigned)&RCON*8)+0;
static volatile near bit POR @ ((unsigned)&RCON*8)+1;
static volatile near bit PD @ ((unsigned)&RCON*8)+2;
static volatile near bit TO @ ((unsigned)&RCON*8)+3;
static volatile near bit RI @ ((unsigned)&RCON*8)+4;
static near bit SBOREN @ ((unsigned)&RCON*8)+6;
static near bit IPEN @ ((unsigned)&RCON*8)+7;
/* Definitions for T1CON register */
static near bit TMR1ON @ ((unsigned)&T1CON*8)+0;
static near bit TMR1CS @ ((unsigned)&T1CON*8)+1;
static near bit T1SYNC @ ((unsigned)&T1CON*8)+2;
static near bit T1OSCEN @ ((unsigned)&T1CON*8)+3;
static near bit T1CKPS0 @ ((unsigned)&T1CON*8)+4;
static near bit T1CKPS1 @ ((unsigned)&T1CON*8)+5;
static near bit T1RUN @ ((unsigned)&T1CON*8)+6;
static near bit T1RD16 @ ((unsigned)&T1CON*8)+7;
/* Definitions for T2CON register */
static near bit T2CKPS0 @ ((unsigned)&T2CON*8)+0;
static near bit T2CKPS1 @ ((unsigned)&T2CON*8)+1;
static near bit TMR2ON @ ((unsigned)&T2CON*8)+2;
static near bit T2OUTPS0 @ ((unsigned)&T2CON*8)+3;
static near bit T2OUTPS1 @ ((unsigned)&T2CON*8)+4;
static near bit T2OUTPS2 @ ((unsigned)&T2CON*8)+5;
static near bit T2OUTPS3 @ ((unsigned)&T2CON*8)+6;
/* Definitions for SSP1STAT register */
static volatile near bit BF @ ((unsigned)&SSP1STAT*8)+0;
static volatile near bit UA @ ((unsigned)&SSP1STAT*8)+1;
static volatile near bit RW @ ((unsigned)&SSP1STAT*8)+2;
static volatile near bit START @ ((unsigned)&SSP1STAT*8)+3;
static volatile near bit STOP @ ((unsigned)&SSP1STAT*8)+4;
static volatile near bit DA @ ((unsigned)&SSP1STAT*8)+5;
static near bit CKE @ ((unsigned)&SSP1STAT*8)+6;
static near bit SMP @ ((unsigned)&SSP1STAT*8)+7;
/* Alternate definitions for SSP1STAT register */
static volatile near bit BF1 @ ((unsigned)&SSP1STAT*8)+0;
static volatile near bit UA1 @ ((unsigned)&SSP1STAT*8)+1;
static volatile near bit RW1 @ ((unsigned)&SSP1STAT*8)+2;
static volatile near bit START1 @ ((unsigned)&SSP1STAT*8)+3;
static volatile near bit STOP1 @ ((unsigned)&SSP1STAT*8)+4;
static volatile near bit DA1 @ ((unsigned)&SSP1STAT*8)+5;
static near bit CKE1 @ ((unsigned)&SSP1STAT*8)+6;
static near bit SMP1 @ ((unsigned)&SSP1STAT*8)+7;
/* Definitions for SSP1CON1 register */
static near bit SSPM0 @ ((unsigned)&SSP1CON1*8)+0;
static near bit SSPM1 @ ((unsigned)&SSP1CON1*8)+1;
static near bit SSPM2 @ ((unsigned)&SSP1CON1*8)+2;
static near bit SSPM3 @ ((unsigned)&SSP1CON1*8)+3;
static near bit CKP @ ((unsigned)&SSP1CON1*8)+4;
static near bit SSPEN @ ((unsigned)&SSP1CON1*8)+5;
static volatile near bit SSPOV @ ((unsigned)&SSP1CON1*8)+6;
static volatile near bit WCOL @ ((unsigned)&SSP1CON1*8)+7;
/* Alternate definitions for SSP1CON1 register */
static near bit SSPM01 @ ((unsigned)&SSP1CON1*8)+0;
static near bit SSPM11 @ ((unsigned)&SSP1CON1*8)+1;
static near bit SSPM21 @ ((unsigned)&SSP1CON1*8)+2;
static near bit SSPM31 @ ((unsigned)&SSP1CON1*8)+3;
static near bit CKP1 @ ((unsigned)&SSP1CON1*8)+4;
static near bit SSPEN1 @ ((unsigned)&SSP1CON1*8)+5;
static volatile near bit SSPOV1 @ ((unsigned)&SSP1CON1*8)+6;
static volatile near bit WCOL1 @ ((unsigned)&SSP1CON1*8)+7;
/* Definitions for SSP1CON2 register */
static near bit SEN @ ((unsigned)&SSP1CON2*8)+0;
static volatile near bit RSEN @ ((unsigned)&SSP1CON2*8)+1;
static volatile near bit PEN @ ((unsigned)&SSP1CON2*8)+2;
static volatile near bit RCEN @ ((unsigned)&SSP1CON2*8)+3;
static volatile near bit ACKEN @ ((unsigned)&SSP1CON2*8)+4;
static volatile near bit ACKDT @ ((unsigned)&SSP1CON2*8)+5;
static volatile near bit ACKSTAT @ ((unsigned)&SSP1CON2*8)+6;
static near bit GCEN @ ((unsigned)&SSP1CON2*8)+7;
/* Alternate definitions for SSP1CON2 register */
static near bit SEN1 @ ((unsigned)&SSP1CON2*8)+0;
static volatile near bit RSEN1 @ ((unsigned)&SSP1CON2*8)+1;
static volatile near bit PEN1 @ ((unsigned)&SSP1CON2*8)+2;
static volatile near bit RCEN1 @ ((unsigned)&SSP1CON2*8)+3;
static volatile near bit ACKEN1 @ ((unsigned)&SSP1CON2*8)+4;
static volatile near bit ACKDT1 @ ((unsigned)&SSP1CON2*8)+5;
static volatile near bit ACKSTAT1 @ ((unsigned)&SSP1CON2*8)+6;
static near bit GCEN1 @ ((unsigned)&SSP1CON2*8)+7;
/* Definitions for ADCON0 register */
static near bit ADON @ ((unsigned)&ADCON0*8)+0;
static volatile near bit GODONE @ ((unsigned)&ADCON0*8)+1;
static near bit CHS0 @ ((unsigned)&ADCON0*8)+2;
static near bit CHS1 @ ((unsigned)&ADCON0*8)+3;
static near bit CHS2 @ ((unsigned)&ADCON0*8)+4;
static near bit CHS3 @ ((unsigned)&ADCON0*8)+5;
/* Definitions for ADCON1 register */
static near bit PCFG0 @ ((unsigned)&ADCON1*8)+0;
static near bit PCFG1 @ ((unsigned)&ADCON1*8)+1;
static near bit PCFG2 @ ((unsigned)&ADCON1*8)+2;
static near bit PCFG3 @ ((unsigned)&ADCON1*8)+3;
static near bit VCFG0 @ ((unsigned)&ADCON1*8)+4;
static near bit VCFG1 @ ((unsigned)&ADCON1*8)+5;
/* Definitions for ADCON2 register */
static near bit ADCS0 @ ((unsigned)&ADCON2*8)+0;
static near bit ADCS1 @ ((unsigned)&ADCON2*8)+1;
static near bit ADCS2 @ ((unsigned)&ADCON2*8)+2;
static near bit ACQT0 @ ((unsigned)&ADCON2*8)+3;
static near bit ACQT1 @ ((unsigned)&ADCON2*8)+4;
static near bit ACQT2 @ ((unsigned)&ADCON2*8)+5;
static near bit ADFM @ ((unsigned)&ADCON2*8)+7;
/* Definitions for CCP1CON register */
static near bit CCP1M0 @ ((unsigned)&CCP1CON*8)+0;
static near bit CCP1M1 @ ((unsigned)&CCP1CON*8)+1;
static near bit CCP1M2 @ ((unsigned)&CCP1CON*8)+2;
static near bit CCP1M3 @ ((unsigned)&CCP1CON*8)+3;
static near bit DC1B0 @ ((unsigned)&CCP1CON*8)+4;
static near bit DC1B1 @ ((unsigned)&CCP1CON*8)+5;
static near bit P1M0 @ ((unsigned)&CCP1CON*8)+6;
static near bit P1M1 @ ((unsigned)&CCP1CON*8)+7;
/* Definitions for CCP2CON register */
static near bit CCP2M0 @ ((unsigned)&CCP2CON*8)+0;
static near bit CCP2M1 @ ((unsigned)&CCP2CON*8)+1;
static near bit CCP2M2 @ ((unsigned)&CCP2CON*8)+2;
static near bit CCP2M3 @ ((unsigned)&CCP2CON*8)+3;
static near bit DC2B0 @ ((unsigned)&CCP2CON*8)+4;
static near bit DC2B1 @ ((unsigned)&CCP2CON*8)+5;
static near bit P2M0 @ ((unsigned)&CCP2CON*8)+6;
static near bit P2M1 @ ((unsigned)&CCP2CON*8)+7;
/* Definitions for CCP3CON register */
static near bit CCP3M0 @ ((unsigned)&CCP3CON*8)+0;
static near bit CCP3M1 @ ((unsigned)&CCP3CON*8)+1;
static near bit CCP3M2 @ ((unsigned)&CCP3CON*8)+2;
static near bit CCP3M3 @ ((unsigned)&CCP3CON*8)+3;
static near bit DC3B0 @ ((unsigned)&CCP3CON*8)+4;
static near bit DC3B1 @ ((unsigned)&CCP3CON*8)+5;
static near bit P3M0 @ ((unsigned)&CCP3CON*8)+6;
static near bit P3M1 @ ((unsigned)&CCP3CON*8)+7;
/* Definitions for ECCP1AS register */
static near bit PSS1BD0 @ ((unsigned)&ECCP1AS*8)+0;
static near bit PSS1BD1 @ ((unsigned)&ECCP1AS*8)+1;
static near bit PSS1AC0 @ ((unsigned)&ECCP1AS*8)+2;
static near bit PSS1AC1 @ ((unsigned)&ECCP1AS*8)+3;
static near bit ECCP1AS0 @ ((unsigned)&ECCP1AS*8)+4;
static near bit ECCP1AS1 @ ((unsigned)&ECCP1AS*8)+5;
static near bit ECCP1AS2 @ ((unsigned)&ECCP1AS*8)+6;
static volatile near bit ECCP1ASE @ ((unsigned)&ECCP1AS*8)+7;
/* Definitions for CVRCON register */
static near bit CVR0 @ ((unsigned)&CVRCON*8)+0;
static near bit CVR1 @ ((unsigned)&CVRCON*8)+1;
static near bit CVR2 @ ((unsigned)&CVRCON*8)+2;
static near bit CVR3 @ ((unsigned)&CVRCON*8)+3;
static near bit CVRSS @ ((unsigned)&CVRCON*8)+4;
static near bit CVRR @ ((unsigned)&CVRCON*8)+5;
static near bit CVROE @ ((unsigned)&CVRCON*8)+6;
static near bit CVREN @ ((unsigned)&CVRCON*8)+7;
/* Definitions for CMCON register */
static near bit CM0 @ ((unsigned)&CMCON*8)+0;
static near bit CM1 @ ((unsigned)&CMCON*8)+1;
static near bit CM2 @ ((unsigned)&CMCON*8)+2;
static near bit CIS @ ((unsigned)&CMCON*8)+3;
static near bit C1INV @ ((unsigned)&CMCON*8)+4;
static near bit C2INV @ ((unsigned)&CMCON*8)+5;
static volatile near bit C1OUT @ ((unsigned)&CMCON*8)+6;
static volatile near bit C2OUT @ ((unsigned)&CMCON*8)+7;
/* Definitions for T3CON register */
static near bit TMR3ON @ ((unsigned)&T3CON*8)+0;
static near bit TMR3CS @ ((unsigned)&T3CON*8)+1;
static near bit T3SYNC @ ((unsigned)&T3CON*8)+2;
static near bit T3CCP1 @ ((unsigned)&T3CON*8)+3;
static near bit T3CKPS0 @ ((unsigned)&T3CON*8)+4;
static near bit T3CKPS1 @ ((unsigned)&T3CON*8)+5;
static near bit T3CCP2 @ ((unsigned)&T3CON*8)+6;
static near bit T3RD16 @ ((unsigned)&T3CON*8)+7;
/* Definitions for PSPCON register */
static near bit PSPMODE @ ((unsigned)&PSPCON*8)+4;
static volatile near bit IBOV @ ((unsigned)&PSPCON*8)+5;
static volatile near bit OBF @ ((unsigned)&PSPCON*8)+6;
static volatile near bit IBF @ ((unsigned)&PSPCON*8)+7;
/* Definitions for TXSTA1 register */
static volatile near bit TX9D @ ((unsigned)&TXSTA1*8)+0;
static volatile near bit TRMT @ ((unsigned)&TXSTA1*8)+1;
static near bit BRGH @ ((unsigned)&TXSTA1*8)+2;
static near bit SENDB @ ((unsigned)&TXSTA1*8)+3;
static near bit SYNC @ ((unsigned)&TXSTA1*8)+4;
static near bit TXEN @ ((unsigned)&TXSTA1*8)+5;
static near bit TX9 @ ((unsigned)&TXSTA1*8)+6;
static near bit CSRC @ ((unsigned)&TXSTA1*8)+7;
/* Definitions for RCSTA1 register */
static volatile near bit RX9D @ ((unsigned)&RCSTA1*8)+0;
static volatile near bit OERR @ ((unsigned)&RCSTA1*8)+1;
static volatile near bit FERR @ ((unsigned)&RCSTA1*8)+2;
static near bit ADDEN @ ((unsigned)&RCSTA1*8)+3;
static near bit CREN @ ((unsigned)&RCSTA1*8)+4;
static near bit SREN @ ((unsigned)&RCSTA1*8)+5;
static near bit RX9 @ ((unsigned)&RCSTA1*8)+6;
static near bit SPEN @ ((unsigned)&RCSTA1*8)+7;
/* Definitions for EECON1 register */
static volatile near bit RD @ ((unsigned)&EECON1*8)+0;
static volatile near bit WR @ ((unsigned)&EECON1*8)+1;
static near bit WREN @ ((unsigned)&EECON1*8)+2;
static volatile near bit WRERR @ ((unsigned)&EECON1*8)+3;
static volatile near bit FREE @ ((unsigned)&EECON1*8)+4;
static near bit CFGS @ ((unsigned)&EECON1*8)+6;
static near bit EEPGD @ ((unsigned)&EECON1*8)+7;
/* Definitions for IPR3 register */
static near bit CCP3IP @ ((unsigned)&IPR3*8)+0;
static near bit CCP4IP @ ((unsigned)&IPR3*8)+1;
static near bit CCP5IP @ ((unsigned)&IPR3*8)+2;
static near bit TMR4IP @ ((unsigned)&IPR3*8)+3;
static near bit TX2IP @ ((unsigned)&IPR3*8)+4;
static near bit RC2IP @ ((unsigned)&IPR3*8)+5;
static near bit BCL2IP @ ((unsigned)&IPR3*8)+6;
static near bit SSP2IP @ ((unsigned)&IPR3*8)+7;
/* Definitions for PIR3 register */
static volatile near bit CCP3IF @ ((unsigned)&PIR3*8)+0;
static volatile near bit CCP4IF @ ((unsigned)&PIR3*8)+1;
static volatile near bit CCP5IF @ ((unsigned)&PIR3*8)+2;
static volatile near bit TMR4IF @ ((unsigned)&PIR3*8)+3;
static volatile near bit TX2IF @ ((unsigned)&PIR3*8)+4;
static volatile near bit RC2IF @ ((unsigned)&PIR3*8)+5;
static volatile near bit BCL2IF @ ((unsigned)&PIR3*8)+6;
static volatile near bit SSP2IF @ ((unsigned)&PIR3*8)+7;
/* Definitions for PIE3 register */
static near bit CCP3IE @ ((unsigned)&PIE3*8)+0;
static near bit CCP4IE @ ((unsigned)&PIE3*8)+1;
static near bit CCP5IE @ ((unsigned)&PIE3*8)+2;
static near bit TMR4IE @ ((unsigned)&PIE3*8)+3;
static near bit TX2IE @ ((unsigned)&PIE3*8)+4;
static near bit RC2IE @ ((unsigned)&PIE3*8)+5;
static near bit BCL2IE @ ((unsigned)&PIE3*8)+6;
static near bit SSP2IE @ ((unsigned)&PIE3*8)+7;
/* Definitions for IPR2 register */
static near bit CCP2IP @ ((unsigned)&IPR2*8)+0;
static near bit TMR3IP @ ((unsigned)&IPR2*8)+1;
static near bit HLVDIP @ ((unsigned)&IPR2*8)+2;
static near bit BCL1IP @ ((unsigned)&IPR2*8)+3;
static near bit EEIP @ ((unsigned)&IPR2*8)+4;
static near bit CMIP @ ((unsigned)&IPR2*8)+6;
static near bit OSCFIP @ ((unsigned)&IPR2*8)+7;
/* Definitions for PIR2 register */
static volatile near bit CCP2IF @ ((unsigned)&PIR2*8)+0;
static volatile near bit TMR3IF @ ((unsigned)&PIR2*8)+1;
static volatile near bit HLVDIF @ ((unsigned)&PIR2*8)+2;
static volatile near bit BCL1IF @ ((unsigned)&PIR2*8)+3;
static volatile near bit EEIF @ ((unsigned)&PIR2*8)+4;
static volatile near bit CMIF @ ((unsigned)&PIR2*8)+6;
static volatile near bit OSCFIF @ ((unsigned)&PIR2*8)+7;
/* Definitions for PIE2 register */
static near bit CCP2IE @ ((unsigned)&PIE2*8)+0;
static near bit TMR3IE @ ((unsigned)&PIE2*8)+1;
static near bit HLVDIE @ ((unsigned)&PIE2*8)+2;
static near bit BCL1IE @ ((unsigned)&PIE2*8)+3;
static near bit EEIE @ ((unsigned)&PIE2*8)+4;
static near bit CMIE @ ((unsigned)&PIE2*8)+6;
static near bit OSCFIE @ ((unsigned)&PIE2*8)+7;
/* Definitions for IPR1 register */
static near bit TMR1IP @ ((unsigned)&IPR1*8)+0;
static near bit TMR2IP @ ((unsigned)&IPR1*8)+1;
static near bit CCP1IP @ ((unsigned)&IPR1*8)+2;
static near bit SSP1IP @ ((unsigned)&IPR1*8)+3;
static near bit TX1IP @ ((unsigned)&IPR1*8)+4;
static near bit RC1IP @ ((unsigned)&IPR1*8)+5;
static near bit ADIP @ ((unsigned)&IPR1*8)+6;
static near bit PSPIP @ ((unsigned)&IPR1*8)+7;
/* Definitions for PIR1 register */
static volatile near bit TMR1IF @ ((unsigned)&PIR1*8)+0;
static volatile near bit TMR2IF @ ((unsigned)&PIR1*8)+1;
static volatile near bit CCP1IF @ ((unsigned)&PIR1*8)+2;
static volatile near bit SSP1IF @ ((unsigned)&PIR1*8)+3;
static volatile near bit TX1IF @ ((unsigned)&PIR1*8)+4;
static volatile near bit RC1IF @ ((unsigned)&PIR1*8)+5;
static volatile near bit ADIF @ ((unsigned)&PIR1*8)+6;
static volatile near bit PSPIF @ ((unsigned)&PIR1*8)+7;
/* Definitions for PIE1 register */
static near bit TMR1IE @ ((unsigned)&PIE1*8)+0;
static near bit TMR2IE @ ((unsigned)&PIE1*8)+1;
static near bit CCP1IE @ ((unsigned)&PIE1*8)+2;
static near bit SSP1IE @ ((unsigned)&PIE1*8)+3;
static near bit TX1IE @ ((unsigned)&PIE1*8)+4;
static near bit RC1IE @ ((unsigned)&PIE1*8)+5;
static near bit ADIE @ ((unsigned)&PIE1*8)+6;
static near bit PSPIE @ ((unsigned)&PIE1*8)+7;
/* Definitions for MEMCON register */
static near bit WM0 @ ((unsigned)&MEMCON*8)+0;
static near bit WM1 @ ((unsigned)&MEMCON*8)+1;
static near bit WAIT0 @ ((unsigned)&MEMCON*8)+4;
static near bit WAIT1 @ ((unsigned)&MEMCON*8)+5;
static near bit EBDIS @ ((unsigned)&MEMCON*8)+7;
/* Definitions for OSCTUNE register */
static near bit TUN0 @ ((unsigned)&OSCTUNE*8)+0;
static near bit TUN1 @ ((unsigned)&OSCTUNE*8)+1;
static near bit TUN2 @ ((unsigned)&OSCTUNE*8)+2;
static near bit TUN3 @ ((unsigned)&OSCTUNE*8)+3;
static near bit TUN4 @ ((unsigned)&OSCTUNE*8)+4;
static near bit PLLEN @ ((unsigned)&OSCTUNE*8)+6;
static near bit INTSRC @ ((unsigned)&OSCTUNE*8)+7;
/* Definitions for TRISJ register */
static volatile near bit TRISJ0 @ ((unsigned)&TRISJ*8)+0;
static volatile near bit TRISJ1 @ ((unsigned)&TRISJ*8)+1;
static volatile near bit TRISJ2 @ ((unsigned)&TRISJ*8)+2;
static volatile near bit TRISJ3 @ ((unsigned)&TRISJ*8)+3;
static volatile near bit TRISJ4 @ ((unsigned)&TRISJ*8)+4;
static volatile near bit TRISJ5 @ ((unsigned)&TRISJ*8)+5;
static volatile near bit TRISJ6 @ ((unsigned)&TRISJ*8)+6;
static volatile near bit TRISJ7 @ ((unsigned)&TRISJ*8)+7;
/* Definitions for TRISH register */
static volatile near bit TRISH0 @ ((unsigned)&TRISH*8)+0;
static volatile near bit TRISH1 @ ((unsigned)&TRISH*8)+1;
static volatile near bit TRISH2 @ ((unsigned)&TRISH*8)+2;
static volatile near bit TRISH3 @ ((unsigned)&TRISH*8)+3;
static volatile near bit TRISH4 @ ((unsigned)&TRISH*8)+4;
static volatile near bit TRISH5 @ ((unsigned)&TRISH*8)+5;
static volatile near bit TRISH6 @ ((unsigned)&TRISH*8)+6;
static volatile near bit TRISH7 @ ((unsigned)&TRISH*8)+7;
/* Definitions for TRISG register */
static volatile near bit TRISG0 @ ((unsigned)&TRISG*8)+0;
static volatile near bit TRISG1 @ ((unsigned)&TRISG*8)+1;
static volatile near bit TRISG2 @ ((unsigned)&TRISG*8)+2;
static volatile near bit TRISG3 @ ((unsigned)&TRISG*8)+3;
static volatile near bit TRISG4 @ ((unsigned)&TRISG*8)+4;
/* Definitions for TRISF register */
static volatile near bit TRISF0 @ ((unsigned)&TRISF*8)+0;
static volatile near bit TRISF1 @ ((unsigned)&TRISF*8)+1;
static volatile near bit TRISF2 @ ((unsigned)&TRISF*8)+2;
static volatile near bit TRISF3 @ ((unsigned)&TRISF*8)+3;
static volatile near bit TRISF4 @ ((unsigned)&TRISF*8)+4;
static volatile near bit TRISF5 @ ((unsigned)&TRISF*8)+5;
static volatile near bit TRISF6 @ ((unsigned)&TRISF*8)+6;
static volatile near bit TRISF7 @ ((unsigned)&TRISF*8)+7;
/* Definitions for TRISE register */
static volatile near bit TRISE0 @ ((unsigned)&TRISE*8)+0;
static volatile near bit TRISE1 @ ((unsigned)&TRISE*8)+1;
static volatile near bit TRISE2 @ ((unsigned)&TRISE*8)+2;
static volatile near bit TRISE3 @ ((unsigned)&TRISE*8)+3;
static volatile near bit TRISE4 @ ((unsigned)&TRISE*8)+4;
static volatile near bit TRISE5 @ ((unsigned)&TRISE*8)+5;
static volatile near bit TRISE6 @ ((unsigned)&TRISE*8)+6;
static volatile near bit TRISE7 @ ((unsigned)&TRISE*8)+7;
/* Definitions for TRISD register */
static volatile near bit TRISD0 @ ((unsigned)&TRISD*8)+0;
static volatile near bit TRISD1 @ ((unsigned)&TRISD*8)+1;
static volatile near bit TRISD2 @ ((unsigned)&TRISD*8)+2;
static volatile near bit TRISD3 @ ((unsigned)&TRISD*8)+3;
static volatile near bit TRISD4 @ ((unsigned)&TRISD*8)+4;
static volatile near bit TRISD5 @ ((unsigned)&TRISD*8)+5;
static volatile near bit TRISD6 @ ((unsigned)&TRISD*8)+6;
static volatile near bit TRISD7 @ ((unsigned)&TRISD*8)+7;
/* Definitions for TRISC register */
static volatile near bit TRISC0 @ ((unsigned)&TRISC*8)+0;
static volatile near bit TRISC1 @ ((unsigned)&TRISC*8)+1;
static volatile near bit TRISC2 @ ((unsigned)&TRISC*8)+2;
static volatile near bit TRISC3 @ ((unsigned)&TRISC*8)+3;
static volatile near bit TRISC4 @ ((unsigned)&TRISC*8)+4;
static volatile near bit TRISC5 @ ((unsigned)&TRISC*8)+5;
static volatile near bit TRISC6 @ ((unsigned)&TRISC*8)+6;
static volatile near bit TRISC7 @ ((unsigned)&TRISC*8)+7;
/* Definitions for TRISB register */
static volatile near bit TRISB0 @ ((unsigned)&TRISB*8)+0;
static volatile near bit TRISB1 @ ((unsigned)&TRISB*8)+1;
static volatile near bit TRISB2 @ ((unsigned)&TRISB*8)+2;
static volatile near bit TRISB3 @ ((unsigned)&TRISB*8)+3;
static volatile near bit TRISB4 @ ((unsigned)&TRISB*8)+4;
static volatile near bit TRISB5 @ ((unsigned)&TRISB*8)+5;
static volatile near bit TRISB6 @ ((unsigned)&TRISB*8)+6;
static volatile near bit TRISB7 @ ((unsigned)&TRISB*8)+7;
/* Definitions for TRISA register */
static volatile near bit TRISA0 @ ((unsigned)&TRISA*8)+0;
static volatile near bit TRISA1 @ ((unsigned)&TRISA*8)+1;
static volatile near bit TRISA2 @ ((unsigned)&TRISA*8)+2;
static volatile near bit TRISA3 @ ((unsigned)&TRISA*8)+3;
static volatile near bit TRISA4 @ ((unsigned)&TRISA*8)+4;
static volatile near bit TRISA5 @ ((unsigned)&TRISA*8)+5;
static volatile near bit TRISA6 @ ((unsigned)&TRISA*8)+6;
static volatile near bit TRISA7 @ ((unsigned)&TRISA*8)+7;
/* Definitions for LATJ register */
static volatile near bit LATJ0 @ ((unsigned)&LATJ*8)+0;
static volatile near bit LATJ1 @ ((unsigned)&LATJ*8)+1;
static volatile near bit LATJ2 @ ((unsigned)&LATJ*8)+2;
static volatile near bit LATJ3 @ ((unsigned)&LATJ*8)+3;
static volatile near bit LATJ4 @ ((unsigned)&LATJ*8)+4;
static volatile near bit LATJ5 @ ((unsigned)&LATJ*8)+5;
static volatile near bit LATJ6 @ ((unsigned)&LATJ*8)+6;
static volatile near bit LATJ7 @ ((unsigned)&LATJ*8)+7;
/* Definitions for LATH register */
static volatile near bit LATH0 @ ((unsigned)&LATH*8)+0;
static volatile near bit LATH1 @ ((unsigned)&LATH*8)+1;
static volatile near bit LATH2 @ ((unsigned)&LATH*8)+2;
static volatile near bit LATH3 @ ((unsigned)&LATH*8)+3;
static volatile near bit LATH4 @ ((unsigned)&LATH*8)+4;
static volatile near bit LATH5 @ ((unsigned)&LATH*8)+5;
static volatile near bit LATH6 @ ((unsigned)&LATH*8)+6;
static volatile near bit LATH7 @ ((unsigned)&LATH*8)+7;
/* Definitions for LATG register */
static volatile near bit LATG0 @ ((unsigned)&LATG*8)+0;
static volatile near bit LATG1 @ ((unsigned)&LATG*8)+1;
static volatile near bit LATG2 @ ((unsigned)&LATG*8)+2;
static volatile near bit LATG3 @ ((unsigned)&LATG*8)+3;
static volatile near bit LATG4 @ ((unsigned)&LATG*8)+4;
/* Definitions for LATF register */
static volatile near bit LATF0 @ ((unsigned)&LATF*8)+0;
static volatile near bit LATF1 @ ((unsigned)&LATF*8)+1;
static volatile near bit LATF2 @ ((unsigned)&LATF*8)+2;
static volatile near bit LATF3 @ ((unsigned)&LATF*8)+3;
static volatile near bit LATF4 @ ((unsigned)&LATF*8)+4;
static volatile near bit LATF5 @ ((unsigned)&LATF*8)+5;
static volatile near bit LATF6 @ ((unsigned)&LATF*8)+6;
static volatile near bit LATF7 @ ((unsigned)&LATF*8)+7;
/* Definitions for LATE register */
static volatile near bit LATE0 @ ((unsigned)&LATE*8)+0;
static volatile near bit LATE1 @ ((unsigned)&LATE*8)+1;
static volatile near bit LATE2 @ ((unsigned)&LATE*8)+2;
static volatile near bit LATE3 @ ((unsigned)&LATE*8)+3;
static volatile near bit LATE4 @ ((unsigned)&LATE*8)+4;
static volatile near bit LATE5 @ ((unsigned)&LATE*8)+5;
static volatile near bit LATE6 @ ((unsigned)&LATE*8)+6;
static volatile near bit LATE7 @ ((unsigned)&LATE*8)+7;
/* Definitions for LATD register */
static volatile near bit LATD0 @ ((unsigned)&LATD*8)+0;
static volatile near bit LATD1 @ ((unsigned)&LATD*8)+1;
static volatile near bit LATD2 @ ((unsigned)&LATD*8)+2;
static volatile near bit LATD3 @ ((unsigned)&LATD*8)+3;
static volatile near bit LATD4 @ ((unsigned)&LATD*8)+4;
static volatile near bit LATD5 @ ((unsigned)&LATD*8)+5;
static volatile near bit LATD6 @ ((unsigned)&LATD*8)+6;
static volatile near bit LATD7 @ ((unsigned)&LATD*8)+7;
/* Definitions for LATC register */
static volatile near bit LATC0 @ ((unsigned)&LATC*8)+0;
static volatile near bit LATC1 @ ((unsigned)&LATC*8)+1;
static volatile near bit LATC2 @ ((unsigned)&LATC*8)+2;
static volatile near bit LATC3 @ ((unsigned)&LATC*8)+3;
static volatile near bit LATC4 @ ((unsigned)&LATC*8)+4;
static volatile near bit LATC5 @ ((unsigned)&LATC*8)+5;
static volatile near bit LATC6 @ ((unsigned)&LATC*8)+6;
static volatile near bit LATC7 @ ((unsigned)&LATC*8)+7;
/* Definitions for LATB register */
static volatile near bit LATB0 @ ((unsigned)&LATB*8)+0;
static volatile near bit LATB1 @ ((unsigned)&LATB*8)+1;
static volatile near bit LATB2 @ ((unsigned)&LATB*8)+2;
static volatile near bit LATB3 @ ((unsigned)&LATB*8)+3;
static volatile near bit LATB4 @ ((unsigned)&LATB*8)+4;
static volatile near bit LATB5 @ ((unsigned)&LATB*8)+5;
static volatile near bit LATB6 @ ((unsigned)&LATB*8)+6;
static volatile near bit LATB7 @ ((unsigned)&LATB*8)+7;
/* Definitions for LATA register */
static volatile near bit LATA0 @ ((unsigned)&LATA*8)+0;
static volatile near bit LATA1 @ ((unsigned)&LATA*8)+1;
static volatile near bit LATA2 @ ((unsigned)&LATA*8)+2;
static volatile near bit LATA3 @ ((unsigned)&LATA*8)+3;
static volatile near bit LATA4 @ ((unsigned)&LATA*8)+4;
static volatile near bit LATA5 @ ((unsigned)&LATA*8)+5;
static volatile near bit LATA6 @ ((unsigned)&LATA*8)+6;
static volatile near bit LATA7 @ ((unsigned)&LATA*8)+7;
/* Definitions for PORTJ register */
static volatile near bit RJ0 @ ((unsigned)&PORTJ*8)+0;
static volatile near bit RJ1 @ ((unsigned)&PORTJ*8)+1;
static volatile near bit RJ2 @ ((unsigned)&PORTJ*8)+2;
static volatile near bit RJ3 @ ((unsigned)&PORTJ*8)+3;
static volatile near bit RJ4 @ ((unsigned)&PORTJ*8)+4;
static volatile near bit RJ5 @ ((unsigned)&PORTJ*8)+5;
static volatile near bit RJ6 @ ((unsigned)&PORTJ*8)+6;
static volatile near bit RJ7 @ ((unsigned)&PORTJ*8)+7;
/* Definitions for PORTH register */
static volatile near bit RH0 @ ((unsigned)&PORTH*8)+0;
static volatile near bit RH1 @ ((unsigned)&PORTH*8)+1;
static volatile near bit RH2 @ ((unsigned)&PORTH*8)+2;
static volatile near bit RH3 @ ((unsigned)&PORTH*8)+3;
static volatile near bit RH4 @ ((unsigned)&PORTH*8)+4;
static volatile near bit RH5 @ ((unsigned)&PORTH*8)+5;
static volatile near bit RH6 @ ((unsigned)&PORTH*8)+6;
static volatile near bit RH7 @ ((unsigned)&PORTH*8)+7;
/* Definitions for PORTG register */
static volatile near bit RG0 @ ((unsigned)&PORTG*8)+0;
static volatile near bit RG1 @ ((unsigned)&PORTG*8)+1;
static volatile near bit RG2 @ ((unsigned)&PORTG*8)+2;
static volatile near bit RG3 @ ((unsigned)&PORTG*8)+3;
static volatile near bit RG4 @ ((unsigned)&PORTG*8)+4;
static volatile near bit RG5 @ ((unsigned)&PORTG*8)+5;
/* Definitions for PORTF register */
static volatile near bit RF0 @ ((unsigned)&PORTF*8)+0;
static volatile near bit RF1 @ ((unsigned)&PORTF*8)+1;
static volatile near bit RF2 @ ((unsigned)&PORTF*8)+2;
static volatile near bit RF3 @ ((unsigned)&PORTF*8)+3;
static volatile near bit RF4 @ ((unsigned)&PORTF*8)+4;
static volatile near bit RF5 @ ((unsigned)&PORTF*8)+5;
static volatile near bit RF6 @ ((unsigned)&PORTF*8)+6;
static volatile near bit RF7 @ ((unsigned)&PORTF*8)+7;
/* Definitions for PORTE register */
static volatile near bit RE0 @ ((unsigned)&PORTE*8)+0;
static volatile near bit RE1 @ ((unsigned)&PORTE*8)+1;
static volatile near bit RE2 @ ((unsigned)&PORTE*8)+2;
static volatile near bit RE3 @ ((unsigned)&PORTE*8)+3;
static volatile near bit RE4 @ ((unsigned)&PORTE*8)+4;
static volatile near bit RE5 @ ((unsigned)&PORTE*8)+5;
static volatile near bit RE6 @ ((unsigned)&PORTE*8)+6;
static volatile near bit RE7 @ ((unsigned)&PORTE*8)+7;
/* Definitions for PORTD register */
static volatile near bit RD0 @ ((unsigned)&PORTD*8)+0;
static volatile near bit RD1 @ ((unsigned)&PORTD*8)+1;
static volatile near bit RD2 @ ((unsigned)&PORTD*8)+2;
static volatile near bit RD3 @ ((unsigned)&PORTD*8)+3;
static volatile near bit RD4 @ ((unsigned)&PORTD*8)+4;
static volatile near bit RD5 @ ((unsigned)&PORTD*8)+5;
static volatile near bit RD6 @ ((unsigned)&PORTD*8)+6;
static volatile near bit RD7 @ ((unsigned)&PORTD*8)+7;
/* Definitions for PORTC register */
static volatile near bit RC0 @ ((unsigned)&PORTC*8)+0;
static volatile near bit RC1 @ ((unsigned)&PORTC*8)+1;
static volatile near bit RC2 @ ((unsigned)&PORTC*8)+2;
static volatile near bit RC3 @ ((unsigned)&PORTC*8)+3;
static volatile near bit RC4 @ ((unsigned)&PORTC*8)+4;
static volatile near bit RC5 @ ((unsigned)&PORTC*8)+5;
static volatile near bit RC6 @ ((unsigned)&PORTC*8)+6;
static volatile near bit RC7 @ ((unsigned)&PORTC*8)+7;
/* Definitions for PORTB register */
static volatile near bit RB0 @ ((unsigned)&PORTB*8)+0;
static volatile near bit RB1 @ ((unsigned)&PORTB*8)+1;
static volatile near bit RB2 @ ((unsigned)&PORTB*8)+2;
static volatile near bit RB3 @ ((unsigned)&PORTB*8)+3;
static volatile near bit RB4 @ ((unsigned)&PORTB*8)+4;
static volatile near bit RB5 @ ((unsigned)&PORTB*8)+5;
static volatile near bit RB6 @ ((unsigned)&PORTB*8)+6;
static volatile near bit RB7 @ ((unsigned)&PORTB*8)+7;
/* Definitions for PORTA register */
static volatile near bit RA0 @ ((unsigned)&PORTA*8)+0;
static volatile near bit RA1 @ ((unsigned)&PORTA*8)+1;
static volatile near bit RA2 @ ((unsigned)&PORTA*8)+2;
static volatile near bit RA3 @ ((unsigned)&PORTA*8)+3;
static volatile near bit RA4 @ ((unsigned)&PORTA*8)+4;
static volatile near bit RA5 @ ((unsigned)&PORTA*8)+5;
static volatile near bit RA6 @ ((unsigned)&PORTA*8)+6;
static volatile near bit RA7 @ ((unsigned)&PORTA*8)+7;
/* Definitions for BAUDCON1 register */
static volatile near bit ABDEN1 @ ((unsigned)&BAUDCON1*8)+0;
static volatile near bit WUE1 @ ((unsigned)&BAUDCON1*8)+1;
static near bit BRG161 @ ((unsigned)&BAUDCON1*8)+3;
static volatile near bit SCKP1 @ ((unsigned)&BAUDCON1*8)+4;
static volatile near bit RCIDL1 @ ((unsigned)&BAUDCON1*8)+6;
static volatile near bit ABDOVF1 @ ((unsigned)&BAUDCON1*8)+7;
/* Definitions for BAUDCON2 register */
static volatile near bit ABDEN2 @ ((unsigned)&BAUDCON2*8)+0;
static volatile near bit WUE2 @ ((unsigned)&BAUDCON2*8)+1;
static near bit BRG162 @ ((unsigned)&BAUDCON2*8)+3;
static volatile near bit SCKP2 @ ((unsigned)&BAUDCON2*8)+4;
static volatile near bit RCIDL2 @ ((unsigned)&BAUDCON2*8)+6;
static volatile near bit ABDOVF2 @ ((unsigned)&BAUDCON2*8)+7;
/* Definitions for ECCP1DEL register */
static near bit P1DC0 @ ((unsigned)&ECCP1DEL*8)+0;
static near bit P1DC1 @ ((unsigned)&ECCP1DEL*8)+1;
static near bit P1DC2 @ ((unsigned)&ECCP1DEL*8)+2;
static near bit P1DC3 @ ((unsigned)&ECCP1DEL*8)+3;
static near bit P1DC4 @ ((unsigned)&ECCP1DEL*8)+4;
static near bit P1DC5 @ ((unsigned)&ECCP1DEL*8)+5;
static near bit P1DC6 @ ((unsigned)&ECCP1DEL*8)+6;
static near bit P1RSEN @ ((unsigned)&ECCP1DEL*8)+7;
/* Definitions for T4CON register */
static near bit T4CKPS0 @ ((unsigned)&T4CON*8)+0;
static near bit T4CKPS1 @ ((unsigned)&T4CON*8)+1;
static near bit TMR4ON @ ((unsigned)&T4CON*8)+2;
static near bit T4OUTPS0 @ ((unsigned)&T4CON*8)+3;
static near bit T4OUTPS1 @ ((unsigned)&T4CON*8)+4;
static near bit T4OUTPS2 @ ((unsigned)&T4CON*8)+5;
static near bit T4OUTPS3 @ ((unsigned)&T4CON*8)+6;
/* Definitions for CCP4CON register */
static near bit CCP4M0 @ ((unsigned)&CCP4CON*8)+0;
static near bit CCP4M1 @ ((unsigned)&CCP4CON*8)+1;
static near bit CCP4M2 @ ((unsigned)&CCP4CON*8)+2;
static near bit CCP4M3 @ ((unsigned)&CCP4CON*8)+3;
static near bit DC4B0 @ ((unsigned)&CCP4CON*8)+4;
static near bit DC4B1 @ ((unsigned)&CCP4CON*8)+5;
/* Definitions for CCP5CON register */
static near bit CCP5M0 @ ((unsigned)&CCP5CON*8)+0;
static near bit CCP5M1 @ ((unsigned)&CCP5CON*8)+1;
static near bit CCP5M2 @ ((unsigned)&CCP5CON*8)+2;
static near bit CCP5M3 @ ((unsigned)&CCP5CON*8)+3;
static near bit DC5B0 @ ((unsigned)&CCP5CON*8)+4;
static near bit DC5B1 @ ((unsigned)&CCP5CON*8)+5;
/* Definitions for TXSTA2 register */
static volatile near bit TX9D2 @ ((unsigned)&TXSTA2*8)+0;
static volatile near bit TRMT2 @ ((unsigned)&TXSTA2*8)+1;
static near bit BRGH2 @ ((unsigned)&TXSTA2*8)+2;
static near bit SENDB2 @ ((unsigned)&TXSTA2*8)+3;
static near bit SYNC2 @ ((unsigned)&TXSTA2*8)+4;
static near bit TXEN2 @ ((unsigned)&TXSTA2*8)+5;
static near bit TX92 @ ((unsigned)&TXSTA2*8)+6;
static near bit CSRC2 @ ((unsigned)&TXSTA2*8)+7;
/* Definitions for RCSTA2 register */
static volatile near bit RX9D2 @ ((unsigned)&RCSTA2*8)+0;
static volatile near bit OERR2 @ ((unsigned)&RCSTA2*8)+1;
static volatile near bit FERR2 @ ((unsigned)&RCSTA2*8)+2;
static near bit ADDEN2 @ ((unsigned)&RCSTA2*8)+3;
static near bit CREN2 @ ((unsigned)&RCSTA2*8)+4;
static near bit SREN2 @ ((unsigned)&RCSTA2*8)+5;
static near bit RX92 @ ((unsigned)&RCSTA2*8)+6;
static near bit SPEN2 @ ((unsigned)&RCSTA2*8)+7;
/* Definitions for ECCP3AS register */
static near bit PSS3BD0 @ ((unsigned)&ECCP3AS*8)+0;
static near bit PSS3BD1 @ ((unsigned)&ECCP3AS*8)+1;
static near bit PSS3AC0 @ ((unsigned)&ECCP3AS*8)+2;
static near bit PSS3AC1 @ ((unsigned)&ECCP3AS*8)+3;
static near bit ECCP3AS0 @ ((unsigned)&ECCP3AS*8)+4;
static near bit ECCP3AS1 @ ((unsigned)&ECCP3AS*8)+5;
static near bit ECCP3AS2 @ ((unsigned)&ECCP3AS*8)+6;
static volatile near bit ECCP3ASE @ ((unsigned)&ECCP3AS*8)+7;
/* Definitions for ECCP3DEL register */
static near bit P3DC0 @ ((unsigned)&ECCP3DEL*8)+0;
static near bit P3DC1 @ ((unsigned)&ECCP3DEL*8)+1;
static near bit P3DC2 @ ((unsigned)&ECCP3DEL*8)+2;
static near bit P3DC3 @ ((unsigned)&ECCP3DEL*8)+3;
static near bit P3DC4 @ ((unsigned)&ECCP3DEL*8)+4;
static near bit P3DC5 @ ((unsigned)&ECCP3DEL*8)+5;
static near bit P3DC6 @ ((unsigned)&ECCP3DEL*8)+6;
static near bit P3RSEN @ ((unsigned)&ECCP3DEL*8)+7;
/* Definitions for ECCP2AS register */
static near bit PSS2BD0 @ ((unsigned)&ECCP2AS*8)+0;
static near bit PSS2BD1 @ ((unsigned)&ECCP2AS*8)+1;
static near bit PSS2AC0 @ ((unsigned)&ECCP2AS*8)+2;
static near bit PSS2AC1 @ ((unsigned)&ECCP2AS*8)+3;
static near bit ECCP2AS0 @ ((unsigned)&ECCP2AS*8)+4;
static near bit ECCP2AS1 @ ((unsigned)&ECCP2AS*8)+5;
static near bit ECCP2AS2 @ ((unsigned)&ECCP2AS*8)+6;
static volatile near bit ECCP2ASE @ ((unsigned)&ECCP2AS*8)+7;
/* Definitions for ECCP2DEL register */
static near bit P2DC0 @ ((unsigned)&ECCP2DEL*8)+0;
static near bit P2DC1 @ ((unsigned)&ECCP2DEL*8)+1;
static near bit P2DC2 @ ((unsigned)&ECCP2DEL*8)+2;
static near bit P2DC3 @ ((unsigned)&ECCP2DEL*8)+3;
static near bit P2DC4 @ ((unsigned)&ECCP2DEL*8)+4;
static near bit P2DC5 @ ((unsigned)&ECCP2DEL*8)+5;
static near bit P2DC6 @ ((unsigned)&ECCP2DEL*8)+6;
static near bit P2RSEN @ ((unsigned)&ECCP2DEL*8)+7;
/* Definitions for SSP2STAT register */
static volatile near bit BF2 @ ((unsigned)&SSP2STAT*8)+0;
static volatile near bit UA2 @ ((unsigned)&SSP2STAT*8)+1;
static volatile near bit RW2 @ ((unsigned)&SSP2STAT*8)+2;
static volatile near bit START2 @ ((unsigned)&SSP2STAT*8)+3;
static volatile near bit STOP2 @ ((unsigned)&SSP2STAT*8)+4;
static volatile near bit DA2 @ ((unsigned)&SSP2STAT*8)+5;
static near bit CKE2 @ ((unsigned)&SSP2STAT*8)+6;
static near bit SMP2 @ ((unsigned)&SSP2STAT*8)+7;
/* Definitions for SSP2CON1 register */
static near bit SSPM02 @ ((unsigned)&SSP2CON1*8)+0;
static near bit SSPM12 @ ((unsigned)&SSP2CON1*8)+1;
static near bit SSPM22 @ ((unsigned)&SSP2CON1*8)+2;
static near bit SSPM32 @ ((unsigned)&SSP2CON1*8)+3;
static near bit CKP2 @ ((unsigned)&SSP2CON1*8)+4;
static near bit SSPEN2 @ ((unsigned)&SSP2CON1*8)+5;
static volatile near bit SSPOV2 @ ((unsigned)&SSP2CON1*8)+6;
static volatile near bit WCOL2 @ ((unsigned)&SSP2CON1*8)+7;
/* Definitions for SSP2CON2 register */
static near bit SEN2 @ ((unsigned)&SSP2CON2*8)+0;
static volatile near bit RSEN2 @ ((unsigned)&SSP2CON2*8)+1;
static volatile near bit PEN2 @ ((unsigned)&SSP2CON2*8)+2;
static volatile near bit RCEN2 @ ((unsigned)&SSP2CON2*8)+3;
static volatile near bit ACKEN2 @ ((unsigned)&SSP2CON2*8)+4;
static volatile near bit ACKDT2 @ ((unsigned)&SSP2CON2*8)+5;
static volatile near bit ACKSTAT2 @ ((unsigned)&SSP2CON2*8)+6;
static near bit GCEN2 @ ((unsigned)&SSP2CON2*8)+7;
#define EEPROM_SIZE 1024
// Configuration Bit Values
// Configuration register 1H
// Oscillator
#define EXTCLKO 0xFFFF // 11XX EXT RC-CLKOUT on RA6
#define INTCLKO 0xF9FF // INT RC-CLKOUT on RA6,Port on RA7
#define INTIO 0xF8FF // INT RC-Port on RA6,Port on RA7
#define EXTIO 0xF7FF // EXT RC-Port on RA6
#define HSPLL 0xF6FF // HS-PLL enabled freq=4xFosc1
#define ECIO 0xF5FF // EC-Port on RA6
#define ECCLKO 0xF4FF // EC-CLKOUT on RA6
#define HS 0xF2FF // HS Oscillator
#define XT 0xF1FF // XT Oscillator
#define LP 0xF0FF // LP Oscillator
// Fail-Safe Clock Monitor Enable
#define FCMDIS 0xBFFF // Disabled
#define FCMEN 0xFFFF // Enabled
// Internal External Switch Over Mode
#define IESODIS 0x7FFF // Disabled
#define IESOEN 0xFFFF // Enabled
// Configuration register 2L
// Power Up Timer
#define PWRTDIS 0xFFFF // Disabled
#define PWRTEN 0xFFFE // Enabled
// Brown Out Detect
#define BOREN 0xFFFF // Enabled in hardware, SBOREN disabled
#define BOREN_XSLP 0xFFFD // Enabled while active,disabled in SLEEP,SBOREN disabled
#define SWBOREN 0xFFFB // Controlled with SBOREN bit
#define BORDIS 0xFFF9 // Disabled in hardware, SBOREN disabled
// Brown Out Voltage
#define BORV21 0xFFFF // 2.1V
#define BORV28 0xFFF7 // 2.8V
#define BORV43 0xFFEF // 4.3V
#define BORV46 0xFFE7 // 4.6V
// Configuration register 2H
// Watchdog Timer
#define WDTEN 0xFFFF // Enabled
#define WDTDIS 0xFEFF // Disabled-Controlled by SWDTEN bit
// Watchdog Postscaler
#define WDTPS32K 0xFFFF // 1:32768
#define WDTPS16K 0xFDFF // 1:16384
#define WDTPS8K 0xFBFF // 1:8192
#define WDTPS4K 0xF9FF // 1:4096
#define WDTPS2K 0xF7FF // 1:2048
#define WDTPS1K 0xF5FF // 1:1024
#define WDTPS512 0xF3FF // 1:512
#define WDTPS256 0xF1FF // 1:256
#define WDTPS128 0xEFFF // 1:128
#define WDTPS64 0xEDFF // 1:64
#define WDTPS32 0xEBFF // 1:32
#define WDTPS16 0xE9FF // 1:16
#define WDTPS8 0xE7FF // 1:8
#define WDTPS4 0xE5FF // 1:4
#define WDTPS2 0xE3FF // 1:2
#define WDTPS1 0xE1FF // 1:1
// Configuration register 3L
// External bus wait enable
#define WAITEN 0xFF7F // WAIT mode active & determined by WAIT1:WAIT0 bits
#define WAITDIS 0xFFFF // WAIT mode inactive
// External data bus width select
#define BW16 0xFFFF // 16-Bit external data bus width
#define BW8 0xFFBF // 8-Bit external data bus width
// External Address bus width select
#define ABW20 0xFFFF // 20-Bit external address bus width
#define ABW16 0xFFEF // 16-Bit external address bus width
#define ABW12 0xFFDF // 12-Bit external address bus width
#define ABW8 0xFFCF // 8-Bit external address bus width
// Processor data mode
#define MCU 0xFFFF // select microcontroller mode
#define MPU 0xFFFE // select microprocessor mode
#define MPUBB 0xFFFD // select microprocessor mode with boot block mode
#define XMCU 0xFFFC // select extended microcontroller mode
// Configuration register 3H
// CCP2 Mux
#define CCP2RC1 0xFFFF // RC1
#define CCP2RE7 0xFEFF // RE7
// if in XMCU or MPUB modes
#define CCP2RB3 0xFEFF // RB3
// ECCP Mux
#define ECCPRE 0xFFFF // ECCP multiplexed on Port E
#define ECCPRH 0xFDFF // ECCP multiplexed on Port H
// Low Power Timer1 Osc enable
#define LPT1EN 0xFFFF // Enabled
#define LPT1DIS 0xFBFF // Disabled
// Master Clear Enable
#define MCLREN 0xFFFF // MCLR Enabled,RE3 Disabled
#define MCLRDIS 0x7FFF // MCLR Disabled,RE3 Enabled
// Configuration register 4L
// Stack Overflow Reset
#define STVREN 0xFFFF // Enabled
#define STVRDIS 0xFFFE // Disabled
// Low voltage program enable
#define LVPEN 0xFFFF // Low voltage ISP enabled
#define LVPDIS 0xFFFB // Low voltage ISP disabled
// Extended CPU Enable
#define XINSTEN 0xFFFF // Enabled
#define XINSTDIS 0xFFBF // Disabled
// Boot block size select
#define BBSIZ4K 0xFFFF // Boot block is 4K
#define BBSIZ2K 0xFFDF // Boot block is 2K
#define BBSIZ1K 0xFFCF // Boot block is 1K
// Background Debug
#define DEBUGDIS 0xFFFF // Disabled
#define DEBUGEN 0xFF7F // Enabled
// Configuration register 5L
// Code Protection
#define UNPROTECT 0xFFFF // Do not protect code
#define CP0 0xFFFE // Code Protect block 0
#define CP1 0xFFFD // Code Protect block 1
#define CP2 0xFFFB // Code Protect block 2
#if !defined(_18F6527) && !defined(_18F8527)
#define CP3 0xFFF7 // Code Protect block 3
#if !defined(_18F6622) && !defined(_18F8622)
#define CP4 0xFFEF // Code Protect block 4
#define CP5 0xFFDF // Code Protect block 5
#if !defined(_18F6627) && !defined(_18F8627)
#define CP6 0xFFBF // Code Protect block 6
#define CP7 0xFF7F // Code Protect block 7
#define CPA 0xFF00 // protect all code blocks
#define CPD 0x7FFF // Code Protect data
#define CPB 0xBFFF // Code Protect boot block
#define CPALL (CPA & CPD & CPB)
// Configuration register 6L
// Write Protection
#define WRTEN 0xFFFF // Do write protect
#define WP0 0xFFFE // Write Protect block 0
#define WP1 0xFFFD // Write Protect block 1
#define WP2 0xFFFB // Write Protect block 2
#define WP3 0xFFF7 // Write Protect block 3
#define WP4 0xFFEF // Write Protect block 4
#define WP5 0xFFDF // Write Protect block 5
#define WP6 0xFFBF // Write Protect block 6
#define WP7 0xFF7F // Write Protect block 7
#define WPA 0xFF00 // Write Protect all code blocks
#define WPD 0x7FFF // Write Protect data
#define WPB 0xBFFF // Write Protect boot block
#define WPC 0xDFFF // Write Protect config area
#define WPALL (WPA & WPD & WPB & WPC)
// Configuration register 7L
// Table read Protection
#define TREN 0xFFFF // Do table read protect
#define TRP0 0xFFFE // Table read protect block 0
#define TRP1 0xFFFD // Table read protect block 1
#define TRP2 0xFFFB // Table read protect block 2
#define TRP3 0xFFF7 // Table read protect block 3
#define TRP4 0xFFEF // Table read protect block 4
#define TRP5 0xFFDF // Table read protect block 5
#define TRP6 0xFFBF // Table read protect block 6
#define TRP7 0xFF7F // Table read protect block 7
#define TRPA 0xFF00 // Table read protect all code blocks
#define TRPB 0xBFFF // Table read protect boot block
#define TRPALL (TRPA & TRPB)
